Tire deflator/ TPMS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dklein90, Oct 30, 2016.
  1. Oct 30, 2016 at 5:44 PM
    Dklein90
    Dklein90 [OP] Active Member
    Im thinking about getting a tire deflator similar to the ARB ez deflator (removes valve stem) I'm wondering if there is any risk of messing up the tire pressure monitoring system. My truck is a 2015 TRD Sport
  2. Oct 30, 2016 at 5:52 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    All tpms does is alert to low tire pressure. It wont hurt it.
    Willbeck likes this.
  3. Oct 30, 2016 at 5:58 PM
    Dklein90
  4. Oct 30, 2016 at 6:03 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    the sensor is attached to the valve stem, but it won't cause any issues. You'll just have the annoying light on the dash...
  5. Oct 30, 2016 at 6:07 PM
    Dklein90
    Thanks for the replies. I've heard they can be expensive so I'm being cautious. Sounds like others are airing down with out any issues so I assume the same will work for me.
  6. Oct 30, 2016 at 6:16 PM
    J_Hacker
    J_Hacker Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
    I have that one. I did not feel like paying the extra money for the arb stamp. It is good does what it is supposed too. I used it when I went out on Corolla beach. Pulled up next to a guy who was doing it the old fashion way with a stick a guage. He had 31's I have 33's. Had all 4 tires done in the time it took him to do 1 1/2. Worth the money. Can be a little difficult to turn at times. I reached out the the seller about the turning difficulty and they advised it was normal and they even sent me a new one free of charge. but all in all a good purchase. :thumbsup::thumbsup::thumbsup:
  7. Oct 30, 2016 at 6:20 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    I have the ARB and it works fine. But honestly I don't use it any more because an even easier, cheaper and faster option is to use these:
    https://www.amazon.com/gp/product/B006D9W5FA/
    They don't go as fast as the ARB but you run four in parallel. They don't auto stop like the Stauns but those seem to have mixed reliability and you have to set them to one pressure.
    These I screw one onto the first tire, after 30 secs the next tire until all four are going. The monitor the pressure on the first - usually almost done at this point. Take of deflator when ready and move to the next tire which will be less than 30 secs from being done too. Whole truck done in about five minutes and way less fussy than the ARB.
  8. Oct 30, 2016 at 6:39 PM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
  9. Oct 30, 2016 at 6:45 PM
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
  10. Oct 30, 2016 at 6:47 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I just used mine like that for the first time last week. It made me scramble a little to make sure I didn't over deflate the tires but it is way faster than doing one tire at a time.
  11. Oct 30, 2016 at 10:50 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I prefer this style deflator. Fast and easy.
    They are made but Currie, ARB, EZDeflator, Dobinson, XBull, and others with prices ranging from around $25 to $40. Probably all made in the same Chinese factory.
  12. Oct 31, 2016 at 4:58 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Being using the ARB for 3 years. No issues what so ever. Have used it alteast 30+ times airing down.
    Jeremy M. likes this.
  13. Oct 31, 2016 at 5:21 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    ARBFTMFW! They do NOT adversely effect the TPMS. You WILL see the low pressure indicator light come on.....But it goes out as soon as you air up again. Really a GOOD way to monitor TPMS to see if it's working!
    I do ARB deflator and a CO2 inflation system Used it enough to know it works to perfection! Fast, easy, safe, and effective. Can't beat it!
  14. Oct 31, 2016 at 9:32 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    steelhd likes this.
