Time to replace lower ball joints?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MamaTried81, Sep 16, 2019.
  1. Sep 16, 2019 at 10:12 AM
    MamaTried81
    MamaTried81 [OP] Well-Known Member
    Oakland, CA
    '02 TRD Tacoma 4x4 V6 XtraCab SR5
    I noticed my LBJs are weeping grease lately. I haven't detected any noises or issues, just this grease. Truck has 111k miles and these are likely the original stock ball joints. I drive it 5 miles each way to work, but I also do a fair amount of off-road driving.
    Is the grease seepage normal? Or a sign to replace them, and if so, urgently or can it wait a week or two? I have a trip planned this weekend, cousin flying in from the other side of the country.
  2. Sep 16, 2019 at 10:13 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Not normal, time to replace. They are sealed and can't be greased.
    G59, GQ7227 and MamaTried81[OP] like this.
  3. Sep 16, 2019 at 10:13 AM
    1DVS-BSTD
    1DVS-BSTD is probably confused
    The Corn Is Pretty Good Here
    '03 TRD Off-Road, '22 Poverty Spec
    881's, Nitrochargers, Dakars, SR8's, Duratracs
    Never a bad idea to replace the ball joints on these trucks. Common fail item. Easy enough to replace and not too expensive if I recall. I’d change them.
    MamaTried81[OP] likes this.
  4. Sep 16, 2019 at 10:20 AM
    eon_blue
    Azusa, CA
    The grease coming out heavily like that is enough to warrant replacing them but it's also a good idea to check them for play like so
    https://www.youtube.com/embed/tqw85L_sMgE
    Any up/down movement in the joint that you can see means you need to replace them. There's a tiny bit of play Toyota says is normal but you need a special tool to measure it
  5. Sep 16, 2019 at 10:22 AM
    MamaTried81
    Oakland, CA
    Do you think they can make a 600 mile trip (mostly road, maybe 30 miles off-road)?
    I just don't know if I can get the ball joints quickly enough to change them before 3am rollout on Friday. Local dealer usually doesn't have 1st gen stuff in stock, but I'll give a call over there.
  6. Sep 16, 2019 at 10:26 AM
    eon_blue
    Azusa, CA
    I would check them for play before determining that
    They're easy to do, if you can source them before Friday I would make it a priority to change them out for the peace of mind if it were me.
  7. Sep 16, 2019 at 10:28 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just replace them; doesn't take long.
    You'll want new bolts that secure the LBJ as well. Cotter pins can be had at any auto parts store.
    GQ7227 likes this.
  8. Sep 16, 2019 at 10:30 AM
    MamaTried81
    Oakland, CA
    I'm going to buy OEM Toyota parts, from what I've read they include the castle nut and cotter pin right?
    Any idea on specs or part numbers for the bolts?
    CS_AR likes this.
  9. Sep 16, 2019 at 10:31 AM
    eon_blue
    Azusa, CA
    yeah should come with them if I remember right.
    If you're closest dealer doesn't have them in stock, ask them to check who does. That's how I got mine, had to drive about 30 min to another dealer but they had what I needed
  10. Sep 16, 2019 at 10:49 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    My OEMs came with castle nuts, cotter pins, and the 4 bolts for mounting to the knuckle. I didn't think they came with the bolts so I ordered extra. Now I have 8 extra mounting bolts that I'll most likely never use.
  11. Sep 16, 2019 at 10:57 AM
    MamaTried81
    Oakland, CA
    Good to know! If mine don't come with bolts, maybe I'll buy yours if you don't plan on keeping them?
    Also, I just jacked the truck up and used the pry bar to test for vertical play -- NONE whatsoever. I think I'm good to order parts online and save myself nearly $200. Slightly annoying that parts cost more at my local dealers than they do at other dealers, but whatever.
    I noticed the weeping of grease after driving through the Carson river a couple of times on a trip about a month ago. I just assumed the river had something to do with it, as it was deep enough to reach the top edge of the front bumper. In any case, thanks for the guidance yall!
