Tight Fit - Garage Parking Aide
Discussion in '3rd Gen. Tacomas (2016-2023)' started by anonymouscuban, Jan 2, 2018.
  1. Jan 2, 2018 at 2:37 PM
    anonymouscuban
    anonymouscuban [OP] Well-Known Member
    Alex
    Porter Ranch
    2017 MGM Off Road Double Cab Shortbox
    Well... I knew it before hand but my Taco is a pretty tight fit in my garage length wise. I have a 3 car garage so width is not a problem. (*insert that's what she said zinger)
    So aside from the tennis ball on a string trick, are any of you guys using some other parking aide to get your truck parked in the garage? If so, can you share?
    Thanks.
  2. Jan 2, 2018 at 2:40 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Tight length wise? I just use the lines on the back up camera and the wall which gives me enough room to close the garage door. This truck is actually longer than the previous gen by 4-5 inches. It's that bumper underbite further worsen by putting the license plate bracket.
  3. Jan 2, 2018 at 2:44 PM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    TacoCat likes this.
  4. Jan 2, 2018 at 2:49 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I might need this. I used the wall and the back up camera lines to park the truck this past weekend but I forgot I put the plates on and the garage door didn't clear the license plate bracket.
  5. Jan 2, 2018 at 2:51 PM
    anonymouscuban
    Alex
    Porter Ranch
  6. Jan 2, 2018 at 2:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I just installed a front camera to go along with the HAI cable. Pretty freaking stellar.
    The tennis ball trick is great, as long as you always come in at the same angle. We have an odd shaped driveway, so that isn't a guarantee.
    The issue in my garage is width. What I did before the camera was get the truck right where I want it, then spray paint a line on the floor where I want the front tire to be and a lateral line where to stop.
    The paint will come up with a pressure washer if I need to.
    We also had one of these to save the car doors:
    https://www.amazon.com/Highland-9242300-Black-Vehicle-Protector/dp/B000221M94
    It could work for the bumper. Just sloooowly coast into it and back of a scosche.
    And one more:
    https://www.amazon.com/MAXSA-Right-Black-Parking-37358/dp/B000F6DNMQ/
    I have this attached to the floor with masonry screws for the Wife's car. I can't use this on the Taco's side of the garage since it is in a different spot if I use my motorcycle or not.
    EagleUSMCRet likes this.
  7. Jan 2, 2018 at 3:14 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I have literally 2" on either end to spare in my garage. I'm going to mount a convex mirror up front to let me pull up close as I can (which is right in front of our furnace).
    tonered, poopshute and urban like this.
  8. Jan 2, 2018 at 3:23 PM
    poopshute
    Colorado
    The one you linked seems to just put a dot on your dash. You'll need to know when to stop based on when the dot gets to a certain point on your dash. Right?
    The one I linked works like a stop light with a radar on it. As you get to your pre-set distance, the lights change from green to yellow to red. You can re-calibrate at any time.
    One thing to note, if you're want to mount the kit I linked to on the same wall that you need to drive up to, just keep in mind that you need a couple feet from the sensor to where your truck will stop. Meaning, you can't have a wall you need to butt up against AND have this device installed on it. It won't read it as you get closer than a couple feet to it. Hope that makes sense. Take a look at the manual (you can probably find it online) for a better explanation.
  9. Jan 2, 2018 at 3:25 PM
    Jimmyboyblue
    Jimmyboyblue Well-Known Member
    Jimmy
    Baja California
    Buy a steel rear bumper should buy you a few inches
  10. Jan 2, 2018 at 3:27 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Years ago my dad had gotten ahold of the round markers in the street. Put two in front and row behind the front tire and once you went over the hump you were good.
    tonered likes this.
  11. Jan 2, 2018 at 3:32 PM
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
  12. Jan 2, 2018 at 3:33 PM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    Guess I low tech and cheap on this one. Had a family member stop me in the right spot and then put a scrap peice of 4x4 wood post in front of the left front wheel, now I just pull in slow until the tire hits the block.
    cshrum, rtzx9r and 2005 TRD Sport like this.
  13. Jan 2, 2018 at 3:34 PM
    2005 TRD Sport
    2005 TRD Sport Well-Known Member
    NM
    17 Black LTD
    Chrome step tubes, bed extender
    I use a 4x4 under the left front tire. A buddy had this in his garage but I haven’t found one similar. 4B2AE973-CF6E-4553-9F7F-C727F3F0F1B4.jpg
    tonered likes this.
  14. Jan 2, 2018 at 3:43 PM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    I use my backup camera. Gets me inches from the wall every time
  15. Jan 2, 2018 at 3:44 PM
    Scruffie
    Scruffie Well-Known Member
    Arsie
    Surrey B.C Canada
    2016 QuickSand Access TRD OR Manual
    265/75/16Dura,SSO Hybrid,X20,CruisinSliders,Skids
    Wanted my truck backed into my garage. So.
    Fluorescent Pink spray Marking paint on floor behind truck. Backed my truck into the garage until the door just closed. Put broom handle on floor and checked my entune reverse screen. Then moved the handle until it matched up with one of the lines showing on my backup screen. Drew a fat line on the concrete floor with the pink marking spray paint. As long as I back in far enough that the mark on the floor is just past the mark showing on my camera screne. I am good to push the button on my automatic door closer. Knowing that it is not going to come down on my hood. Worked great for well over a year now.
    tonered likes this.
  16. Jan 2, 2018 at 3:51 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
  17. Jan 2, 2018 at 3:58 PM
    anonymouscuban
    Alex
    Porter Ranch
    Cool guys. Few options. I thought of just going really low tech and putting a 2x4 down on the ground with velcro. I wanted to see if there are slicker options without spending an arm and leg.
    I tried the parking stop under one tire, like the yellow and black one posted, but it hits or miss. I'm on a cul-de-sac so my driveway is oddly shaped. It's also on an incline so I lose side of the stop quite a distance from it. A wider one would work for sure.
    I like the option @poopshute posted but I need to make sure i have enough clearance from the wall I would mount it to for it work properly. I have about 18" I think. Sounds like a lot but I need to leave this much room so you can get around the front of the car to access the one side of the garage.
  18. Jan 2, 2018 at 4:02 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    i cut a scrap piece of 4x4 diagnally and caulk it to the garage floor.
    its cheap and been using it for years. i have only kicked it once with
    my big toe. :goingcrazy:
  19. Jan 2, 2018 at 4:05 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Whoa.....garages are for motorcycles. Tacomas belong in the driveway.
    cascadetaco likes this.
  20. Jan 2, 2018 at 4:08 PM
    Qwack
    Oahu
    my bikes and tacoma are in the garage, 4runner sits outside
    cshrum and tonered like this.
