Tire Deflator Options
Discussion in 'Off-Roading & Trails' started by '16goingon'17, Jun 16, 2021.
  1. Jun 16, 2021 at 11:48 PM
    '16goingon'17
    '16goingon'17 [OP] Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    Can’t seem to find reliable info on TW covering all the options out there for deflating tires. Hopefully folks who know their stuff can chime in.
    I currently use an ARB E-Z Deflator knockoff, but I’d like something I can leave on the valve and set and forget at the trailhead.
    Someone in the DFW forum posted this new concept, but why stop there? For $120 it should provide a kinetic-powered bluetooth actuator so I can press a button on my phone and all 4 tires will drop to my preset PSI.
  2. Jun 17, 2021 at 1:17 AM
    charliehex
    charliehex I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
  3. Jun 17, 2021 at 6:43 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    $6, don't over complicate this, all 4 tires in 1 minute.
    Bertlow and Slick Taco like this.
  4. Jun 17, 2021 at 8:22 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    i use some cheap staun knockoffs from Amazon and they work great. takes some fiddling to get them set to whatever pressure you want but is consistent once i set them good.
    plus they came in a 6 pack so i have 4 set for most trails and then 2 set for super low for super slow stuff
  5. Jun 17, 2021 at 8:24 AM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Just don't buy the Smittybilt valve deflators. They're unbelievably inaccurate when set accordingly.
  6. Jun 17, 2021 at 8:34 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
  7. Jun 17, 2021 at 10:43 AM
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
  8. Jun 17, 2021 at 3:38 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Same.
    I've got similar stauns knockoffs. They work great. They're slow, but yo just stick them on and walk away.
    Use that time to pound your trails beers (kidding) or whip out the map and discuss the route. Technically you could drive with them on, but I don't see a reason to do that. It increases the chances of ripping a valve out, too.
    I set them at 18 psi. If I need to go lower, I just do it the old fashioned way with a stick or a small rock, lol.
    BKinzey likes this.
  9. Jul 1, 2021 at 7:59 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I have a knock off set as well and they SUCK. I've tried to set them multiple times and they are still extremely inconsistent. Seems like YMMV with these knock offs.
  10. Jul 1, 2021 at 8:52 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I don't, and won't, run auto deflators so have no personal experience but people I trust who are very experienced claim Coyote is the way to go. They claim they are somehow better than Staun.
    https://www.coyoteents.com/deflators/
    clip and clenkeit like this.
  11. Oct 22, 2021 at 11:33 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    This, though. Been airing down with ole reliable for the last 10 years. Way faster than my buddies fancy dancy deflators and octopus hose setups
  12. Oct 24, 2021 at 4:29 AM
    texas angler
    texas angler Well-Known Member
    Texas Hill Country
    20 OR
  13. Oct 24, 2021 at 8:01 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Long ago I went to the hardware store and auto parts store for an air chuck, gauge, radiator drain petcock and a few brass pipe fittings. In about ten minutes I had a quick deflator that’s now over thirty years old.
    I wonder how much it would cost today. Still much less than what’s offered today I’d bet.
  14. Oct 28, 2021 at 12:59 PM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    I've got Coyote deflators and love them. Solid design, American made. Pretty quick too. When I first got them I checked the setpoints and they were all nailing my requested 18 psi setpoint over and over. I changed it around myself and they give repeatable results without loosening.
    IIRC the differences between Coyote and Staun are faster deflation, wrench flats to snug up your settings, come with a second pack of springs to cover high and low pressure settings instead of buying another model Staun, and I believe Coyote also OKs screwing them on at the trailhead and taking off, removing them at the first opportunity (just be mindful you've got chunks of brass hanging off your valve stems).
  15. Dec 7, 2021 at 1:23 PM
    Just1n
    Just1n Well-Known Member
    I got these, they work OK. I haven't used any of the other brands, but one thing to know is that they use a spring that is actuated by the tire pressure. So let's say that you set the deflators to 10 PSI, once the tire gets low on pressure, the air is released at a much slower rate until it gets to the 10 PSI. This is fine for me, just something to be mindful of before purchasing. What I did was set my deflators to about 7 PSI, that way the spring is easier to push and deflate quicker to 10'ish PSI. I put each one on, and by the time I get the 4th deflator on I am ready to remove the first installed deflator. Highly recommend
  16. Jan 18, 2022 at 2:02 PM
    jack415
    jack415 Well-Known Member
    Stauns
    Just1n and SilverBulletII like this.
  17. Jan 21, 2022 at 11:45 AM
    Just1n
    Wow that's quite the price tag
