Time to do valve cover gaskets....
Discussion in '1st Gen. Tacomas (1995-2004)' started by mystik cabs, May 2, 2020.
  1. May 2, 2020 at 12:37 PM
    mystik cabs
    mystik cabs [OP] Well-Known Member
    Brian
    North Stonington, CT
    '04 TRD DBL Cab
    ...since the passenger side cover is leaking enough..is there a complete parts list or a kit that will supply everything needed to pull it apart and get it all back together. I assume OEM is the way to go, maybe Camelback for the best deal?
  2. May 2, 2020 at 12:39 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
  3. May 2, 2020 at 12:41 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    cover gaskets, spark plug tube gaskets, bolt grommets, and spark plugs should be about all you'll need
    https://www.youtube.com/watch?v=N5fAXAuGozI
    Edit: Be VERY gentle with the plastic fuel rails. They will break. The goal is to limit the amount of breakage that occurs. Mine stayed mostly in tact with the exception of the tabs that have the holes in them for the bolts.
  4. May 2, 2020 at 5:38 PM
    E4x4D
    E4x4D Member
    E
    2002 Tacoma 4x4
    Video in the post above helped me a lot. Check the sticky as well. I used all OEM parts. It took me about 2 days taking my time.
    Kolter45 and otis24 like this.
  5. May 2, 2020 at 10:39 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    The bolts are proabably just really loose (it has happened to me on 2 different 3.4l) you can reach most of them with extensions and swivels, just tighten them down gently and your leak will probably go away.
  6. May 3, 2020 at 4:44 AM
    mystik cabs
    Brian
    '04 TRD DBL Cab
    I've already tightened the vc bolts because they were loose. That got me a year a so of slowing down the leak. I did plugs and wires about 25K ago so they should be good still. Really was looking for Toyota part numbers so i can order the parts..
    koco and GQ7227 like this.
  7. May 3, 2020 at 7:14 AM
    koco
    Bay Area Ca.
    '01 Taco
    The video from Timmy the Toolman has it all. The spark plug hole grommets take a while to knock out and replace, so set aside enough time for that.
  8. May 3, 2020 at 7:41 AM
    Bend_corners
    Bend_corners Well-Known Member
    Jim
    USA
    1995.5 5vzfe medium quartz Xtracab
    Also doing this right now- as stated above Tim's video has all of the relevant information. Be ready to spend some time working the spark plug gaskets out, as mine were brittle AF. Also, if the plastic above your valve covers is in bad shape, you can fix it using this solution or another like it. It made removal of the valve covers super easy for me. https://www.tacomaworld.com/threads/idea-for-brittle-plastic-wiring-harness.662176/
  9. May 3, 2020 at 9:58 AM
    MatthewMay1
    Matthew
    Lone Star Republic
    All the OEM part numbers should be in the video I posted above.
  10. May 29, 2020 at 5:38 PM
    mystik cabs
    Brian
    '04 TRD DBL Cab
    Thanks for that Matt, it'll be very helpful!
  11. May 31, 2020 at 6:42 PM
    1997tacomav6
    Denver
    Be careful pulling the half moons, if you go back and forth the edges will break off easily.
    Pull straight up only!!!
    Good thing is the half moons only cost 10.00 new from Toyota
    Also if you have a dremel with a wire brush and cable extension that will make short work of cleaning the gasket material on the engine and the parts.
