Tips for removing dealer sticker on tailgate?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maine_Tacoma13, May 6, 2019.
  1. May 6, 2019 at 8:29 AM
    Maine_Tacoma13
    Maine_Tacoma13 [OP] Well-Known Member
    There is a small dealer sticker on my tailgate that I'd like to remove. I would assume that it is fairly easy to remove probably by simply pealing by hand but is there anything I should/could use in case there is any left over residue or potentially a "sun stain" of sorts from being there for a couple of years?
  2. May 6, 2019 at 8:38 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Apply a bit of heat with a hair dryer, slowly peel back. Use Goo Gone to remove adhesive.
  3. May 6, 2019 at 8:45 AM
    Gimmick
    Gimmick Well-Known Member
    Anthony
    Canada
    2017 TRD Offroad DCSB
    goo gone is great. Just wash it off after
    xxTacocaTxx likes this.
  4. May 6, 2019 at 8:50 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Heat gun on low. And take your time. The faster you try and heat it the sticker will become so weak it will break apart and leave behind the adhesive as you pull it off. Use just enough heat to get it to lift away and it should all come off in one piece.
  5. May 6, 2019 at 8:54 AM
    ThotVaccine
    ThotVaccine Well-Known Member
    2019 MGM Tacoma TRD Off-Road
    As stated before, a little heat and it should peel right off.
    I took mine off within a month of ownership. I used a blow dryer on low heat and low speed settings. Heated for about 30sec, and the sticker peeled right off, no residue left behind.
  6. May 6, 2019 at 9:31 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Heat gun or hairdryer, warm up and peel away.
    Use a eraser wheel, quick and easy and wont damage the paint.
    Apply vasaleine to the sticker and let is sit about an hour. Depends on the type of sticker it should slide right off.
  7. May 6, 2019 at 9:34 AM
    mOjO_Taco
    mOjO_Taco Well-Known Member
    Mesa, AZ
    2020 TRD 4X4 OR Cement
    None yet
    I used a hairdryer and 3M adhesive remover, worked great and no residue. Make sure to give it a nice polish afterwards.
  8. May 6, 2019 at 9:35 AM
    Casinater
    Casinater Well-Known Member
    Casey
    2017 Quicksand Tacoma TRD OR DCSB
    +1 for hair dryer. I used a car adhesive remover from turtle wax. It’s citrus based and safe on car paint.
  9. May 6, 2019 at 9:41 AM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    Rubbing alcohol is also good for removing sticker residue.
    I'm not sure about goo gone, if it has grit in it, it will damage your paint! (I may be thinking of something else, maybe orange off)
  10. May 6, 2019 at 9:43 AM
    su.b.rat
    su.b.rat broken truck
    Boghog1 likes this.
  11. May 7, 2019 at 9:43 AM
    DESportTRD
    DESportTRD Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    Heat and peel with hair dryer, use a plastic scraper or plastic credit card is necessary. Use WD40 to remove excess glue/sticky. Clean off WD40 with GlassPlus (has no ammonia), apply wash etc. Been doing this for many years for removing Dealer decals, and debagging emblems!
  12. May 7, 2019 at 10:25 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Goo Gone is great stuff. No abrasives.
  13. May 7, 2019 at 10:40 AM
    Clipper16
    Clipper16 Well-Known Member
    Gil
    Tennessee
    2018 TRD Sport ACLB Intense White Tech and Pro
    Rubbing alcohol removed the adhesive residue much faster than GooGone on my TRD SPORT stickers.
  14. May 7, 2019 at 10:55 AM
    gw204
    gw204 Well-Known Member
    Wash the area first to remove any dirt. Then if you have dark paint park in the sun. That could be all the heat you need.
  15. May 7, 2019 at 10:57 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    80 grit sandpaper work best.
  16. May 7, 2019 at 11:01 AM
    ICU1
    ICU1 Well-Known Member
    Replace tailgate. :crapstorm:
  17. May 7, 2019 at 11:12 AM
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    This is absolutely retarded advice that will leave people with scratched paint.
    Tullie D and BSFord like this.
  18. May 7, 2019 at 11:43 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
  19. May 7, 2019 at 11:50 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    One of the dealbreakers I tell a salesman when I new truck shopping is if you put that shitty advertising sticker on my truck you lose the deal. It's worked for the last 4 vehicles I bought, there has been no dealer stickers of any sort. I guess if they pay me like 99$ a month I'll advertise for them , but untill that day comes , dont put that shit on my truck.
    Shveet and BSFord like this.
  20. May 7, 2019 at 1:04 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    I second that. Your fingernail is about as hard as you wanna get.... if you heat it right, you shouldn't need a scraper.
