Time to get brakes done for the first time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zooyorkajd, Jul 12, 2022.
  1. Jul 12, 2022 at 10:38 AM
    zooyorkajd
    zooyorkajd [OP] Well-Known Member
    Truck is at 45k miles. I am asking the community what are your thoughts on resurfacing the rotors. Should I get new rotors or get the currents ones resurfaced?
    A quick background of the truck. This will be its first brake job. The current pads are at 3mm so I know it’s time. The rotors seem to be in good shape but do have grooves.
  2. Jul 12, 2022 at 10:39 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Resurface rotors, new pads, bleed brakes = Gucci
    Tacospike and zooyorkajd[OP] like this.
  3. Jul 12, 2022 at 10:39 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    For the small price difference I would go new.
    Delta09 likes this.
  4. Jul 12, 2022 at 10:43 AM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I would resurface if they meet the specs, otherwise replace them. No need to toss perfectly good rotors.
  5. Jul 12, 2022 at 10:44 AM
    sirsaechao
    Tim
    CA
    Or this but keep the stock and have them turned so you have a set to swap each time so you don't need to wait for them to get turned.
    TacoJoe480 likes this.
  6. Jul 12, 2022 at 10:48 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have no vibrations, you can just swap out the pads. My oem rotors were replaced at about 70K with EBC rotors. At about 130K, I had my oem rotors resurfaced and reinstalled them. I’m coming up to 200K and can feel some out-of-true vibrations from the rotors. Will try to get the EBC rotors resurfaced.
    eurowner likes this.
  7. Jul 12, 2022 at 10:50 AM
    Tacospike
    Two Trucks
    I have this on my list of things to do.
    I have pads in the garage already, I'm just going to resurface rotors and replace the pads. I think the pads were $40-$50 at auto zone. I want to say I got duralast gold class? Been a few months since I bought them.
    pahaf likes this.
  8. Jul 12, 2022 at 10:51 AM
    CPax
    CPax Well-Known Member
    A lot of the time (in my experience) resurfacing rotors almost as expensive as buying brand new ones. Just something to consider.
    pahaf likes this.
  9. Jul 12, 2022 at 10:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    45k seems pretty low mileage
    Heavy stop and go miles? Heavy loads? Mountains?
    Hopefully not one of the drivers who treat the brakes as a off/on switch.
    Price the rotor turning to the cost of new. The difference could be minimal.
    Either way, be sure to follow a proper bedding procedure.
    shakerhood likes this.
  10. Jul 12, 2022 at 11:06 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
  11. Jul 12, 2022 at 11:16 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    When I do brakes and I feel I need rotors I buy new. Just swapping pads is a good choice if they weren’t worn and distorted the rotors. If I have any grooves I swap rotors and pads.
  12. Jul 12, 2022 at 11:19 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    New brake rotors are $50-ish from Toyota. But good luck getting them. Last time I checked, they were sold out everywhere
  13. Jul 12, 2022 at 11:26 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    New rotors have gotten insanely expensive so if someone still knows what they're doing in turning them, that may be a more economical option. I've always tried to get new ones and shopped around but it's crazy how much they've gone up in price. Definitely don't need to stay OEM if you don't want to but also don't go for the cheapest option.
  14. Jul 12, 2022 at 11:32 AM
    pahaf
    paul
    NorCal
    Napa resurfaced my rotors for $18 each.
  15. Jul 12, 2022 at 11:32 AM
    fourfourone
    Rock auto has a few good quality options for around the $60 dollar mark.
    Smacky2020[QUOTED] likes this.
  16. Jul 12, 2022 at 11:38 AM
    Smacky2020
    Bristol, VA
    The shipping always kills it for me. I wish I lived close to one of their warehouses for some of the bigger/heavier things like brakes and suspension parts
  17. Jul 12, 2022 at 11:40 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Resurfacing rotors that are already flat is kind of pointless. While it does give you a clean surface to start from, you will glaze and groove them in the first couple of hundred miles. Cutting them makes them thinner and more susceptible to warping. I would leave them alone.
    Clearwater Bill likes this.
  18. Jul 12, 2022 at 11:40 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I just put all new brakes on the second gen, which are the same as a 3rd gen. I went with Raybesto's Element 3 Hybrid pads and Element 3 coated rotors. I've had very good luck with them. After bedding in they have really good bite. Here's all the part numbers (ignore the caliper numbers, doubt you need those...)
    Rotors are $38 a piece and the pads were $26. Biggest thing is to properly clean and lubricate pad mating surfaces and pins.
    With the price of rotors now I never bother resurfacing them.
    Also please ignore the post that are basically telling you to pad slap it...
    RustyGreen likes this.
  19. Jul 12, 2022 at 11:43 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Totally!
    Make sure to spray the rotors clean on both sides with brake cleaner before you install the new pads.
  20. Jul 12, 2022 at 12:58 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
