Through Glass Antenna for Ham Radio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doc62, Dec 4, 2023.
  1. Dec 4, 2023 at 2:17 AM
    Doc62
    Doc62 [OP] Well-Known Member
    Dave
    SE Pennsylvania
    2021 Tacoma TRD Off Road, 2019 Sahara
    I've searched all over this site (as well as the internet) and saw multiple answers. Just wanting to know if anyone here successfully uses a through glass antenna setup for their radio using the back window that came with privacy glass. Thanks.
  2. Dec 4, 2023 at 6:20 AM
    Tallwalker
    Tallwalker Too tall to hide, too old to run.
    Through glass is really a last resort in my opinion. There is no ground plane so it is only going to act as a 1/4 wave 0db antenna. Better than using a rubber duckie on an HT but not by a whole lot. Works ok if you only venture a few miles from the repeater but don’t expect much range. If you must, Larson is probably the best glass mount. I don’t honestly know for sure if Toyota rear glass uses metallic privacy film, but that and keeping away from defroster elements is important if you install one.
  3. Dec 5, 2023 at 12:16 AM
    Doc62
    Dave
    SE Pennsylvania
    Just looking into options. The front A-Post/Hood area is already taken up by antennas for two other radios.
  4. Dec 5, 2023 at 12:35 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I used a Larson glass mount for many years on my accord- it worked well with decent range for my 2M rig. I now use rack mounts for my antennas - they attach to my Prinsu roof mount.
    Victory 4x4 makes an antenna mount for the hood that can be attached on either side, that is a good place for an antenna- my AM/FM goes there since I pulled the plug to the OEM antenna in the roof.
  5. Dec 5, 2023 at 5:23 AM
    Doc62
    Dave
    SE Pennsylvania
    The question is will the Larsen work through the rear privacy glass. Trying to avoid spending the money for one and finding out it does not work due to the privacy glass.
