Throwing 2 Codes (p0441, P0455)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brandon H, May 21, 2010.
  1. May 21, 2010 at 6:52 AM
    Brandon H
    Brandon H [OP] Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Hey Everyone,
    Think I need some help on this. Throwing 2 codes (P0441, p0455). Already changed he Gas Cap. No Help. Any help would be greatly appreciated. Thanks!!!!
  2. May 21, 2010 at 6:56 AM
    techgeekwill
    techgeekwill Well-Known Member
    Spring, TX
    18 Inferno TRD OR DCSB
    Have you done anything to it recently, like added/modified the air intake?
    I'd try clearing them and see if they come back. It could just be the Gas cap wasn't tight enough or something and they haven't cleared. Other than that, check that all the EVAP hoses are connected and secure.
  3. May 21, 2010 at 8:06 AM
    Brandon H
    Newhall, CA
    07 DC Offroad
    The engine is totally stock. Codes have been there for a year now. Cleared many times
  4. May 21, 2010 at 8:28 AM
    techgeekwill
    Spring, TX
    Since it's emissions, and you're stock. Go to the dealer. The emissions warranty goes longer than the power train.
  5. May 21, 2010 at 8:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2
    8 years or 80k I believe.
  6. May 21, 2010 at 8:51 AM
    Brandon H
    Newhall, CA
    07 DC Offroad
    Yeah I think I will. That's about the only thing still stock!!!
  7. May 21, 2010 at 10:45 AM
    mpleitez
    mpleitez Well-Known Member
    valencia
    03 toyota tacoma double cab 4x4
    Rear E-Locker TRD supercharger w/URD 7th injector 3 in. lift (soon) Icon coil overs front (soon) Icon UCA (soon) K&N air intake DT Headers (one day)
    Hey Brandon,
    My problem was the purge hose in the engine bay was old and had a hole in the line once I replced it and erased the codes no more problems. The purge hose is on the drivers side. Purge hosse was $14.00 from Toyota
  8. Jan 3, 2011 at 5:17 PM
    STEVECBR929RR
    STEVECBR929RR STEVECBR929RR
    STEVE
    CONNECTICUT
    06 TACOMA DBL CAB SR5 TRD
    black nerf bars, AVS in channel rain guards
    Hey Brandon,
    My CEL came on today and I scanned it and I have the exact same two codes you did. Did you ever find out what it was or get it fixed? Any help would be greatly appreciated. I hate going to the stealership!
    Thanks!
  9. Jan 3, 2011 at 5:24 PM
    Brandon H
    Newhall, CA
    07 DC Offroad
    Hey Steve,
    Still have the problem. Not sure what to do next
  10. Jan 3, 2011 at 6:49 PM
    98tacoma27
    Ben
    Not Beech Creek
  11. Jan 3, 2011 at 6:50 PM
    98tacoma27
    Ben
    Not Beech Creek
    It could be something as simple as the purge VSV stuck open
  12. Jan 4, 2011 at 5:17 AM
    STEVECBR929RR
    STEVE
    CONNECTICUT
    Thank You for the info 98Tacoma27!
  13. Jan 4, 2011 at 5:18 AM
    STEVECBR929RR
    STEVE
    CONNECTICUT
  14. Jan 21, 2014 at 4:02 PM
    Wildhorse1966
    Wildhorse1966 Active Member
    sorry for bringing a thread back from the dead but many of these threads people post them and never post what was done to fix it .. well, last year I repaired Brandons truck performed smoke test and couldn't find any problems removed fuel tank for the well known issue with the fuel pump and that wasn't the issue either .. turned out to be a bad charcoal canister .. its been over a year now and he no longer has a CEL
  15. Jan 21, 2014 at 5:06 PM
    Saphteemon
    Saphteemon Member
    Cypress, CA
    14 Taco, 86 4runner
    Stock
    Appreciate the post weirdhorse
  16. Jan 22, 2014 at 8:30 AM
    Brandon H
    Newhall, CA
    07 DC Offroad
    If you guys need any Repair work in the LA area, My Mechanic and Friend is a Toyota Master Mechanic. Does great work. Hit me up.
    SethM likes this.
  17. Apr 15, 2014 at 5:02 AM
    Firemediceric
    Firemediceric New Member
    Florida
    2006 Tacoma
    I am just chiming in for those who, like me, stumble across this thread when doing a Google search after having the check engine light come on and finding out they have the same two codes. In my case I was fortunate enough that just reseating the gas cap fixed it for me. I have an aftermarket gas cap because I want one that locks. I had to check engine light come on, I put the scanner on the truck to check the codes, found these two, cleared the codes, reseated the gas cap and all has been fine since.
    2K01SpaceOtterSea likes this.
  18. Mar 30, 2016 at 6:22 PM
    ADVBedouin
    ADVBedouin Well-Known Member
    Central CA Coast
    '10 Preunner Acc Cab 2.7L 5spd
    2" CCM front spacers, secondary airfilter gone, OEM 16" alloys, Trailer hitch gone, Seat belt buzzer gone, Ignition key buzzer gone, shortened fact. antenna.
    Just as another datapoint, my '10 Tacoma with the 2.7L 4cyl & 80k miles showed a check engine light & trac control light, & threw the 0441 & 0455 codes, but upon filling the tank, I noticed that the gas cap was a little loose. I had the codes read & cleared, tightened the stock gas cap correctly, & in 700 miles the issue hasn't come back. I got lucky, but maybe this will help someone out.
  19. Mar 31, 2016 at 12:12 PM
    RobIAm
    RobIAm Member
    tex
    11 base prerunner
    5100,dacar,17,bacflip
    It must be somewhere but I can't find it. How do you clear the codes?
    TY
  20. Mar 31, 2016 at 2:47 PM
    ADVBedouin
    Central CA Coast
    You'd need an OBDII reader to do it & it plugs into the obd port under your dash. I just stopped by my local shop & he read & cleared the codes for me in a minute. I've heard many auto parts stores will do this for you for free too.
