Tie Rods. Symptoms / best cost replacements
Discussion in '1st Gen. Tacomas (1995-2004)' started by jspansel, Apr 24, 2015.
  1. Apr 24, 2015 at 3:22 PM
    jspansel
    jspansel [OP] Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    So I believe I need new tie rods. Inner or outer? I dont know... How can I tell?
    Driver side is hard to turn by hand. Passenger side, I can turn fairly easy by hand. Would that be inner or outer?
    I did the tack weld mod on the steering shaft and just put new Energy Susp. rack bushings in. Still have play in steering.
    Should I just replace both inner and outer on both sides and be done?
    What are good cost replacements? I have seen prices all over the board. I know moog is decent but I hear to stay away from their ball joints so I'm not sure.
    Thoughts?
    I need new tires coming up soon, so I want to get this all taken care of so I can get proper alignment before new tires.
  2. Apr 24, 2015 at 3:57 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    About all I can say, is I get the duralast ones from AutoZone. Lifetime warranty. If it goes bad just take in the old one and get a new one freeeeeeee!:) I buggered up the threads on one and they told me to bring it in to get my money back...
    Of course I would probably get some decent inners. Those are a bitch to replace. Outers tie rods as well as ball joints I use the duralast. They really aren't that bad. Unless you do a lot of wheeling or 'prerunning'. Then I'd be more cautious on what brand I'd get in that case.
  3. Apr 25, 2015 at 4:50 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    I'm a firm believer in OEM. Pay a little more but they are far superior. I put Smakei 555 outer tie rods on and they lasted 2 months before the grease boot deteriorated and started leaking grease. How many miles are them? I had over 200,000 miles on my oem tie rods. They still seemed ok but I replaced anyway for peace of mind. What's the tack weld mod?
  4. Apr 25, 2015 at 5:54 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    What do you mean by turn? Turning to adjust is the only reason to turn the the rods.
    If the end is worn, you will feel slop in the ball. The inner has a ball as well, but you need to pull back the bellow to see if it has slop.
  5. Apr 25, 2015 at 9:18 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    This goes for me as well. Outer tie rods will have some play in the ball joints and will be loose. You will have to take off the tie rods and get to the inners to check them. But the same goes for those. I replaced mine and they weren't that hard. You can use a pipe wrench if needed but I would recommend one of these. http://www.lislecorp.com/divisions/products/?product=530&division=1&category=2 It's the 42mm for our trucks I believe. That said I would start with outer. Inner ends are very heavy duty and after 120k mine were still solid as a rock. Or you can go get a huge crescent wrench that will open to 42mm. I have a 12 inch that falls just short. I was just going to do the inner only but I screwed up the threads on one and ended up doing new ones anyway. They are cheap, go OEM on the outer.
    Inner rods...
    http://tps.toyotaofdallas.com/parts/2001/Toyota/Tacoma/DLX/?siteid=214074&vehicleid=69994§ion=STEERING&group=STEERING%20GEAR%20%26%20LINKAGE&subgroup=STEERING%20GEAR%20%26%20LINKAGE&component=Inner%20tie%20rod
    outer
    http://tps.toyotaofdallas.com/parts/2001/Toyota/Tacoma/DLX/?siteid=214074&vehicleid=69994§ion=STEERING&group=STEERING%20GEAR%20%26%20LINKAGE&subgroup=STEERING%20GEAR%20%26%20LINKAGE&component=Outer%20tie%20rod
    I get all my parts here, they beat almost any dealer in price. Trust me I have three Toyota dealerships less than 15 miles away to check. I have the added benefit of them being 15 miles away. :) But they do ship, and they are AWESOME to deal with. They are the same people who do trdparts4u and are in the same building. http://trdparts4u.toyotaofdallas.com/Scripts/default.asp
  6. Apr 26, 2015 at 6:52 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I would stick with OEM for the tie rods and ball joints. I bough Moog ball joints and I got CarQuest tie rods with lifetime warranty and dont have any complaints yet. To check the outers, jack the truck up and center and lock the steering wheel. Put your hands in the 9 and 3 position and yank on them. If there is play, then they are bad. As well as check for the boot being messed up or any grease around that area
    Rebel Kittie likes this.
  7. Apr 26, 2015 at 9:15 PM
    jspansel
    Jay
    Central OR
    By turn, I mean grab the tie rod and can rotate it back and forth by hand. Driver side is hard to move but I'm able to. Passenger side is fairly easy to rotate.
    Tac weld mod... Pulling the steering column and slapping on a tac weld on the shaft and slip joint to stop slip. Search steering play weld or something like that. Lots will show up.
  8. Apr 27, 2015 at 6:01 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    ^Where exactly are you grabbing and turning? It almost sounds like backing nuts are loose....
  9. Apr 27, 2015 at 6:09 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    You can check the inner this way as well. Just replaced my inner with moog. Also while you have it jacked up its not a bad idea to put your hands at 12 and 6 and check your wheel bearings.
    OEM are definitely superior. Somewhere there is a thread talking about how the ball joints are made. Moog was metal on metal and OEM has a bushing in it I believe. This was for the lower bj's but I'd imagine any bj would be similar.
  10. Apr 27, 2015 at 7:58 AM
    jspansel
    Jay
    Central OR
    Here is a pic (NOT my truck.. just for example)
    The whole bellows boot and everything rotates together. (within the outer tie rods range of motion at the joint...) So I assume the inner is rotating as well. Should there be no motion at all?
    I know moog is bad for ball joints... im not replacing those, just tie rods. Still would not recommend them for that? What about just napa's or such? I'll have to look into it more.. I dont drive the truck but maybe 5k a year, if that.
    I have no torn or damaged boots on the outers...
  11. Apr 27, 2015 at 8:10 AM
    Lumpskie
    New Hampshire
    ^Oh, ok. So you are just rocking it back and forth, feeling for resistance. I'm not expert, but here's my take. The resistance you feel will be directly correlated with the "tightness" of the ball joint on your outer tie rod end, then. I wouldn't worry about how hard it is to move it by hand, as long as there isn't slop when you turn the wheel. Have a friend rock your steering wheel back and forth and watch to see if there is lateral deflection in the joint itself. As long as it isn't loose, you're ok.
  12. Apr 27, 2015 at 8:31 AM
    jspansel
    Jay
    Central OR
    Thanks! Yeah, it was hard to explain.. pics help. Yes, just rocking back and forth. Sounds good! I will have to try that test and grabbing the wheel test.
  13. Apr 27, 2015 at 7:07 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Some pics would help. Really I think the outers will have physical appearance of wear before anything else.
