Tie Downs Points For Dirt Bike
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MlcKTMGUy, Aug 27, 2015.
  1. Aug 27, 2015 at 2:18 PM
    MlcKTMGUy
    MlcKTMGUy [OP] Active Member
    Beadling Pa
    2023 Dbl Cab Limited
    Just picked up a 15 Tacoma 4x4 AC, TRD OR. One of the main uses of the bed will be strapping in my dirt bike. Been a while since I had a truck.
    For better stability I prefer to put the wheel of the dirt bike in the corner of the bed with the bike diagonal so I can close the tail gate.
    I have 4 sliding tie down points (2 on each side) along the top of the bed rail. Are these strong enough to strap in a dirt bike? You have to pull the tie downs pretty firmly to make sure the bike is steady.
    The two anchor points in the lower corner of front on either side of the bed look much stronger but wouldn't allow for stuffing the wheel into a corner.
    How do you all strap the bike in?
  2. Aug 27, 2015 at 2:23 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    The bed cleats are fine in my experience... are you using the the pull tight straps? if so I highly doubt you could break one...
    Ive always had bikes straight however with the tail gate down and used the front hooks just because they are so much lower..
  3. Aug 27, 2015 at 2:31 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    I wouldn't trust those cleats.
    Bebop and At The Helm like this.
  4. Aug 27, 2015 at 2:35 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    SixthSnail likes this.
  5. Aug 27, 2015 at 2:36 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Have you tried to put the front in the center using the lower tie downs and just swinging the rear to the corner, after strapping the front center, to try clearing the gate? Not sure if it would work, just an idea.
  6. Aug 27, 2015 at 2:38 PM
    GHOST SHIP
    GHOST
    Now I have bed corner tie downs from another member here. A bunch of companies make them though- usually somewhere around $60-80.
  7. Aug 27, 2015 at 2:41 PM
    tacojpklx
    tacojpklx Well-Known Member
    eric
    michigan
    '10 AC OR, Magnetic Gray, 6spd
    toytec lift (eibach, bilstein 5100 at 0, Recall springs +Sumo Springs) seat covers, tint, weathertecs, shrokwork sliders, brute force rear bumper, in bed hi lift.
    i position mine like this.
    I use the rear drivers side d ring and i added another d ring to the front passenger bed bolt on the other side. On your '15 you could maybe use that bed side hook. i've since gone to pro taper soft tie downs which i recommend. Most times i add a third strap from the rear passenger d ring to the brake side footpeg area to prevent the bike rolling forward. i don't purposely cram the front wheel into the box corner. It just kind of wedges in there nice when the tailgates up.
  8. Aug 27, 2015 at 2:47 PM
    Josh828
    Josh
    Avery NC
    Didn't break... :anonymous:
    And how the hell does @Rock Lobster fit a quad in the back?
    TBH I ride a LTR and the only way it may fit would be on top of the bed cover
  9. Aug 27, 2015 at 2:55 PM
    Josh828
    Josh
    Avery NC
    Humm... maybe extended A arms were a bad idea...
  10. Aug 27, 2015 at 3:11 PM
    Humboldt707
    Humboldt707 Active Member
    Clay
    NorCal
    06' DCSB 4x4 SR5
    OME Lift w/ Dakar Leafs, TC UCAS, 285/65/17 BFG KOs on Moto Metals, BAMF Sliders welded on, Pelfreybilt front bumper with Warn zeon10000 winch and Rigid LEDs, Pelfrey Rear Hi-clearance, Ambiguous Retrofit Headlights, ARB CKMTA12 OBA, SPOD
    I second this. I have one and it works awesome. Can fit 2 or even 3 bikes with the wheels stuffed between the gaps. I have a short bed and just let the bikes back tire sit on the tail gate. I also just put a strap around the rear swingarm to the back corner d-rings so the ass end cant move around at all.
  11. Feb 27, 2019 at 6:39 AM
    krzysnwbrdr
    krzysnwbrdr Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
    I swear i have seen a picture showing which tie-down points are good and bad.
    I searched forum but cant seem to find it.
    Anybody?
  12. Feb 27, 2019 at 6:50 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    I've had no problem with these points.
  13. Feb 27, 2019 at 6:58 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    image.jpg Dont remember where I got this. But it’s worked great for me. Goes along the front of bed like the other pictured here.
  14. Feb 27, 2019 at 9:01 AM
    msfit
    msfit Well-Known Member
    SJ
    Radarninja[QUOTED] likes this.
  15. Feb 27, 2019 at 9:10 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Do not use the bed cleats only for tie down. I added D-rings to the bed so I had one on each bed bolt (two front, two middle, two rear), and tied down using those and Canyon Dancers.
    HansLanda likes this.
  16. Feb 27, 2019 at 11:32 AM
    HansLanda
    HansLanda Well-Known Member
    Bed rail cleats are not safe. Add 4 more D rings to the bed like CanisLupus and I did, and you're good to go. I use soft loop cam lock straps around the upper fork, and they're very secure.
  17. Feb 27, 2019 at 3:17 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    The ones on the back of the bed have a lot less flex to them than the side rails. I've been hauling my bike with those for years. Still not the ideal mounting point, but they have held up for me.
