Timing chain replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mr Bob, Jul 14, 2021.
  1. Jul 14, 2021 at 12:54 PM
    Mr Bob
    Mr Bob [OP] Active Member
    Engine is a F2 Rz - n73 1996 Toyota Tacoma extended cab 2 wheel drive
    wondering what all gaskets needed when replacing timing chain and is it necessary to have to pull the head
  2. Jul 14, 2021 at 12:59 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I wouldn't replace the timing chain unless it broke.
  3. Jul 14, 2021 at 1:02 PM
    Mr Bob
    If it breaks in this engine it will destroy the engine it definitely has to be replaced the engine is a 2.4 L and believe you me I'm really not thrilled about having to get it done but I have two hundred seventy-four thousand miles on the engine I put new front wheel bearings on it and brakes and when I took it down off the stands and went to start it up I heard this clunk which was either the plastic guide bracing or it jumped tooth on the gears and I can hear it slightly slapping against the housing plus the research that I've done of others and the symptoms I have the same
    Rachelsdaddy likes this.
  4. Jul 14, 2021 at 1:08 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I don't know much about the 4cyl timing chains but theyre considered a lifetime part...it's the timing belt on the V6 that has a 90k replacement interval
    But if it's showing signs of failure or stretching then it's better to be safe than sorry
  5. Jul 14, 2021 at 1:12 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    FYI 1996 2.4 is 2rz with 8 port intake manifold. 22r are in the pickup 95.5 n older
  6. Jul 14, 2021 at 1:28 PM
    Mr Bob
    The tag on door of my truck States 10/95 my title says 1996 maybe I misread the information about the 22R all I know is I'm a life member of the DAV service-connected for my feet and I got to have transportation I got a F-150 with a zero mile transmission in it I just had put in thought I only had 94000 miles on the ends and because it is a one owner truck come to find out it's probably got about $294,000 and it's got a bad cylinder I have an F-350 with $6,500 worth of Parts about 10 to 12 thousand miles on remanufactured engine engine and everything that is 27 year old kid about three and a half years ago rear-ended me while I was doing 55 miles an hour down the highway and bent the frame on my truck totaled my truck out so hopefully that engine I can put in the F-150 but right now I got to have this Toyota going cuz I've already almost rebuilt this truck and I need to transportation the basically all I need to know is what gas cuz I need to get cuz I've already got the timing chain ordered and is it necessary to have to remove the head
  7. Jul 14, 2021 at 2:31 PM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Check out lceperformance.com they got kits n will help you out with any questions.
  8. Jul 14, 2021 at 3:12 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    If the oil has always been changed, and the motor is clean inside I bet it's like new. Mine is at 280,000. Castrol synthetic most of it's life, and it's new inside
  9. Jul 14, 2021 at 3:15 PM
    Mr Bob
    Yeah I have been changing the oil and spark plugs about every six months when I did a compression test on it about 2 years ago results came out like it was almost new I generally change the oil and plugs in my trucks every 6 months no longer than a year on the plugs because during the winter time I use 10w 30 during the summer time I use 10w 40 I live in Texas so the heat Factor
  10. Jul 14, 2021 at 3:19 PM
    Mr Bob
    Thank you for that information I checked them out and evidently you have to pull the head and pan gave me info for a gasket kit for $89 but that did not include the studs I got the gasket kit and studs for $82 rockauto.com
  11. Jul 14, 2021 at 4:26 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Strange... 3RZ taco here with 325k miles original chain, had the engine apart at 275k miles to do head gasket and re-seal oil pan and inside it looked like new. Toyota 4 cylinders are impressive!
  12. Jul 14, 2021 at 4:31 PM
    Mr Bob
    Oh I did a lot of research all over the Internet to get information I don't know about 3rz but a lot of ones I read they were talking about changing it out around 250,000 miles they recommend doing it at a hundred thousand miles one guy made the statement that if the timing chain breaks it will grenade your engine and of course the others stated that it would destroy the engine also and also I experiencing the same thing they were talking about they experienced before changing it
  13. Jul 14, 2021 at 4:36 PM
    05RedTaco
    Tony
    Scottsdale
    Yeah, the 2rz and 3rz are interference engines so if it goes out of time really bad things happen, I had a timing belt skip on my Audi and ended up with 20 bent valves...
    Did you pull the valve cover yet? If not pull the cover and inspect the chain as well as guides and go from there...
  14. Jul 14, 2021 at 4:39 PM
    Potomus Pete
    Hippy
    I don't tear into an engine unless it's absolutely needed. I don't blame you for wanting to do it. I would love to adjust my valves . That's the number one thing with our motors.
  15. Jul 14, 2021 at 4:41 PM
    05RedTaco
    Tony
    Scottsdale
    Valve adjustment is soooo easy on the 4 cylinders, unlike the 5VZ you gotta remove most of the intake to remove valve covers....
    Potomus Pete[QUOTED] likes this.
  16. Jul 14, 2021 at 4:52 PM
    Mr Bob
    No I haven't pulled the valve cover yet because I'm still having to drive it but all the symptoms that were described by others who had that problem and I can hear it slapping slightly on the housing
  17. Jul 14, 2021 at 4:55 PM
    Mr Bob
    I'm just about for sure that when I heard that clunk when I went to start it up the other day it was probably the plastic guide plus the way it's been acting afterwards and before I thought it might have been the fuel filter and or the valves but I listen to real close today and it sounds like it's slightly slapping up against the housing
  18. Jul 14, 2021 at 5:26 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    The guides wear… then the chain. Theres a million kits available. No, you don’t need to pull the head. It’s no big deal. DO NOT BUY CHEAP EBAY CRAP!!!! Very least go Napa brand. Watch YouTube. Have fun
  19. Jul 14, 2021 at 5:39 PM
    Mr Bob
    I've been watching YouTube videos on it all the parts that I have bought for it primarily from rockauto.com
  20. Jul 14, 2021 at 5:45 PM
    Rachelsdaddy
    Southern NH
    I’m not suggesting it’s necessary to buy Toyota but you get what you pay for with this stuff. Buy once, cry once. Good luck, you can doooo it!!!!
