Timing Belt Replacement: Mileage or Time?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rocketeer928, Sep 24, 2009.
  1. Sep 24, 2009 at 7:04 PM
    rocketeer928
    rocketeer928 [OP] Member
    Western Connecticut
    2003 Tacoma SR5 V6 4WD
    Truxedo cover, Fog lamps, Hitch
    I have a 2003 V6 TRD X-tra cab Tacoma that is pretty much my third vehicle. While living in Germany for a year in 2007, I had my truck properly stored. As a result, my truck only has 17,500 miles on it. The owner's and service manual indicate to change the timing belt at 90,000 miles or 6-7 years (can't remember which), whichever comes first.
    Do I really need to heed the time recommendation and consider changing the timing belts, water pump, etc in 2010, or can I wait longer? I did read in another thread that one should change the timing belt at no longer than the 10 year point, no matter the mileage.
  2. Sep 24, 2009 at 7:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes. You need to heed the owners manual.
  3. Sep 24, 2009 at 7:37 PM
    PhatTaco
    PhatTaco Well-Known Member
    Jerry
    Georgia
    07 PreRunner SR5
    Backup camera, wheel locks, locking gas cap, tailgate anti-theft device (hose clamp).
    Yes you need to do as the owner’s manual says. I don’t know if your engine is an “interference” engine but this is where the valves and pistons will collide in the combustion chamber if the belt breaks. Obviously a very catastrophic and expen$ive event. If the engine is non-interference then the worst that can happen is you will be stranded at the most inconvenient time at the most remote location. You will now have the added cost of towing and still have to have the timing belt and water pump changed but not at a time of your choosing. Not worth trying to stretch it.
    TACOTU3 likes this.
  4. Sep 24, 2009 at 10:17 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The factory recommendation for timing belt replacement on a 5VZ is 90,000 miles or 9 years (108 months).
    The 5VZ is a non-interference engine.
    tacojim02 likes this.
  5. Sep 25, 2009 at 3:45 AM
    rocketeer928
    Western Connecticut
    9 years is more palatable.
    ExOkie likes this.
  6. Sep 25, 2009 at 4:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    This about sums it up nicely.
  7. Oct 9, 2009 at 5:57 PM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    bump
    id like to get a little more input on this thread before i make any decisions
  8. Oct 9, 2009 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What more do you need?
  9. Oct 9, 2009 at 6:01 PM
    tacotopher
    Memphis
    Zombie TRD OR
    Just lookin to see if anyone has done this on their own?
    Also what else would you recommend changing while replacing the belt?
  10. Oct 9, 2009 at 6:17 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    ExOkie likes this.
  11. Oct 9, 2009 at 6:19 PM
    tacotopher
    Memphis
    Zombie TRD OR
    awesome. id love to change it myself, just real hard finding the time
  12. Oct 9, 2009 at 6:25 PM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    Also might as well change the AC belt, PS belt, Alt belt. I have no real insight on doing this with the engine in the truck, because I did it on a engine out of the truck since I am doing a 3.4 swap in my 89. It was straight forward though probably take a full saturday to get it done.
    Your gonna need make a SST tool to get the crank pulley off. And be sure to torque everything back to OEM spec.
    Just do a quick google search and you'll find everything you'll need to know.
  13. Oct 9, 2009 at 6:27 PM
    tacotopher
    Memphis
    Zombie TRD OR
    Thanks for getting me on the right path. Google has answers to everything...
  14. Oct 9, 2009 at 10:46 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    So even though his truck only has 17500 miles on it, you're saying to change the timing belt because of the time it's been on the truck? Does the material the belt is made of simply degrade over time and need replacing, regardless of the mileage?
  15. Oct 10, 2009 at 6:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its a rubber belt....Much like tires. Yes, the belt can degrade over time.
    2002Tacoma4x4 likes this.
  16. Oct 10, 2009 at 6:37 AM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Yea, thats something Ive been meaning to do. I think Id like to try and attempt it myself. Does anyone have the Toyota Service Manual regarding this?
  17. Oct 10, 2009 at 7:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    . :) (there are 3 seperate ones to help ya)
  18. Oct 10, 2009 at 8:08 AM
    bawilson21
    Bryan
    WA
    Chris.... Thank you. Once again, you've proven to be awesome!
  19. Oct 10, 2009 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help. :)
  20. Oct 10, 2009 at 10:12 PM
    tacotopher
    Memphis
    Zombie TRD OR
    I just read thru that manual. NO way in hell i could do that with my knowledge!
