throttle fuse?
Discussion in '1st Gen. Tacomas (1995-2004)' started by barnabus1999, May 31, 2018.
  1. May 31, 2018 at 8:41 AM
    barnabus1999
    barnabus1999 [OP] Active Member
    2004 Ext Cab Tacoma 4x4
    My throttle is not working the shop replaced the fuse yesterday. Which fuse do I need to replace?
    Related note:
    The shop is recommending replacing the positive cable harness and is quoting 1k to do the job. I am not confident this needs to be done.
  2. May 31, 2018 at 2:18 PM
    barnabus1999
    ok so I am guessing the EFI fuse?
  3. May 31, 2018 at 5:58 PM
    lvs2rock
    lvs2rock Well-Known Member
    N. Cali
    96 Taco 2RZ-FE auto
    what engine?
  4. May 31, 2018 at 6:07 PM
    lvs2rock
    N. Cali
    96 Taco 2RZ-FE auto
    oh, and could you explain symptoms and reason given by shop for thinking positive cable harness needs replacing? Incidentally, did they charge you for the mis-diagnosis? AFAIK most if not all Toyota fuses, relays and switches have testing procedures for confirming functionality- frequently involving electrical resistance (?) of the component under various conditions- they're outlined in the Toyota FSM (yup, that's where I learned it!) and step by step iprocedures are given for Toy techs to follow. If it's good enough for Toyota......
  5. May 31, 2018 at 6:12 PM
    02hilux
    Planet: EARTH
    Throttle fuse?
    Described your issue and symptom will help us try to help you
    lvs2rock likes this.
  6. May 31, 2018 at 6:32 PM
    barnabus1999
    Its a v6. She was sitting for a month and the battery was dead. I cant charge it living in an apartment no electrical outlet. Cool old Optima battery is 5 y/o time for a new one. Shop sold me a wrong model.
    Admitting some ignorance...
    I put it in blew fuses
    Talked to mechanic at shop he got it running by fixing fuses flipping battery, cutting stereo wires that didn't fit.
    Long story
    Got a new battery correct battery today after a day on the phone with Optima and Oreilys.
    Need to patch the wiring. Ideally need new terminals and get it cleaned up.
    Getting tired of this after a few days.
  7. May 31, 2018 at 6:39 PM
    barnabus1999
    I'm tired of this My Mom aksed me why I keep this old truck, I've worked on building this fot 15 years. Im about ready to have it huled to Toyota. I'll give it one more try when I'm in the mood.
  8. May 31, 2018 at 6:42 PM
    barnabus1999
    Now the gas peddle doesn't work at last start. When shop looked at it replaced fuse. I can't figure out which one. I put in a new EFI fuse haven't tested yet.
  9. May 31, 2018 at 7:45 PM
    barnabus1999
    The throttle would not respond this morning after starting. When a fuse was replaced by mechanic yesterday it was ok. Ground was not attached due to wiring issues.
  10. Jun 3, 2018 at 9:47 AM
    lvs2rock
    N. Cali
    96 Taco 2RZ-FE auto
    can you resolve the wiring issues? Your chances of success would be greatly improved if you eliminate these as a possible cause. At the very least re-ground at all key points.
  11. Jun 3, 2018 at 12:54 PM
    barnabus1999
    I got burned out w this after a day on the phone w O’Rielys and Optima got the correct battery. Toyota says computer needs to be replaced
  12. Jun 3, 2018 at 1:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    So you connected the battery with reverse polarity?
    If so you blew at least the main fuse. Depending on other things it may have well toasted the ECU as Toyota is suggesting.
  13. Jun 3, 2018 at 3:43 PM
    barnabus1999
    Yeah I admit using the wrong part caused the problem I could have been more aware. Wish I’d have known. Thanks for listening. My girl has been out of a week I miss her. I hope she recovers and understands how much I care.