    GQ7227 likes this.
  12. Sep 16, 2019 at 11:06 AM
    MamaTried81
    Oakland, CA
    Should I go ahead and do the upper ball joints as well? They're much cheaper.
    CS_AR likes this.
  13. Sep 16, 2019 at 11:07 AM
    eon_blue
    Azusa, CA
    Most times dealerships will match the price of online parts especially if the online price is from another dealership. They mark them way up to make as much $$ as possible but at the end of the day they want to make a sale. That's been my experience with ours here in SoCal. Just print out the online estimate and show it to them, worst they'll say is no
  14. Sep 16, 2019 at 11:09 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Make sure you buy Genuine Toyota Parts. You can pay for expedited shipping if you want 2-day delivery.
    I wouldn't bother with the upper ball joints at this time because they don't seem to cause problems.
    Oh, and don't forget :gossip: , the front end needs to be realigned after you replace them. I sure wouldn't drive 600 miles without an alignment, nor would I drive a mile with leaky ball joints.
  15. Sep 16, 2019 at 11:10 AM
    CS_AR
    I did.. It rides better. Removed the harshness from worn suspension components.
  16. Sep 16, 2019 at 11:23 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Like others said its probably a good idea to do both, but probably not needed before your trip. I wouldnt drive 600 miles on the lbjs though
    Every time I order parts from the dealership near me they have it the next day. Id just call your closest dealer and get em from them. My dealer will not match internet pricing, but Ive now gone there enough they throw me a discount when I ask for it.
  17. Sep 16, 2019 at 11:38 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Generally, the rule of thumb is never do any major work right before a trip. However, if you can swing it, I'd replace the lowers.
    For the lowers, go buy yourself a pitman arm puller from harbor freight or some other auto parts store. That's the only special tool you need to replace the lowers. The 4 bolts have a deceptively low torque spec too, 59 ft lbs iirc, so if you have a torque wrench, use it. If not, the German "goodentight" works in a pinch. Don't remember the torque spec on the castle nuts, but once you reach the proper torque, you'll want to over tighten them if you need to line up the cotter pin, don't loosen the nut to install the cotter pin.
    Quite honestly, if you REALLY need parts asap, I wouldn't be afraid to go with auto parts store parts, at least to get you rolling on your trip. If you can't find local source for the OEM, go to AutoZone and pick some up. I'm no fan of the cheap parts store brands, but will easily last you thru your 600 mile trip. They don't instantly explode when they touch your truck.
    When all said and done, it should take you maybe 30 minutes per side for the lowers, assuming you don't struggle with rusty bolts. Just jack it up, support the frame, remove wheels and lower shock bolts, and pop the 2 castle nuts free, then the 4 bolts. I'm in the camp that if you replace apples for apples, (oem for oem) you shouldn't need an alignment, but if you have the time, you may as well get one.
    Since you're in a time crunch, I'd leave the uppers for later, they aren't the problem child. Uppers are easier(ish) as long as you rent the proper ball joint press. Most auto parts stores rent them for free.
    Prayn4surf and MamaTried81[OP] like this.
  18. Sep 16, 2019 at 11:42 AM
    MamaTried81
    Oakland, CA
    Definitely bought OEM Toyota parts. And yeah, I bought a 3-year unlimited alignment--we're on a first name basis over there lol
    Upper ball joints are leaking too, fyi. I just didn't post a pic because they aren't leaking nearly as bad.
  19. Sep 16, 2019 at 11:45 AM
    jbrandt
    Justin
    For the uppers, it's really up to you and if 1) you can get your parts in time, and 2) if it'll keep you up at night. Like I said, the uppers aren't known for failing like the lowers are, but if you have the right tools, it shouldn't take too long to do.
  20. Sep 16, 2019 at 11:52 AM
    CS_AR
    I borrowed the heavy duty ball joint press kit from Advance Auto for the uppers. The smaller kits didn't have enough reach.
