Tire Chain Recs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by caitlin739, Oct 20, 2021.
  1. Oct 21, 2021 at 9:37 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    My family uses them both ... and they live near Gaspe ... and they get 150 inches a snow a year, on average. My uncle only drives on those Nokian studded tires (mostly because he drives to fast for chains) and he never gets stuck.
    Me ... I prefer the chains ... but you have to drive really slowly or you will blow up ... I mean like go slow and then go slower than that ...
    All in good fun ...
    257Roberts[QUOTED] likes this.
  2. Oct 25, 2021 at 3:18 PM
    caitlin739
    caitlin739 [OP] Active Member
    Caitlin
    TRD Sport
    Sorry guys! It was a typo. 265 70R 16. I switched wheels/tires with a friend's OR
    Taco_Craig likes this.
  3. Oct 25, 2021 at 5:02 PM
    RavenTechnik
    RavenTechnik Well-Known Member
    Jed
    Oregon
    2021 White Tacoma TRD Off Road DCLB
    When buying chains, do you guys typically just buy one set (2 tires) or get chains for all 4 tires?
    I will be taking a trip down to California from Oregon over the Mt Shasta pass, which I believe requires chains. I’m sure if it’s bad I’ll go 4-wheel drive which makes me think I should get two sets of chains.
  4. Oct 25, 2021 at 5:18 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Like others have said, I have the Peerless Autotrac ones and have been super happy with them. Great traction and a good road feel for ice, snow, and even patches of pavement if it's late/early season in SoCal. Never had a problem with their auto-tightening system.
    Find the set that fits your tire size and buy on Amazon!
    https://peerlesschain.com/light-truck-tire-chain/auto-trac-lt
  5. Oct 25, 2021 at 5:25 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    In the days of rear wheel drive cars I always used snow tires and I kept a pair of summer tires with chains mounted in the trunk. If it got real bad just pull over, jack car up and install chained tires. A technique I used to keep chains real tight was to deflate the tires near completely and install the chains as tight as I could then inflate to proper pressure. Those chains always stayed tight and never gave me a problem.
  6. Oct 25, 2021 at 5:40 PM
    Citizen
    Citizen Active Member
    Bay Area, CA
    2020 Tacoma - Off Road 4x4
    When I purchased my 2020 I had to sign a waiver saying I understood to NOT use chains, but instead to use cables…..but you guys are using chains?
  7. Oct 25, 2021 at 5:49 PM
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    If you have never used them before, don't try putting them on for the first time by the side of the road in bad weather. Do it in your driveway or garage for practice. You will be glad you did.
    Doghouse61 likes this.
  8. Oct 25, 2021 at 5:53 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    You seriously had to sign a waiver about chains??? In California??? (Yes I know there is snow in parts of Northern California) I didn’t sign any sort of waiver and I park beside my igloo daily!!!
  9. Oct 25, 2021 at 6:13 PM
    Summitroad
    Summitroad Well-Known Member
    Northen CA
    TRD OR 4X4
    Mt Shasta pass? Hwy 5 highest point is at Syskiyou pass in OR. Done it many times, in general, 1 set of 2 chains for the rear, in the front there is not enough clearance beteween tires and A arm for chains, cables would be ok. but, I have never done it or need it. Main thing is to have adequate tires and check weather
  10. Oct 25, 2021 at 6:17 PM
    RavenTechnik
    Jed
    Oregon
    im not 100% it’s called Mt Shasta pass . I would be taking I5 the entire way.
  11. Oct 25, 2021 at 6:31 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    You'll find out how close your tires are to your UCAs real quick.
  12. Oct 25, 2021 at 6:41 PM
    Summitroad
    Northen CA
    TRD OR 4X4
    Most of the time Hwy. 5 is keept in good shape. Normally I pay attention to the temp. of the day to avoid black ice.
  13. Oct 25, 2021 at 9:39 PM
    Jes
    Jes Well-Known Member
    Knoxville
    2017 Taco TRD Pro Cement
  14. Oct 25, 2021 at 10:42 PM
    HV101
    HV101 Well-Known Member
    Harlow
    2016 Gray Tacoma SR5 Access Cab
    None
    It’s Siskiyou Pass on I 5. Elevation 4300’. Highest point from Mexico to Canada. I would not recommend using chains on front tires of 4wd Tacoma. Check owner manual. If you have decent tires and fwd, you can get through chain check points in California without chaining up. unless it’s really coming down. And by that time, they are probably getting ready to shut freeway down anyway. Chain crews help install and remove for fee if you want on I80 and 50.
  15. Oct 26, 2021 at 12:19 AM
    #35
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    https://www.lesschwab.com/more/tire-chains
    If you don’t have experience with chains, and don’t plan on off-road use/ abuse of them then I’d highly recommend going to LS for the quick fit chains. They will show you how to properly install and adjust them and if you end up not using them, they will issue a full refund at the end of stud season. April 1 I believe is the date. I don’t use these for oversized tires and off-roading but have used them in a car and 2wd Tacoma.
  16. Oct 26, 2021 at 12:31 AM
    #36
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    One set for the rear is all you need. Things get close in the front when you steer and hit bumps. Not necessary up front.
  17. Oct 26, 2021 at 7:33 AM
    #37
    TacoPlatter
    TacoPlatter Well-Known Member
    Michigan
    2017 Double Cab Off Road
    Good recommendation on using chains on the rear only. Chains are only for the extreme conditions noted and best not to be driving, if possible, when they are truly needed. Consider dedicated winter tires for your commute. They make a huge difference. I run Nokian Hakkapeliittas.
  18. Oct 26, 2021 at 8:22 AM
    #38
    DuffyBank
    DuffyBank Well-Known Member
    Sounds like the OP needs them more for regulatory compliance than actual use, but here is my 2-bits.
    Dedicated quality winter tire first and foremost. Consider pizza cutters as the contact patch is actually larger, airing down also helps. Make sure you have weight in the back of your truck. Sand bags between the wheel wells are good, I also use cement patio tiles as they lay flat. Advantage of sand bags is you have sand if you need to throw some around your tires to get going again. Make sure you have a shovel. A small winter kit with blankets, survival munchies, ... will get you through being trapped in hours long road closures.
    If you need chains on the highway, consider parking it until maintenance crews can catch up, but if you must carry on no matter what, get a set that you can operate and practice installing them. I carry a good set of v-bar chains that I occasionally need for bush work, something more user friendly probably suits your needs. For the most part, mine act as an extra sand bag as I haven't needed them in two years. Install, tension, drive, re-tension.
    I live in the mountains of BC, with mountain passes all around and have never used chains on the highway.
    Doghouse61, averagejp and Speedfreak like this.
  19. Feb 24, 2022 at 11:15 AM
    #39
    JimROCDS
    JimROCDS Well-Known Member
    Jim
    Massachusetts
    Tacoma
    I plow with my Tacoma and although I have snow tires on, they're not as good as I like.
    So this year I decided to get some snow chains. I purchased the Peerless Auto Trac Chains.
    I followed the manufacturers size and then followed the videos and the instructions that came
    with the chains. It wasn't as easy as they made it look. My guess is that they used larger chains
    than what the recommended size is.
    Anyway, I saw this video and this guy's method makes it much easier for me. It's a little
    more inconvenient in that I had to get under the truck to connect the cable, but otherwise
    it was easier having the chain in front of me than behind the tire when I first set up the cable
    connection.
    Anyway, he's the video that I found the better method for me.
    https://www.youtube.com/watch?v=Dgi-T_dBjsc
  20. Feb 27, 2022 at 3:25 AM
    #40
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
