Tighten spark plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Feb 26, 2015.
  1. Feb 26, 2015 at 5:46 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    since i dont have a torque wrench how do i go about tightening the spark plugs?
    tighten by hand without the ratchet than 1/2 or 1 full turn after with the ratchet on? let me know asap thanks
  2. Feb 26, 2015 at 5:52 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I don't think I've ever used a torque wrench on my spark plugs. Just tighten them till snug. There's a crush washer that you're trying to crush when you tighten them.
    What's the torque rating?
  3. Feb 26, 2015 at 5:56 AM
    pinktaco808
    super light like 15lbs man how you tighten yours?
  4. Feb 26, 2015 at 6:00 AM
    Pigpen
    Northwest Montana
    tighten until the washer crushes, no further. That or buy a torque wrench. The light duty lever style (non ratcheting) are pretty cheap. If you're working on your truck it's a tool you should have.
  5. Feb 26, 2015 at 6:06 AM
    pinktaco808
    how will you know since you cant see anything?
  6. Feb 26, 2015 at 6:09 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    You have to have a calibrated hand. :D
    It sounds like you need to go out and buy a torque wrench. Set it to 15ft lbs and go for it. After you've done it several times you'll figure out how tight you need them without it.
    Don't forget the anti seize.
  7. Feb 26, 2015 at 6:10 AM
    pinktaco808
    lol
  8. Feb 26, 2015 at 6:13 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Isn't it like 1/16 turn after contact for no washer plugs, and 1/8 turn for washered plugs? Verify the amount before you do, not sure if memory is correct.
  9. Feb 26, 2015 at 6:13 AM
    pinktaco808
  10. Feb 26, 2015 at 6:15 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    X2 on hand tightening them. You'll feel the the crush washer collapsed to let you know its sealed and tight.
    Torquing spark plugs is too much of a risk imo. Its very easy to over tighten especially when your working at an angle. I've changed a lot of spark plus in my short time (motorcycle/jet ski tech for years) :D
  11. Feb 26, 2015 at 6:24 AM
    pinktaco808
    soo about 1/16 turn after finger tight?
  12. Feb 26, 2015 at 6:25 AM
    pinktaco808
    06 with 100k
  13. Feb 26, 2015 at 7:32 AM
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    For those using a torque wrench - good . But , make sure to set it back to the lowest setting for storage - or it can wreck the calibration over time .
    Sarge
  14. Feb 26, 2015 at 7:45 AM
    81shark
    81shark Well-Known Member
    some plugs don't need it.
  15. Feb 26, 2015 at 7:49 AM
    Aw9d
    Aw9d That one guy
    I've never used anti-seize and never once have I ran into an issue. My race cars, motorcycles, go-peds, trucks, have always been ok without it. I just alway make sure the block is cold when I do the work.
  16. Feb 26, 2015 at 7:55 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Our plugs are gasket/crush washer style. Don't know what mm, but 1/16 turn is probably not enough. 20 years ago on aluminum heads we always did finger tight + 1/2 turn.
  17. Feb 26, 2015 at 8:41 AM
    pinktaco808
    half turn after finger tight just with the extension and spark plug socket?
  18. Feb 26, 2015 at 9:12 AM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    '22 MGM DCLB TRD OR
    I had a bit of shell shock when I found out the 30K service on my old Ram 1500 Hemi *required* the plugs changed...and there were two per cylinder...and they were only available at the dealer.
  19. Feb 26, 2015 at 11:40 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    Should be ok, you should be able to feel when the crush washer is fully compressed - if it needs more effort STOP. Figure 1/2 turn max.
  20. Feb 26, 2015 at 2:04 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Go buy yourself a torque wrench and some anti-seize.
    You'll be glad you did. It'll be something you'll have & use for a long time.
