Ticking noise when accelerating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kackritz44, Jan 25, 2018.
  1. Jan 25, 2018 at 7:25 PM
    Kackritz44
    Kackritz44 [OP] Member
    Kaitlyn
    1998 Toyota Tacoma SR5
    So i have a 1998 tacoma with the 2.4 in it. I recently pulled the motor to replace the oil pan gasket, rear main seal, front crank seal and the valve cover gasket. When i put the motor back in and cranked it up everytime I accelerate it makes a ticking noise like a ziptie is hitting the fan but it ticks only when i am accelerating it will not do it while its idling... i was told it may be the timing chain but i need other opinions before i replace it. I read on here people had kinda the same problem but it was the exhaust and i have checked everything dealing with the exhaust and it cant be it.
  2. Jan 25, 2018 at 7:27 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    @BartMaster1234
    BartMaster1234 likes this.
  3. Jan 25, 2018 at 7:28 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  4. Jan 25, 2018 at 7:28 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  5. Jan 25, 2018 at 7:28 PM
    Speedytech7
    @Kackritz44
    Is your truck auto or manual? How many miles?
  6. Jan 25, 2018 at 8:13 PM
    Kackritz44
    Kaitlyn
    @Speedytech7 my truck is an automatic and my truck only has 99k
  7. Jan 25, 2018 at 8:14 PM
    Speedytech7
    99k is really low for a 2rz and especially low to need a timing chain. If it still shifts and drives okay I'd lean toward exhaust leak too, really common on the 2 into 1 collector that has three bolts.
    Key-Rei likes this.
  8. Jan 25, 2018 at 8:15 PM
    Kackritz44
    Kaitlyn
    @BartMaster1234 it aint as loud as that and does not do it when idling
  9. Jan 25, 2018 at 8:15 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That's good. That's what it sounds like when the flexplate is cracked.
  10. Jan 25, 2018 at 8:36 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It would help if you can record the sound or a video. I recorded that sound file on my iPhone and exported it and uploaded it to that website.
  11. Jan 25, 2018 at 8:39 PM
    Kackritz44
    Kaitlyn
    @BartMaster1234
    I will try and get one. Would it make that sound if the bolts aren’t tightened down all the way?
  12. Jan 25, 2018 at 8:40 PM
    Speedytech7
    Or if you reused the old exhaust gaskets
  13. Jan 25, 2018 at 8:43 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Did you torque everything to spec and use thread sealer?
    It'll make that sound if the flexplate is hitting the inspection plate or it's cracked. It could be something else but I'm really not sure. I do know if the sound worsens and becomes like my sound bytes than your flexplate is cracked.
  14. Jan 25, 2018 at 8:49 PM
    ectrd
    ectrd Well-Known Member
    '04DC
    4 tires, a steering wheel & a seat
    I wouldn't think it'd be a timing chain (do you even have a timing chain ? ) This is a 4 banger ?
    In any event most likely would'nt even run , even if it only jumped a half tooth..
  15. Jan 25, 2018 at 8:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It's a 2RZ-FE 2.4l four cylinder. That and the 3RZ-FE 2.7l both had timing chains. The 5VZ-FE v6 is what had the timing belt.
    Speedytech7 likes this.
  16. Jan 25, 2018 at 9:09 PM
    Kackritz44
    Kaitlyn
    Yes it does have a timing chain cause i was going to replace it while it was out but it looked fine and tight still. But we did not take the exhaust manifold off so i dont see why it would leak
  17. Jan 25, 2018 at 11:08 PM
    Kackritz44
    Kaitlyn
  18. Jan 25, 2018 at 11:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  19. Jan 26, 2018 at 5:30 AM
    Kytacotrd
    Kytacotrd Well-Known Member
    2003 Tacoma TRD xtra cab
    If it sounds like underneath, might be u joints.
  20. Jan 26, 2018 at 6:25 AM
    zbadboy
    zbadboy Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
    U-joints don't tick.
