Tie Rod Removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jesse46, Jan 15, 2022.
  1. Jan 15, 2022 at 7:53 PM
    Jesse46
    Jesse46 [OP] Well-Known Member
    Jesse
    Orange County, CA
    2017 OR DCSB 4x4
    Any advice for removing the tie rod? I began my attempt at installing my new suspension but am having a lot of trouble removing my tie rod. I would like to do it without having a pro do it but I may bight the bullet if I can't get it off.
    Thanks.
  2. Jan 15, 2022 at 8:02 PM
    jlaurence32
    jlaurence32 Well-Known Member
    Colorado
    2016 MGM TRD Sport 4x4 DCSB
    Right at the 5:00min mark is a good explanation. That's what I did to get mine off. You gotta hit it hard enough that it seems you're gonna break the casting and use a hard steel hammer not a soft dead blow. Hit straight into it, not from the side so it can bend. Hit the casting not the tie rod. You want the shock/vibration. Also leave the nut on a couple turns loose so the arm dont drop. Gotta do the same for the upper ball joint...
    Tacoma Rough Country 3" Suspension Lift w/ N3 Struts (2005-2019 Pre-Runner & 4WD) Review & Install - YouTube
    eurowner likes this.
  3. Jan 15, 2022 at 8:51 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Big f**king hammer and hit it until it pops out.
    Vegasstunts likes this.
  4. Jan 15, 2022 at 10:11 PM
    Jesse46
    Jesse
    Orange County, CA
    2017 OR DCSB 4x4
    The good news is I got it off in the strangest way possible. I hit it another 12 times after making this post and reading your guys replies. It still wouldn’t budge, so I say there for a few seconds then out my hand on the tie rod and wiggled it. It then dropped like as if it taunting me.
    bad news is that I nicked the rubber piece underneath it and it’s leaking grease every so slightly. Is this something that I should replace?
    mquibble likes this.
  5. Jan 15, 2022 at 10:15 PM
    Tacomike18
    J
    Outer tie rods are cheap, just make sure your alignment is straight
    mello03 likes this.
  6. Jan 15, 2022 at 10:40 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I use a pitman arm type puller tool.
    mello03 and TartanEagle like this.
  7. Jan 15, 2022 at 10:53 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yep.
    paid maybe 10-15 for it and it takes seconds to remove the tie rod. Have used it dozens of times. Hammer method never works for me
    TartanEagle likes this.
  8. Jan 16, 2022 at 5:08 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Nicked or cut the boot?
  9. Jan 16, 2022 at 6:21 AM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Just replace the outer tie rod with the Moog and be done with it. Make sure you measure it and your alignment should be close, but you will have to get it aligned anyway. I always put a bit of anti-seize in that tapered end and it makes it much easier in the future. I do this on UCA ball joint tapered end too. Done dozens of lifts this way.
  10. Jan 16, 2022 at 2:14 PM
    Jesse46
    Jesse
    Orange County, CA
    2017 OR DCSB 4x4
    I’m not sure, I can’t see the whole but it would leak grease as I hit it from all the vibration/rattle.
  11. Jan 16, 2022 at 2:14 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Well, if it’s leaking I’d replace the boot.
  12. Jan 16, 2022 at 2:15 PM
    Jesse46
    Jesse
    Orange County, CA
    2017 OR DCSB 4x4
    As an update. I’m onto the other side and I’m stuck once again with the lower tie rod end. I’m wacking it with limited space as I can’t turn the steering wheel. I tried some rust penetrant but haven’t got any luck yet. The upper boots came right out with 3-4 hits from the hammer.
    Edit: Got it off with a mallet.
