Tips for removing tight/stubborn Toyota connectors?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bcmbcmbcm, Mar 13, 2022.
  1. Mar 13, 2022 at 6:23 PM
    bcmbcmbcm
    bcmbcmbcm [OP] Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Hey folks,
    Does anyone have any tips for removing some tight factory Toyota connectors? I am trying to separate the DRL connector at the drivers side headlight. I lifted the retaining tab but it still won't budge. I don't want to put tools on it and mess it up.
    Thanks in advance!
    Brett
  2. Mar 13, 2022 at 6:48 PM
    flatironsoverland
    flatironsoverland @FlatironsOverland
    Erie, Colorado
    Well I'd say the solution has to do with why the connector isn't releasing normally. Electronics cleaner can help clean out a dirty and caked connector. If it's related to something else however, my suggestion would change.
  3. Mar 13, 2022 at 6:51 PM
    bcmbcmbcm
    Brett
    Thanks. I can't imagine why it would be dirty or not releasing normally. This is a 2022 with only 3k miles on it.
  4. Mar 13, 2022 at 6:53 PM
    flatironsoverland
    Erie, Colorado
    In that case it may just be a tight tolerance clip. In general with clips you should press the release tab, press the two connectors together (so that the release can full disengage), then pull them apart. As you know using any tool will likely break or damage the clip, just not worth it in the long run.
  5. Mar 13, 2022 at 6:56 PM
    bcmbcmbcm
    Brett
    Thanks. It looks like the clip pulls up on this one. Are you saying to push the connectors in after releasing the clip?
    Sierrahunter likes this.
  6. Mar 13, 2022 at 7:00 PM
    flatironsoverland
    Erie, Colorado
    Correct, it's a bit backwards to what you think but when you push them together while pressing the release, it allows the release part fully disengage since it's having issues.
    AmateurTaco1313 likes this.
  7. Mar 13, 2022 at 7:02 PM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    Sometimes they just need a little wiggle
    flatironsoverland likes this.
  8. Mar 13, 2022 at 7:02 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  9. Mar 13, 2022 at 8:00 PM
    bcmbcmbcm
    Brett
    Connector wasn't stuck. I was. It was a push down vs. a pull up. Thanks fellas.
  10. Mar 13, 2022 at 8:45 PM
    flatironsoverland
    Erie, Colorado
    We've all been there, good thing you didn't force it and break it!
  11. Mar 14, 2022 at 4:28 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    If you are struggling with a connector in a tight spot, I recommend finding a similar one in an easy location to practice on.
