Timing Chain Tensioner Removal and re-seal (3RZ)
Discussion in '1st Gen. Tacomas (1995-2004)' started by ElTacoma, Jan 3, 2016.
  1. Jan 3, 2016 at 11:23 AM
    ElTacoma
    ElTacoma [OP] Well-Known Member
    San Luis Obispo
    2011 tacoma wheels, spidertrax 1.5" lug-centric spacers, magnaflow exhaust, magnaflow cat
    Does anyone know of a write up on how to remove the timing chain tensioner? My goal is to re-seal it, as I believe it is leaking.. It looks pretty tough to get to, and would most likely need to remove the AC compressor. Here is the only pic I could find in the FSM
  2. Jan 3, 2016 at 11:40 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Good question. Looks like it just unbolts from the side. Does this help?
  3. Jan 3, 2016 at 2:01 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    It's not a bad job at all. I do t remember if the AC compressor has to come off but if it does, it's only 4 bolts. Just leave the lines hooked up and let it dangle. Pop off the two bolts on the tensioner and it slides right out. It should have an o-ring on it to seal things up if I remember correctly. You do have to take the valve cover off to make sure the little lever that holds the tensioner in is released after installation.
  4. Jun 9, 2018 at 12:46 PM
    Duty Bootie
    Duty Bootie Well-Known Member
    Richard
    Vancouver Island
    96 Taco Bush Truck - Now in Restoration
    Do you have to drop the oil pan as part of this operation please....I'm doing a head gasket but while I'm at it I want to do timing chain/tensioner and water pump.....no sense going back in in less than another 400,000 KM LOL
  5. Feb 6, 2020 at 11:38 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    All that crap is in a 3rz!!? Wow. I had no idea.... lol8FE2E453-B9AB-4A05-A948-E9BA7CAECED5.jpg
  6. Feb 6, 2020 at 11:52 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Probably better to ask this in the 2nd gen forum...
  7. Sep 15, 2022 at 5:41 AM
    Pupinaut
    Pupinaut New Member
    I know this is a very old trend, but I had the same question as Duty Bootie. Were you able to pull the cover without dropping the oil pan... In a 95, 4x4, 3RZ the clearance between the oil pan and the front differential is very limited. I wonder how you were able to get this picture. The oil pan does not seems to be aligned, so it might be that is is dropped and sitting on the differential.... to be continued once solved :p
  8. Sep 15, 2022 at 8:00 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Cover has two pins at top....mates/ plugs straight up to bottom of head.....
    So u have to drop pan at least enough to slide cover down to clear those ...
    Unless head is already off........
  9. Apr 2, 2025 at 1:19 PM
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    That’s why I deleted the balance shafts. So much crap taken off the engine that doesn’t need to be there.
  10. Apr 2, 2025 at 5:32 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    I had to drop my OP(2RZ..basically same)
    as far as the rear clearance in rear….
    There is some flywheel shield that comes off. IIRC had to “set back” some tranny lines and T line brackets too
    totally enough room to get socket with swivel and extension up there NP
