Thoughts on this gear?
Discussion in 'Recovery' started by Rustytaco71, Nov 26, 2018.
  1. Nov 26, 2018 at 9:03 AM
    Rustytaco71
    Rustytaco71 [OP] Well-Known Member
    2018 4Runner
    Ordered some items off of Amazon for recovery gear as I plan to do some adventuring in the snowy mountains this winter!
    Anybody have any insight on my current selection? Look good or should I swap for something else or add anything else?
    Is the hitch receiver strong enough to hold our trucks? It’s rated at 4.75 tons so that comes out to 9500lbs. Will the weight increase on the shackle receiver the same way it does on the strap?
    Just learning with all this recovery gear so please be patient with me:D
    It was $75 for all this gear due to them having 10% off if you purchase 3 or more items form them.
    Thanks!
    Rhino USA Folding Survival Shovel - Best Entrenching Camping Tool Available, Carbon Steel Design for Ultralight Durability - Beach, Camp, Hiking, Backpacking, Recovery - Guaranteed! https://www.amazon.com/dp/B07BH7C339/ref=cm_sw_r_cp_api_oFc.BbTFTXYJA
    RHINO USA Shackle Hitch Receiver, Best Towing Accessories for Trucks & Jeeps, Connect Your Rhino Tow Strap for Vehicle Recovery to This 31,418 Lbs Capacity Reciever, Mounts to 2” Receivers! https://www.amazon.com/dp/B06WLMF23C/ref=cm_sw_r_cp_api_POc.BbEB8BHHS
    Rhino USA Recovery Tow Strap 3" x 30ft - Lab Tested 31,518lb Break Strength - Heavy Duty Draw String Bag Included - Triple Reinforced Loop End to Ensure Peace of Mind - Emergency Off Road Towing Rope https://www.amazon.com/dp/B06WRSR2PG/ref=cm_sw_r_cp_api_7Ac.BbAAA8Q2A
  2. Nov 26, 2018 at 10:35 AM
    Rustytaco71
    2018 4Runner
    Upon learning that the strap is a towing strap and not designed to “snatch” recover, I cancelled it and went with this:
    Ultimate Tow Recovery Strap 35000lb - Recover Your Vehicle Stuck in Mud/Snow - Heavy Duty 3" x 20' Winch Snatch Strap - Protective Loops, Water-Resistant - Off Road Truck Accessory - Bonus Storage Bag https://www.amazon.com/dp/B06ZZBGFYV/ref=cm_sw_r_cp_api_uYd.Bb4QP2XQ3
    I still kept the receiver and shackle.
  3. Nov 26, 2018 at 10:37 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    Welcome to TW.
    We all have to start somewhere, and we all don't have the budget to buy "the best" right off the bat. Buy the best you can afford and put it to use. If it doesn't work for you or fails, then buy something better. Just don't get yourself in a position where the tool's failure will leave you stranded; i.e., don't go wheeling by yourself.
    Reviewers seem to like the products. I'm sure they'll work just fine.
  4. Nov 26, 2018 at 10:37 AM
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    Get a real shovel. Go to Lowes or any home improvement store.
    Durango95 and Rustytaco71[OP] like this.
  5. Nov 26, 2018 at 10:58 AM
    Rustytaco71
    2018 4Runner
    Understandable, it’s always nice to get a thumbs up though from someone who has more experience in a certain realm. Thank you!
    2BeersPlease[QUOTED] likes this.
  6. Nov 26, 2018 at 11:24 AM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Buy a real shovel. A D handle or forest service shovel should fit in the bed just fine. You will also need a way to connect the strap to another vehicle. I’d also suggest mud and snow rated tire chains.
    Durango95 likes this.
  7. Dec 9, 2018 at 3:18 PM
    kurts74
    kurts74 Well-Known Member
    Flagstaff, Arizona
    2nd Gen 4-door longbed
    ICON Mid travel set up with Hard candy shell
    Agree 1000% get a full length shovel...if you have to dig under your axle with a dinky shovel your going to get very frustrated. You will be on your hands and knees most likely in mud/snow.
  8. Jan 6, 2019 at 9:09 AM
    svdude
    svdude Well-Known Member
    jonathan
    The Rhino products are good stuff. There's tons of good reviews on them and articles covering the reliability of their products. You're not going to go wrong with them.
    For the snatch strap, keep in mind the snatch strap is only good for vehicle to vehicle pulling. If you wanted to winch with a hilift the strap will stretch through the whole range of the hilift movement before the vehicle starts getting pulled.
    I threw a hilift recovery strap in my kit for this reason. It's polyester and has a 2% stretch (as opposed to a 10% for a nylon strap) so it's good for winching with a hilift and can be used to recover vehicles.
  9. Jan 12, 2019 at 11:05 AM
    madcratebuilder
    madcratebuilder Well-Known Member
    PNW
    ZR2 Deepwood Green
    skidz, gears, tune, zeon 12-s
    Towing with a snatch strap can cause strap failure. Every time the strap stretches the molecules move apart, it takes time for them to regain the original integrity. Repeated stretching over a short period of time may cause failure. Fine for short distance but I would not recommend for several miles.
  10. Jan 15, 2019 at 9:40 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It’s not always obvious, but it has been said, and bears repeating. A strap is ONLY useful if you have another vehicle. I know it sounds obvious, but I’ve seen a few people driving alone “but they had a recovery kit with a strap” and they get stuck, break out the strap, THEN the lightbulb goes on, lol.
    So, if you drive alone, get a winch, or some type of winch device, a come along at least, better yet a hi-lift as that can be used for many things.
    I 2nd he idea of a full sized shovel, or at least one of those shorter gardening shovels. Those folding shovels are great for soldiers on foot who need to dig a foxhole, but if you have a truck, bring a bonafide shovel. You have the space, it’s a pickup truck.
    madcratebuilder likes this.
