Time To Rotate My Tires, But Which Rotation Pattern To Do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by File IFR, Jan 26, 2014.
  1. Jan 26, 2014 at 7:02 AM
    File IFR
    File IFR [OP] "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Guys, I've checked tire websites for proper rotation swap... front to back or criss-crossed. I read that directional tires cannot be criss-crossed.
    How do I know I have directional tires and what pattern do you go with if non-directional?
    Tires are the stock ones (Sport TRD).
    Thanks for any tips :)
  2. Jan 26, 2014 at 7:06 AM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    Front to back and back to front,no need to cross rotate...
    eherlihy likes this.
  3. Jan 26, 2014 at 7:09 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Rear right goes to front right. Rear left to front left. Front right to rear left. Front left to rear right. Tires will say if they're directional. If they are keep the 2 sides the same. Driver side front goes to driver side rear. Same for passenger.
    Cross rotating will give a more even wear on the tire.
  4. Jan 26, 2014 at 7:22 AM
    dxpsman
    dxpsman Well-Known Member
    Brandon
    Oceanside, CA
    14 TRD Sport PreRunner
    AFE MACH Force-Xp 3" Cat-Back Stainless Steel Exhaust System w/Black Tips, Complete OME 3" lift, debadged, Body Armor 4x4 side steps.
    Your stock tires are non-directional. It is incredibly uncommon for SUV/Truck tires to be directional, so anything you purchase is likely going to be non-directional. Tires marked "Rotation" with an arrow pointing one way or another are directional. The tread will also look like an arrow, like this:
    With that said, the ideal rotation pattern is to bring the rears straight forward, and cross the fronts to the rear (for rear and 4WD). This ensures each tire hits every corner of the vehicle throughout the life of the tires.
  5. Jan 26, 2014 at 7:26 AM
    RTD
    RTD Well-Known Member
    Taxachusetts
  6. Jan 26, 2014 at 7:45 AM
    File IFR
    Central MA
    I just went out to the garage and looked, they're 17" Bridgestone Duellers.
    I noticed no rotation arrow/indication on the sidewalls and the tread pattern doesn't appear directional like the picture.
    It's 12*F in the garage :mad:. I just turned the heat on, so I'll get out there in an hour and do the swap. Since they're non-directional, I'll diagonally cross the tires.
    Thanks for the replies guys, you all rock. :D :cheers:
  7. Jan 26, 2014 at 8:12 AM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    The owner's manual for my '14 says to rotate tires front to rear and I haven't known a tire shop since bias ply tires that recommended cross-rotation (and that's a long time).
    jpmorrisvb likes this.
  8. Jan 26, 2014 at 8:22 AM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    ^^^^ This
  9. Jan 26, 2014 at 8:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On my 4x4's, I always move the fronts to the rear, and cross the rears to the fronts.
    NmapFE likes this.
  10. Jan 26, 2014 at 8:39 AM
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    2019 TRD Double cab, Long box
    Roof Rack, Step Bars, 3” Rough Country lift 265/70/17 Goodyear DuraTracs
    i agree
  11. Jan 26, 2014 at 12:01 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I always do it front to back / back to front. I never cross sides. Rotate every 5,000 Miles.
    10thMTNgrunt, eherlihy and jpmorrisvb like this.
  12. Jan 26, 2014 at 1:34 PM
    File IFR
    Central MA
    I checked the book (imagine that ;)) like I should have. It says to go front to back.
    I still like the idea or cross pattern for even wear, even if it makes a small difference.
  13. Jan 26, 2014 at 4:36 PM
    SSG665
    Georgia
    18 Tacoma
    Go by the book..
    3Riverz88 likes this.
  14. Jan 26, 2014 at 4:44 PM
    2ndchancetoyotas
    2ndchancetoyotas Well-Known Member
    Greg
    AZ
    Rebuilt
    When i worked at the stealership, the standard was front to back. Normally never had any issues. This included SUV's both 2 and 4wd.
  15. Jan 26, 2014 at 10:30 PM
    RdRunr
    RdRunr Well-Known Member
    Dan
    still in the Matrix
    2014 Base, white, reg cab, 2.7L, 5-spd
    DT header, Flowmaster 50 Series Delta Flow muffler
    Wasn't there something about a tire's belts or plys getting used to rolling in one direction and it's not good to rotate from one side to another? Or is that no longer (or never was) valid?
  16. Jan 26, 2014 at 10:44 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Done it this way with all of my vehicles, except for the ones with directional tires, and have had excellent tire wear. Also it looks like the Michelin site suggests a cross rotation except for the directional.
  17. Jan 26, 2014 at 10:58 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Never was valid. Just a myth that you'd break a belt.
    If anything, that might have been the case with bias, but the myth was always about radials.
    Cross-rotation has fallen out of favor because:
    A) - More and more vehicles are equipped with directional tread
    B) - Unless you always go to the same shop, the kid doing your rotation has no idea whether the last rotation crossed back to front or front to back.
    It's an issue of "staying on script"... keeping the kids doing rotations from having to actually check to see if the tires are directional.
  18. Jan 27, 2014 at 6:52 AM
    dxpsman
    Brandon
    Oceanside, CA
    ^^Aye.
    Front to back is the easiest, and most idiot-proof method. Crossing the rears to the front or fronts to the rears is the industry standard, assuming it's done every time. This is especially effective on higher torque 2 wheel drive vehicles. Folks that keep the tires on one side wonder why their tires cup/wear more on the power wheel side than the other.
  19. Jan 27, 2014 at 6:56 AM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    Cross rotate is the way to go. Especially if you have mud tires. The wear is much more even.
  20. Jan 27, 2014 at 7:18 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    Rear to front and cross fronts to rear will keep them smoother if there is any scalloping. This way they are in a different position for 4 rotations. Max life.
