Time for new brakes ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mallcrawler20, Oct 4, 2023.
  1. Oct 4, 2023 at 9:49 AM
    Mallcrawler20
    Mallcrawler20 [OP] Well-Known Member
    Trd off-road 4x4 Manual
    So had recent service done at dealership . Was advised that the front brakes need to be replaced at 44k miles . Was told they are between 4-6 mm . Are they pulling my chain or should I replace them . Also is 349. 95 a good price for them to replace or should I use brake masters or something like that . I know a lot of you guys are like do it yourself but I’m not very confident in brake jobs . Thanks guys .
  2. Oct 4, 2023 at 9:52 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Their trying to take your money. You got about 50% life left in those pads.
    You dont dump a half drank beer to get a new one, why would you throw out half worn brakes.
  3. Oct 4, 2023 at 9:54 AM
    Mallcrawler20
    K cool ty was wondering if they are taking me for a ride .
  4. Oct 4, 2023 at 10:13 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    4mm left is actually kind of low. Closer to about 20%ish pad life left meaning OP should think about doing them sooner than later.
    ToyoTaco25 likes this.
  5. Oct 4, 2023 at 10:16 AM
    5nahalf
    Erik
    Minnesota
    new is around 11mm, so 4mm being around 35% 6mm being around 55%.
    If we take the low side at 4mm, then they are getting about 6200 miles per mm of brake pad. So at 4mm they can still go 25k miles till the pads are gone. If we leave 2mm left, then they still have 12k miles left on those pads.
    High side of 6mm means they are using 1mm per 8800 miles, so they have roughly 52k miles until the pads are done, 2mm remaining we have 35k miles remaining.
    As a second point, the dealer saying "4-6mm" is pretty shitty practice. They can measure them without removing anything (they have brake pad thickness gauges that you just put next to the pad), but they are choosing a vague number range to give the illusion you need to replace them soon.
    Most brake measurement devices list 4-6mm as "moderate" wear, as in right in the middle of new and needing to be replaced.
  6. Oct 4, 2023 at 10:19 AM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    If you watch a YouTube on how to do the front brakes, you may see that it actually is very simple and something you can do yourself.
    02Duck likes this.
  7. Oct 4, 2023 at 10:32 AM
    Mallcrawler20
    So I looked at my paperwork again shows
    6mm in the front and 4 mm in the rear . But they said the front needed replaced . Something is not right …if the rear is less than the front wouldn’t the rear need replaced . The rear shouldn’t wear faster than the front . I think I need to get another opinion on the brakes .
  8. Oct 4, 2023 at 10:35 AM
    fourfourone
    You have rear drums and shoes. The brake material is a lot less thick.
  9. Oct 4, 2023 at 10:35 AM
    5nahalf
    Erik
    Minnesota
    Rear are drums, they start out at 5mm, so you have used 1mm.
    Either way they are just trying to get your money on the front brakes. They are fine for along time.
  10. Oct 4, 2023 at 10:39 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Good info here, as I'm at around 42k and wondering how long these pads last. I have a healthy 5-6mm left, as well.
    I don't get excited unless I hear metal on metal scraping. lol
  11. Oct 4, 2023 at 10:47 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Is the $349.95 price for pads and rotors?
    I changed my pads and rotors at 40K miles because I had a vibration. Still a good amount of pads left, so I would recommend doing both pads and rotors when you feel it is time.
  12. Oct 4, 2023 at 10:53 AM
    5nahalf
    Erik
    Minnesota
    This is a interesting question, as the parts from toyota should come in right around $300 (from a quick online search). Might be a pad slap, or it might be a "sale" item that they then upsell you on brake flush, caliper replacements, wheel bearings or any number of thing that they "found" while in there.
    Chew likes this.
  13. Oct 4, 2023 at 10:56 AM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I have not had anyone, including myself, look at or measure my rotors or pads yet. I have 94K miles on the truck, still on the original pads and rotors. No known issues with the brakes, though they do seem to be getting a little bit soft lately. I plan to take the truck in at ~100K miles for some key service (brake check, fan belt replacement, spark plug replacement, coolant replacement...)
    MGMDesertTaco likes this.
  14. Oct 4, 2023 at 11:04 AM
    TA2016
    Oregon
    I have never measured my pads or rotors. Just eyeball the pads when I rotate tires. I try to do my brakes sooner than later. If I were to wait too long I am changing rotors with the pads anyway.
    Don't be afraid of doing your brakes. Watch a good YouTube video and work slow. I went with PowerStop because my OEM brakes developed a vibration at 40K miles.
    https://www.amazon.com/dp/B005FKS28C?ie=UTF8
  15. Oct 4, 2023 at 11:07 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Usually the OEM rotors will have minimal wear if there's still pad material left and the pads wore evenly. $350 would be for pads.
    TA2016[QUOTED] likes this.
  16. Oct 4, 2023 at 11:13 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I'm at 80k on my original pads. I have never had pads last this long. Obviously pad life is dependent on driving type, but I drive the same as I did on other vehicles that I was getting 40k if I was lucky.
  17. Oct 4, 2023 at 11:14 AM
    MGMDesertTaco
    I guess it depends on your driving habits. Get a second opinion from a reputable shop.
  18. Oct 4, 2023 at 11:15 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    Majority of actual braking force is done by the front brakes. Rear drum brakes wear really slowly by comparison. My ex had a Saturn SL2 that didn't need rear brakes until almost 200k miles.
