Time to replace my headlight housings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sarra, Jan 19, 2025.
  1. Jan 19, 2025 at 9:00 AM
    Sarra
    Sarra [OP] Well-Known Member
    2007 TRD Off Road 4.0 6MT
    None yet
    Yes. I have a 2007 Off Road with the factory headlight housings, still.
    I followed the sticky thread, and found the 2009-2015 headlight housings available for sale still, but I have some questions.
    I understand the bulb changes, and since the connectors are keyed to the bulb, which adapter harness do I need?
    Do the new housings come loaded, or do I need to purchase bulbs, as well?
  2. Jan 19, 2025 at 9:17 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Keep in mind headlamps from a 2012-2015 won't directly fit your 2007.
    Naveronski and lowmower like this.
  3. Jan 19, 2025 at 2:21 PM
    bananaboat
    bananaboat Well-Known Member
    I recently replaced mine, in a 2006. I ordered these from Amazon, which are only the housings, no bulbs or wiring. The fit was perfect and the quality seems good, although they've only been on for a couple months so time will tell. I applied silicone caulk to the joint between the clear lens and the black housing.
    https://www.amazon.com/dp/B07DDFCP19?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    I also replaced the bulbs even though I think they were fine:
    https://www.amazon.com/dp/B099GSB3ZC?ref=ppx_yo2ov_dt_b_fed_asin_title
    I didn't replace any wiring. I'm quite happy with the result, much more light on the road. Whole thing cost about $150, although it looks like the price has come down since then.
  4. Jan 19, 2025 at 2:34 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    If you buy the OEM headlamps from Toyota, yes, they come with new H4 bulbs.
    But as @replica9000 noted, the headlamps from a later Gen 2½ truck will not fit an earlier Gen 2 without a number of not-insignificant mods.
  5. Jan 19, 2025 at 3:12 PM
    Sarra
    None yet
    I got that, thank you. I did find replacement headlight housings for the 2005-2011 trucks, I was hoping for an option that would eliminate the DRL. Is there an alternative that will fit, or should I just get the OE style housing and use an alternative method to disable the DRL?
  6. Jan 19, 2025 at 7:01 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  7. Jan 19, 2025 at 7:12 PM
    replica9000
    2019 T4R ORP
    My 2008 didn't have DRLs, so I'm not sure what methods would disabled them. It could be as simple as pulling a fuse if you're lucky. Are your DRLs the amber turn signals or the highbeams (dimmed)? If you want to disable them because of the melting issue, Toyota fixed that issue. The part numbers below should be the updated assemblies.
    OEM headlamps will be the best quality, but not the cheapest option. Some dealers offer good online discounts though.
    Chrome R 81110-04163
    Chrome L 81150-04163
    Smoked R 81110-04173
    Smoked L 81150-04173
  8. Jan 21, 2025 at 9:37 AM
    Sarra
    None yet
    I think I'm going to just get the stock all clear replacements.
    I'm going to depin the DRL wire, since that's reversible and doesn't violate the wiring itself.
  9. Jan 21, 2025 at 10:05 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Are you replacing the housings because they are yellowed? Id suggest you try the Cerakote brand headlight restoration kit... I have had GREAT luck with that 17dollar kit to bring back to life yellowed headlights.
  10. Jan 21, 2025 at 12:50 PM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    I tried several approaches to restore my headlights. Magic Eraser (worked well for a while) and paste wax, Mcguire's kit, finally sanding and painting with clearcoat. Nothing worked for over a year.
    I finally broke down and bought new OEM headlights from Serra Toyota for ~$360 for the pair in May of 2023.
    Since I installed the new headlights, I make every effort to park with the headlights in the shade.
  11. Jan 21, 2025 at 2:27 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 07 does not have DRL. I polished my housings several times and it made a huge difference each time. But 3 years ago they were just too far gone. I looked at a lot of cheaper aftermarket options but finally decided to go with factory replacements. The local dealer wanted $750 for a set. Online directly from Toyota was $700.
    On a hunch I asked my BIL, who owns a local body shop, what he could get them for through his commercial account. The local Toyota dealership delivered them to his shop for $500 and I paid him $500.
    They came with new bulbs and were relatively easy to install.
  12. Jan 21, 2025 at 3:06 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  13. Jan 21, 2025 at 10:05 PM
    Sarra
    None yet
    Okay, my bad for not being completely transparent on this.
    I'm replacing the housings because they're literally fire risks. They are melted, bad, where the turn signal/DRL is. The turn signals light up when the parking brake is release, they ARE DRL's.
    I know there WAS a recall for this, but the previous owner never did the recall, so now I have to purchase replacement housings.
    I know how to polish housings, that's when I realized how absolutely terrible those housings have burned up. It actually appears as if there was a small fire in one of them, at least once, in the past.
  14. Jan 22, 2025 at 5:01 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    No need to worry about the DRLs doing it again - the headlights have been updated to fix that problem. It was an issue with the lenses, not the electricals in the truck.
  15. Jan 22, 2025 at 6:04 AM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
    I bough some cheap Ebay ones for around $60, so far they've held up well. I sealed up the back of the housings with some black RTV and called it good. I've seen a little bit of moisture after washing my truck in a heated bay then parking it outside in the cold, but nothing during regular driving. We'll see how they do next summer but I could buy 10 pairs of the headlights for the cost of OEMs so its a no-brainer for me.
  16. Jan 22, 2025 at 7:33 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I've been here for a couple of years :rolleyes: and read most of the headlight threads since I've had to polish mine a couple of times- my opinion, based on all of the posts I've seen, just bite the bullet and buy OEM lights. The factory headlights in good condition are very good (other than the fading issue) and mine have never leaked or gotten condensation in them. Good headlights really are an important piece of safety equipment and, at least in my opinion, both personal and professional, are worth the money.
    If you don't need them immediately, watch for the online dealers to have sales and shop around and you can find them for much better prices. The folks here are really good about posting deals so I bought a pair of the smoked OEM lenses last time someone posted about SE Toyotas having, IIRC, 25% off. I still need to install them, I've got an ARB bumper so not sure how much of a PITA it's going to be, but it's on my short list. I picked up new clips as well since they're essentially single use, especially with the age of my truck. Double check your wiring and make sure the previous owner didn't change fuses to keep them working; it's amazing how often people will insert a higher amperage fuse instead of solving an electrical problem.
  17. Jan 22, 2025 at 8:51 AM
    eherlihy
    Go here, and supply your own bulbs. You can get both OEM Toyota Headlight Housings for <$350
    https://autoparts.serratoyota.com/
    These are the housings for 2005-2011 Tacomas
  18. Jan 22, 2025 at 9:03 AM
    4xdog
    Santa Fe, NM
    On my 2015 / Gen 2.5, it was a big PITA. On the late Gen 2s have a different ARB bullbar and that bar had to come off to change the headlamps.
  19. Jan 22, 2025 at 9:11 AM
    Sarra
    None yet
    I am not worried about them burning up on the new ones, I just don't want the DRL's. I've disabled them on every vehicle I own that had them, and will continue to do so.
    My plan is to get new housings from Toyota, apply a UV protective film, then install them. I'd rather reapply a UV protective layer every other summer, than have to buff and buff and buff them.
    I have a 2007. There's no bullbar. I'm not really worried about it.
  20. Jan 22, 2025 at 11:54 AM
    bananaboat
    Plus $100 shipping. At least when I priced them out.
