Tip for removing stubborn diff fill plug?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VTDave, May 7, 2010.
  1. May 7, 2010 at 6:25 AM
    VTDave
    VTDave [OP] Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    My rear diff fill plug looks like someone beat the snot out of it with an air tool. It's on there tight and the corners are slightly rounded, but probably salvageable. Any tips for getting it off? I've already tried penetrating oil and tapping the breaker bar with a hammer.
    The problem is that the the bolt head is pretty shallow and when I tried to use a breaker bar to get enough torque on it, it seemed like the socket was going to slip off. There just wasn't enough bolt head material for the socket to hang onto.
    I thought about hitting it with heat, but perhaps MAPP gas torch + diff oil = bad idea.
    Ideas?
    Thanks
    Dave
  2. May 7, 2010 at 6:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Keep tapping the wrench with a hammer
  3. May 7, 2010 at 6:35 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Key word, TAPPING, NOT to be confused with Banging!!:D
  4. May 7, 2010 at 6:37 AM
    VTDave
    Vermont, USA
    Chris: how long would you tap w/ the hammer before switching to Plan B (to be determined)?
    I tapped it for ~ 5 minutes. Tonight I'll give it another try.
    (Ok, bring on all the sarcastic comments about TAPPING THAT!! FOR ONLY 5 MINUTES?)
  5. May 7, 2010 at 6:38 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    6 point socket and grind (or turn on a lathe) the bevel off the end of the socket. The end of the socket that goes on the Drain Plug should be square so you get max bite on the bolt.....
    There's plenty of bolt to get a bite on, just not enuf socket until the bevel is gone....
  6. May 7, 2010 at 6:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would try it off and on for about 10 mins.
  7. May 7, 2010 at 6:47 AM
    rob1
    Robert
    South Texas
    Just be patient with it and it should break loose. Turning the right way??
  8. May 7, 2010 at 8:08 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    you have a new one (fill plug) at the ready, right?
  9. May 7, 2010 at 8:12 AM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    vice grips and a hammer
  10. May 7, 2010 at 8:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think you can get vice grips around the fill or drain plugs on his truck
  11. May 7, 2010 at 8:16 AM
    kris77
    West Virginia
    why not? The drain plug sticks down enough. They make big enough vice grips...The fill plug, Im not too sure about..
    I just changed this fluid like 2 days ago, and i cant remember if the fill plug was sticking out enough or not...Almost positive the drain plug is though.
    My bad...I knew it was sticking down..lol...Forgot it had a case around it.
  12. May 7, 2010 at 8:17 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    put ATF fluid on the bolt and just give time, second make sure you have tighest fit socket you can find... 6 point would be the best.
  13. May 7, 2010 at 8:22 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    go tow something big and get that rear end red hot...then try tapping it with a BFH
  14. May 7, 2010 at 8:28 AM
    aficianado
    back to bone stock.
    i find that if you sometimes switch from a 12 pt wrench to a 6 pt, or vice a versa..you can get more bite. hell, i have even gone to a tight standard sized socket and tapped them on. all these move have a distinct "point of no return".
  15. May 7, 2010 at 9:12 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Others have just asked the Dealer to help get it lose...most do it for free.
  16. May 8, 2010 at 4:25 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Pick up a new plug, then get someone to weld a nut or old lug nut to the plug. You should have no issues getting the plug out after this.
  17. May 8, 2010 at 5:14 AM
    1980
    1980 Well-Known Member
    The Dust Bowl
    For a rounded-off bold that you can't get purchase on you can try using a drift punch and hammer. You will probably have to tap from several different angles but eventually the bolt should start to move. An alternative is to file a couple of new parallel flats and then use an open-ended wrench and hammer. I had to do this a lot when I worked for one farmer who seemed to think that a 24" pipe wrench was the only tool they made.
  18. May 8, 2010 at 2:30 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    PENETRATOR LUBE!!!! All jokes aside I was being serious. I use PB Blaster and a 3/8" ratchet with a 6 sided socket. No hammers no BS, just getting the job done.
    Worst case scenario would be to heat it slightly it and give the plug a solid wrap with a small ball-peen hammer.
  19. May 8, 2010 at 5:19 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    That's what I would do.
