Threads rusted on cab running board holes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PeteSmashh, Mar 6, 2020.
  1. Mar 6, 2020 at 9:04 AM
    PeteSmashh
    PeteSmashh [OP] Well-Known Member
    I went to put running boards on my tacoma and found that the threads were so badly rusted that the stock screws (m8x1.25x25mm) would not even go in. I was able to get a m7 screw to go in which is a tiny bit smaller and it actually tightened up but was a little loose. I was thinking to use some kind of adhesive to stay secure. I was debating using loctite or silicone...what do you guys think?
    Other option was to try to rethread the holes using a tap set.
  2. Mar 6, 2020 at 9:14 AM
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    Chase the holes with a tap first then be sure to use anti seize on the mounting bolts.
  3. Mar 6, 2020 at 9:16 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    tap
    TnShooter and DG92071 like this.
  4. Mar 6, 2020 at 9:22 AM
    PeteSmashh
    Thats a good idea. Use the same size tap as the M8 bolts or go higher?
  5. Mar 6, 2020 at 9:40 AM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    Since you know the original size, I'd re-tap with that. If they're real bad, use some cutting oil.
    Silentshredr and DG92071 like this.
  6. Mar 6, 2020 at 12:40 PM
    redcon
    redcon Well-Known Member
    Dave
    Southern PA
    2012 AC 4x4 Base 2.7L/5MT
    I had to chase the threads with a tap when I mounted my boards up-- but on just one of my holes on each side that was very rusty. The others were clean and the bolts threaded through great.
  7. Mar 6, 2020 at 2:36 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    It is clear I don't know a whole lot ... but this might help. :)
    I had this same problem on my 2005 Tacoma. I bought a small wire brush in the shape of a Christmas tree, soaked it in rust removing lubricant (can't remember what brand I used but picked it up at Autozone), and twisted it in the whole and spun it around for awhile. I then got another liquid that I rubbed on the bolts with another product and they slowly threaded right in and those holes were pretty rusted. Might not apply in your case but in case it does I wanted to share. I found the metal brush and the lubricant worked pretty well. Might be worth considering.
    D2. likes this.
  8. Mar 7, 2020 at 4:09 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    To clean up existing threads, use a chaser. To cut new threads use a tap. There is a difference.....
  9. Mar 9, 2020 at 9:22 PM
    PeteSmashh
    this worked great. Cleaned the holes out after with WD-40. I also got the cheapest running boards on eBay and they’re def not high quality but I like em. 4” running boards look pretty good. I thought they were gonna look too wide but they don’t and it’s also pretty easy to get in and out of the truck with em.
    TacoJoeBro[QUOTED] likes this.
  10. Mar 9, 2020 at 9:42 PM
    jaredjnolan
    jaredjnolan Member
    Jared
    2007 Black Tacoma Long Box TRD Sport
    happened to me, some wd 40 and carefully re-tap
  11. Mar 10, 2020 at 10:03 AM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    Nice! Those don't look bad on there at all. They've got a good length and position between the tires. As long as they serve their purpose and you like them, I say rock em.
  12. Mar 11, 2020 at 9:13 AM
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    A tap will work just fine.
    MSN88longbed likes this.
