Tips for removing spare tire hoist winch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by farrington14, Sep 25, 2022.
  1. Sep 25, 2022 at 5:53 PM
    farrington14
    farrington14 [OP] Active Member
    2014 Tacoma 2.7L MT 4WD regular cab
    Does anybody have any tips for removing the spare tire hoist winch without having to remove the bed? Mine is completely rusted and I'd like to replace it, but getting to the bolt heads above the winch is tricky. If you know of a tool that works well to reach up there, please let me know.
  2. Sep 25, 2022 at 6:00 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    You don't necessarily have to completely remove the bed, but loosening in and moving it up a couple inches would make it a lot easier with a ratcheting wrench.
    I need to remove mine. I tried without removing the bed and gave up.
    farrington14[OP] likes this.
  3. Sep 25, 2022 at 6:10 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I removed mine with a regular crescent wrench. A ratcheting wrench would have been great.
    Don't need to remove or mess with the bed; just accept that it's going to be tight.
  4. Sep 25, 2022 at 9:58 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Unbolt it. It’s 4 bolts. Takes only a few minutes
    Bikinaz and FishaRnekEd like this.
  5. Sep 25, 2022 at 11:00 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    i recently removed mine with a ratcheting wrench, did not have to move the bed. just took a little bit of patience because of the tight space.
  6. Sep 25, 2022 at 11:02 PM
    mushroom_man7
    forgot the mention I dremeled the four bolts down to the baseplate so that they come out sooner
    SR-71A and farrington14[OP] like this.
  7. Sep 26, 2022 at 5:03 AM
    netman86
    netman86 Well-Known Member
    Maine
    99 flatbed, 2013 quad cab
    Certainly watching with interest.
    I had to torch my spare out yesterday to fluidfilm the frame.
    Wrecked the tools designed to drop the tire first, whole mechanism is seized up.
    Did you find a replacement? I haven't looked yet...
    Removing the bed doesn't look so bad- but I just found out yesterday it's made of plastic! Normally I'd consider drilling through-holes and plug welding them, but a plastic bed is entirely new to me.
    Anyway- if you dremel or otherwise grind those bolts flush from the underside- you might be able to simply through-drill them easier than trying to get them out with a wrench. The threads will be reversed coming from this end so a pilot hole through each bolt and then maybe a 1/2" bit... if it bites hard it could unthread the bolt- if not it will drill it out and make it easy to get rid of from there.
    I likely won't get to this project until next summer, but I'm interested in how you handle it.
  8. Sep 26, 2022 at 5:09 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I think i still have a spare tire hoist that i removed from 2015 tacoma. If one of you needs it, i can go look to confirm if it's still around.
  9. Sep 26, 2022 at 5:22 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    If you do end up removing the bed, make sure to spray the bolts with penetrant and let it soak for a day first.
    I couldn't take off the spare winch with the bed in place...
  10. Sep 26, 2022 at 5:28 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    Spoken like a true rust free AZ owner. :thumbsup:
  11. Sep 26, 2022 at 5:51 AM
    netman86
    Maine
    I seriously have doubts that I could remove the bed without breaking at least two of those bolts- the spare tire ones wouldn't stand a chance :)
    If the mechanism itself is rusted and seized up (like mine), chances are the bolts to remove it are far worse.
  12. Sep 26, 2022 at 6:49 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    I see… I didn’t have any of that to deal with. My truck is a southwest truck from 2008 so it was very easy
  13. Sep 26, 2022 at 6:49 AM
    farrington14
    If it's in good shape, I would absolutely take you up on that generous offer.
  14. Sep 26, 2022 at 6:57 AM
    farrington14
    Thanks. I'll reply here after I've removed it to let you know how it went. I'm not in a huge hurry, but I'll likely get to it in the next month. The longer I let it go, the worse the rust will be, especially with the winter salty roads.
  15. Sep 26, 2022 at 6:59 AM
    mushroom_man7
    I did it without removing the bed, why are people talking about removing the bed? seems really unnessacary unless im missing something
  16. Sep 27, 2022 at 6:11 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Was on a southern truck. I took it off my 2015 tacoma after only a year or 2. Been in a box since. I only have 1 of the bolts but otherwise looks nearly new. Looks like M8x25. Most auto parts stores carry those in a zinc coated grade 10.9 if you don't already have some laying around. Send me a pm and we can make a deal to ship it to you.
    Got some 2nd gen tacoma oem floor mats too if you want em. ;)
    wilcam47 and Jimmyh like this.
  17. Oct 8, 2022 at 4:04 PM
    farrington14
    I installed the winch today. As rusty as my bolts were, some penetrating oil and a wire brush cleaned them up enough so that I could wrench them off. I tried a few angled wrenches, but in the end all I needed was a straight 12mm ratcheting box-end wrench. I had to take the rear bolts off first and then loosen the two front bolts at the same time so that the winch would drop down as I loosened them - there wasn't enough clearance between them and the bed otherwise. And when I replaced the bolts, I ended up buying slightly shorter ones. I think the originals were 25mm long, but I went with 20mm. I probably could have gotten away with 15mm, but 20mm was the shortest M8x1.25's that my local hardware store had. I hope yours goes as smoothly next summer.
  18. Mar 27, 2023 at 6:50 PM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    I got a 12mm wrench on these bolts but its a little short. These are normal bolts yea? So looking up id be turning clockwise to remove? Stupid question but the bolts looked a little funny. Didn’t want to cranking them the wrong way with what little wrench i have
  19. Mar 27, 2023 at 7:04 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    Now that it is replaced, make it a point to exercise it twice a year to inspect and to help keep it free. While it's down, liberally coat the entire mechanism and works with Fluid Film or equivalent. I do this every year spring and fall and even though when raising it, I don't muscle it down over-tight, it's still very stubborn about letting go to lower it on next the initial try. I coat the wheel as well.
  20. Mar 27, 2023 at 7:40 PM
    farrington14
    They're regular bolts and nuts. They are not reverse threaded. So turn them the way you would a normal nut and bolt.
    Slvr14tacoma[QUOTED] likes this.
