Tips for Backing Up Your Trailer
Discussion in 'Towing' started by chilioil.514, Oct 1, 2016.
  1. Oct 1, 2016 at 3:54 PM
    chilioil.514
    chilioil.514 [OP] Well-Known Member
    2003 Tacoma TRD Prerunner 4-Door
    Prodigy P2, Alpine 235BT, Hayden Aux Trans Cooler, Scan Gauge II
    Relatively new to towing w 2 yrs experience. One thing I'm still trying to improve is backing up the trailer and requiring less attempts to get into a driveway/campsite. Below are some of the things I've learned.
    - practice in a big parking lot
    - have a ground guide be another set of eyes
    - turn the opposite way that you'd think to move
    - small steering adjustments have large effects
    - remove WDH spring bars before backing up
    Any other suggestions/tips?
    theredofshaw likes this.
  2. Oct 1, 2016 at 4:01 PM
    jsi
    jsi Well-Known Member
    native earthling
    Go slow and make lots of little corrections.
    Once you've got the trailer going the right direction turn the front wheels so the front end will follow the same curve.
    NMroamer likes this.
  3. Oct 1, 2016 at 4:05 PM
    apreston1
    apreston1 Well-Known Member
    Liberty Hill, Texas
    Place your hand on the bottom of the steering wheel, move your hand to the right and the trailer steers right, move your hand left of center and the trailer steers left.
  4. Oct 1, 2016 at 4:07 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    ^^^ this
    ramonortiz55 likes this.
  5. Oct 1, 2016 at 4:08 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    If backing is challenging you and the opposite turning thing is throwing you off then hold you hand on the bottom of the steering wheel then you turn the wheel the same direction you want the trailer to go. Yes small trailers react quickly with little steering input. The key to backing the really little trailers is not to see it in either side view mirror. If you don't see it then you're going straight.
  6. Oct 1, 2016 at 4:17 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    I'll just say practice...
  7. Oct 1, 2016 at 4:38 PM
    chilioil.514
    Nice! Like the bottom steering wheel tip.
  8. Oct 1, 2016 at 4:51 PM
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    Try your best (because sometimes you simply can't due to terrain or obstacles) to get the truck and trailer in a straight line. Take it slow and use small corrections like they said earlier... Small trailers can be a PITA but after doing it a few times it becomes fairly simple.
  9. Oct 1, 2016 at 4:52 PM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Best advice here.
    Hardscrabble likes this.
  10. Oct 1, 2016 at 4:58 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Practice backing up in a straight line, accomplish this and everything else will come easier.
  11. Oct 1, 2016 at 5:20 PM
    chilioil.514
    Anybody ever mount a camera at the back of the trailer (e.g. license frame) for visibility? A camera that connects to an iPad or iPhone wirelessly would be nice. Anyone w experience w this?
  12. Oct 1, 2016 at 11:50 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    a shorter tongue will make backing overly responsive
    and the trailer's towing stability will be more sensitive at speed.
    a lengthened tonque serves well to improve
    both backing ability and towing stability.
    but too long of a tongue can occasionally be problematic
    for extreme entry - departure angles.
    And so... there is a line that can be crossed.
    rule of thumb for determining maximum tongue length...
    the measurement from the hauler's rear axle to the trailers axle
    should be near about the same as the hauler's Fr - Rr measured wheel base.
    the trailer should be able to minimully swing 90* (L or R)
    and preferably without damaging the side of yer hauler.
    I use my spare tire mounted on the front of my trailer
    combined with my hauler's custom rear bumper...
    to limit my trailer's swing and avoid possible contact
    to the side of my hauler.
    This could be a valuable consideration if...
    if ya ever lose traction /or stall when attempting a climb...
    and inadvertently roll backwards more then was intended *
    * a trailer commonly does not stay in line with the hauler
    when sliding down a hill backwards. Especially if the slide is abrupt.
    ^ possibly a helpful tip if ya wish to avoid sheet metal damage !? Lol
    I've had an 90* trailer incident (jackknife) occur before
    as I attempted to climb up a slippery slope (trail).
    My winch managed to straightened things out afterwards.
    Could be considered butt puckering
    when yer sliding down a hill backwards
    while towing a trailer !!
    But I got outta that pickle
    with my sheet metal intact, as well my dignity. Lol
    thanks Warn
  13. Oct 2, 2016 at 7:32 AM
    chilioil.514
  14. Oct 3, 2016 at 6:52 AM
    tgear.shead
    tgear.shead Well-Known Member
    When I was about 12 or 13, I learned both how to drive manual AND how to back up trailers by backing a SHORT trailer through a long, windy, narrow, and muddy track with a long truck with a manual transmission. There was firewood at the other end of the track, and nowhere to turn around.
    Ever since that day, the only time I ever have to take a second run at backing up a trailer is if I'm incredibly SICK. Its hard to focus when you're sick. Oh, and the wood splitter, its about 4 feet from coupler to axle, CANNOT be backed up sanely by anything besides the 4wheeler.
  15. Oct 3, 2016 at 10:59 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Wow, it must be exhausting being so awesome.
    cgm likes this.
  16. Oct 4, 2016 at 6:11 PM
    jsi
    native earthling
    I learned the same way, big ass dump truck, short little chipper. When driving straight you couldn't even see the chipper in the mirrors. The first time I tried backing with a short vehicle I thought it would be easy, but I was like a complete beginner.
  17. Oct 7, 2016 at 2:23 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    If you own a garden tractor and trailer, go hook it up and drive around the yard in reverse. If not take your trailer to Walmart and practise in a big open lot.
    There are way to many people towing trailers that have no idea how to control it. Going to boat ramps and camp grounds are entertainment to watch.
    Unfortunately I don't have any "secrets" to share other than practise.
  18. Nov 23, 2016 at 4:17 PM
    cmartinez95
    cmartinez95 Well-Known Member
    Houston
    2014 TSS DCab 4x4
    2.0 SAWS, 2.0 Icon Rear Shocks, 1.5" Icon AAL, USOFFROAD Winch Mount, Warn M8000S, HID Retrofit Headlights, Custom made sliders, Fab Fours rear bumper, LED Fogs, Heated Mirrors, Auto Dimming rear view with temp and compass, BAMF antenna mounts, LED Interior lighting and Undercover SE Tonnea.
    This is good in theory. I'd actually consider it if it didn't have to plug into the OBDII port. I already use that for my scanguage, so I wouldn't be able to use this. The search for something like this continues. But just to add to the original topic, nothing beats practice. And I've also grabbed two little radios so that my wife and I can talk as I'm backing up into a campsite with our TT. Makes it easier when we can communicate easily as I try to back in. Did that just this past weekend at a local state park here in TX.
  19. Jun 30, 2018 at 5:23 AM
    cgm
    cgm Well-Known Member
    NBPT, MA
    2014 TRD Sport 6 Speed DCSB
    I realize that this is an old thread, but thanks for the advise. I'm going to try the "hands on the bottom of the steering wheel thing"
    Thesandaddict likes this.
  20. Jun 30, 2018 at 8:20 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Just don't be Peter Griffin :D
