Tie rod end replacement suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco Diablo, Dec 12, 2017.
  1. Dec 12, 2017 at 6:59 PM
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    So... my Taco was wondering all over the road on me, and I started to notice some funky tire wear. I decided to order inner and outer tie rod ends and a steering rack bushing kit and start there to remedy the problems. (https://www.tacomaworld.com/threads/steering-rack-bushing-suggestions.523952/ )
    When I started to look at the tie rods, it was pretty clear they were at least part of my problems.
    Parts list I went with:
    Proforged Inner Tie Rod Ends
    Part #104-10495 (same part for left and right)
    TRW Outer Tie Rod Ends
    Part #JTE1320 (left)
    Part #JTE1319 (right)
    I went with the TRW Outers because they are greasable. Although I do suggest replacing the zert fittings.
    To get familiar with the process, and tools involved, I highly suggest checking out this video.
    https://youtu.be/AVQHgcXEhpE
    The video has a lot of great info, but there's a few additional tid bits I think need to be added.
    The steering rack piston is slotted for a 32mm wrench. But you can't use just any 32mm. I bought a Husky 32mm and it was too thick to fit in to the slots. You will need a wrench with a side profile of a Craftsman (had to go buy it during the repair) The Husky wrench is 14mm thick where the Craftsman is around 12mm thick.
    The wrench on the left is the Craftsman. The right is Husky.
    It's also worth mentioning, the slots on the large end of the inner tie rod are 1 5/8. I hate using adjustable wrenches (like shown in the video). I took one of the new ones to size it up at my local Napa. The new and old inner tie rods had the same sized slots.
  2. Dec 12, 2017 at 7:02 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Here is a picture of the end of the steering rack piston, where it meets the inner tie rod. The large bell on the inner tie rod is 1 5/8. The narrow slot on the piston is where the 32mm wrench needs to be 12mm thick, or less, to fit.
    TrentonTDG likes this.
  3. Dec 12, 2017 at 7:07 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    If you go with greasable outer tie rods, and install them with the zert fitting that are included, you will have this. The zerts are a pain in the ass to get to. You'll need an adapter for your grease gun (that will most likely leak) or you will need to remove the wheels to grease your tie rods.
    Or you can go to Napa and buy these for about 5 bucks.
    And then you have this... much easier!
  4. Dec 12, 2017 at 7:14 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    FYI... The inner clamp on your steering rack boots (left side of the boot in this picture) is quite possibly the biggest pain in the ass on your entire truck.
    Also... while you have everything torn apart, double and triple check these boots for rips, tears or holes. You do not want water to get in here. Also, I used super lube grease to help seal the areas under the clamps at either end of the boots. I filled the grooves where the boot ends sit with the super lube.
    TrentonTDG, jammer and CS_AR like this.
  5. Dec 13, 2017 at 8:03 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Zert fitting??? ZERT fitting?????????
    Here's a bit of trivia to help dispel the continual bastardization of the English language:
    (source = www.geni.com/people/Oscar-Zerk/6000000020722661365)
    "Who invented the Zerk fitting?
    "About Oscar Ulysses Zerk. Oskar Zerkowitz emigrated to the United States and changed his name to 'Oscar Ulysses Zerk'. He was also known as 'Oscar V. Zerk'. He became a world-famous inventor and one of his most prominent creations was a grease fitting known as 'the zerk."​
    I don't know if the above is true or not but it sounds reasonable. I picked up "zerk fitting" in 1960 and have not ever heard the phrase "zert fitting" up until now. ;)
  6. Dec 13, 2017 at 8:44 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    In other words...
    Lmao :proposetoast:
    From now on I will refer to them as "ball check grease fittings"... how's that?
    unstpible, TrentonTDG, G59 and 4 others like this.
  7. Dec 13, 2017 at 9:58 AM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    Let me know when you get to your ball joints... I'm about to tackle those in the next couple of weeks. But those zerts ... OMG!
  8. Dec 13, 2017 at 10:05 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I have the lower ball joints, and the upper control arm assemblies now. They will ve going in this weekend.
    And by the way... SPC UCAs have zert... I mean "ball check grease fittings" as well.
  9. Dec 13, 2017 at 11:20 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    That's a good note, I remember I was confused half way through when mine wouldn't work. Ended up just grinding the wrench until it fit haha.
  10. Dec 13, 2017 at 12:29 PM
    AKsavanaman
    Lower 48 :( U.P MI
    When I did mine I just happened to have an adjustable wrench that was skinny enough.. but I initially ran into the same problem
  11. Apr 4, 2019 at 9:58 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I'm resurrecting an old thread, I know....But did the wandering issue get better after replacing the tie rod ends? I've been having the same issue for over a year now and finally bought the parts to do it. I had a shop check my ball joints for play and they said they seemed fine but the tie rod ends were for sure bad. Hopefully it will help my issues because it's getting borderline unsafe to drive when it's windy.
    CS_AR likes this.
  12. Apr 8, 2019 at 6:13 AM
    nzane10
    nzane10 Member
    Nick
    Texas
    @ffirg same here man mines getting pretty sketchy so I’m about to tear mine apart, I’m doing the sway bar relocation kit (I have new coilovers), new sway bar end links, tie rod inners and outer, and I need uca but I’m broke lol
    ffirg likes this.
  13. Jun 26, 2019 at 7:17 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lol... sorry bro, never saw you asked this question. The wandering issue absolutely stopped after doing this.
    TrentonTDG and TWJLee like this.
  14. Jun 26, 2019 at 7:18 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I ended up taking out my sway bar all together. Once I went with heavy coil springs (ToyTec 620#) I no longer needed it.
    TrentonTDG, Luv my yota and CS_AR like this.
  15. Jun 26, 2019 at 7:19 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Still no issues. Just got my truck alignment checked about a month ago, and they said everything is good to go.
  16. Jun 27, 2019 at 7:38 AM
    Taco86er
    Taco86er Well-Known Member
    Bay Area
    04 Dbl Cab TRD
    3” Eibach/Bilstein Lift, TG Low Pro Bumper, Hella 700’s, HID Retrofits, Hella Supertones, Deckplate, Grey Wire, Shell w/Thule Rack and Basket, LED Shell Lighting, Rear Bumper LED Pod Reverse Lights, Tinted Tails
    Good stuff!!! Bout to tackle these any day now
    Running Board Man and CS_AR like this.
  17. Jun 27, 2019 at 7:44 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Same here. I usually borrow the inner tie rod end kit from Advance Auto.
    Luv my yota likes this.
  18. Jun 27, 2019 at 11:39 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Low Range is not one of my favorites.
    I ordered my ProForged from Amazon or Summit (Can't remember, but it was who ever was cheaper).
  19. Jun 27, 2019 at 12:11 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    I won’t wait a couple weeks at all, order=canceled. I’ve had vendors take my money in hold, and not ship!, saying (product in stock), then you call, and they are waiting for a piece of your order! Fuck that, they are middle men then really. That’s when they get dropped completely from my radar, they don’t have money to stock but tell the internet it’s in stock. I’m too old for that stress, paying for parts is bad enough. Lmao
  20. Jun 28, 2019 at 8:47 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    The narrow slot on the piston of the rack is 30mm. The slot on the inner tie rod is 42mm. The steering rack and inner tie rod on a 1st Gen Tacoma should be identical to a 3rd Gen 4runner.
