Thoughts on synthetic oil & Royal Purple
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, Mar 5, 2010.
  1. Mar 5, 2010 at 3:52 PM
    BreezyTaco
    BreezyTaco [OP] Well-Known Member
    Corpus Christi, TX
    Pioneer Indash GPS, JL Audio Speakers, FM Alarm, Euro Tail lights, Blue Dash Lights, Trailor Hitch, Painted Fiberglass A.R.E. Tonneau Cover
    I made the switch to synthetic oil yesterday and it was a little pricey. I got the oil change at Pep Boys which was priced at $69, but needed an extra quart for the Tacoma, so total was 85, but out the door for 75 with military discount. My buddy swore by Royal Purple so that is what I had put in, is this switch worth the money, and is Royal Purple the answer?
  2. Mar 5, 2010 at 3:54 PM
    sooner02r1
    sooner02r1 Well-Known Member
    A lot of people swear by Royal Purple, and I run it in my rear diff, but for my motor I run Mobil 1. A little cheaper and in a stock Toyota motor I think it's more than sufficient.
  3. Mar 5, 2010 at 3:55 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    unless you're racing, royal purple is a little overkill imo. and it is deffinately too expensive to pay someone to change your oil. our trucks are some of the easiest in the world to change oil on (location of the oil filter, and clearance to crawl under). if you do it yourself, you can get your oil changed using synthetic for about $35 and 15 minutes of your time.
  4. Mar 5, 2010 at 3:56 PM
    BreezyTaco
    Corpus Christi, TX
    That is what I was going to get but like I said my buddy was saying if I didn't feel the difference he would pay for my next oil change. Haven't noticed any difference thus far, but we'll see in the long run.
  5. Mar 5, 2010 at 3:57 PM
    BreezyTaco
    Corpus Christi, TX
    Yeah I thought about that today, but next time I will prolly do it myself, just wanted it done professionally the first time.
  6. Mar 5, 2010 at 3:57 PM
    jandrews
    '09 FourDubDee TRD OR
    Please search the forums. This has been beat to death.
    For brevity's sake:
    1) Any quality (brand name) synthetic will do fine.
    2) Regular oil changes are more important than synthetic/dino.
    3) Use a quality filter (the OEM filters from Toyota are excellent), which should be changed as regularly as the oil.
    There. Done.
    FWIW, I run RP in my V6 at the moment and will be moving to RP in the diffs/t-case when the time comes to change (mobil 1 in the driveline right now).
  7. Mar 5, 2010 at 3:58 PM
    BreezyTaco
    Corpus Christi, TX
    I could use the search engine, but wanted to include my own personal experience, thanks for the info though.
  8. Mar 5, 2010 at 6:24 PM
    rodstone
    rodstone Well-Known Member
    Travis
    California
    08 2.7l 2wd
    I am the same way, if it's overkill protection then that's right up my alley. I got RP in the engine,trans and diff. I used Mobil-1 at first in my truck, then tried out RP in the engine and haven't looked back. Mobil-1 is great oil, I use it in the rest of my family's cars. Pep Boys has had that deal goin on for a while now and I'm lovin it.
  9. Mar 5, 2010 at 6:29 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I've seen some reports on Bob's in the past that Royal Purple isn't all it's made out to be. Castrol GTX Syntec and Mobile 1 performed as well if not better over longer durations for protection. As stated above though, any synthetic beats dyno oil for protection. At 5k intervols, either will work pretty well but I've always been on the 3k dyno mark, or 5k synthetic. Either is still overkill. $75 in parts is way to expensive, save some cash and get Castrol GTX Syntec or Mobile 1 quite a bit cheaper in the future. Also as mentioned, quality filters are where it's at. For once, dealer filters are excellent, though I still run K&N myself (always have, always will).
  10. Mar 5, 2010 at 6:40 PM
    scocar
    scocar hypotenoper
    There are some interesting studies, actual si-yun-tiffik studies, on most of these oils, and the Royal Purple did not seem to fare too well, IIRC. the Amsoil and Mobile 1 did. And know I am hoping that I'm not confusing the motor oil and the gear oil studies....
    If you are a Costco member, you may be able to find it for, uh, I think it was about $35/case (six bottles). The OEM filters are about $6, which is about half of a Mobile 1 or K&N filter at Autozone ($13). The filters have been pretty rigorously studies too.
    What I don't undertand is that Mobile 1 has been proven to last 10K miles (one of the major selling points of synthetics, higher cost, but last longer), but lots of people seem to like to throw synthetics away at 3K miles. I guess they are rich, own Exxon Mobile stock, and like to waste perfectly good oil. I can see changing only the filter at 5k, but not the oil.
    I know that when I put in Mobile 1 the first time, my truck gained like 500 hp, I got about 73 mpg, and all the hot chicks in my neighborhood suddenly wanted a ride. Amazing stuff.
  11. Mar 5, 2010 at 6:56 PM
    jandrews
    All the whining I've seen over there has to do with RP 5w-30 shearing to 5w-20 at about 5000mi. Wear metals are always super low though, so I really couldn't care less about oil weight shearing down. A lower viscosity oil providing good wear protection just means better mileage.
  12. Mar 6, 2010 at 8:19 AM
    BreezyTaco
    Corpus Christi, TX
    This is some great information, I havent felt a difference yet in the truck, but we'll see how the mpg goes. I'm installing an Injen CAI hopefully sometime next week, but I may go to Mobile 1 in the future.
  13. Mar 6, 2010 at 9:32 AM
    copernicus
    copernicus Well-Known Member
    I used royal purpler at 3k - 6k miles on my truck, then I switched to mobile 1. I'm at 9K and the mobil one feels better to me.
  14. Mar 6, 2010 at 9:50 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  15. Mar 6, 2010 at 1:54 PM
    BreezyTaco
    Corpus Christi, TX
    Thanks, I'm gonna do my own oil changes, it is way too expensive to take it to the shop.
  16. Mar 6, 2010 at 2:40 PM
    BSRACING777
    BSRACING777 Well-Known Member
    Brendan J.
    Austin, Texas
    06 tacoma 4X4 TRD QuadCab
    A good buddy of mine wrenches at Lexus and they use Catrol and I use the new CASTROL EDGE. My last Toyota truck before someone wanted it more then me took it had 398k on it and never had the engine open for any reason, I use it in my sons race bike too. I too use the K&N oil filters and seems to love it, my Taco tells me so all the time? :)
  17. Mar 6, 2010 at 2:43 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    RP is way over-priced for what you get.
    Lots of good synthetics you can pick up and get the same 5k protection for around $30. If you watch for sales/rebates, you can get them at even better prices. Right now I'm using some PP that I got for $1 a quart after rebate.
  18. Mar 6, 2010 at 2:53 PM
    hate2work
    Washington State
    06 standard cab
    I agree. If I was going to use an oil that cost $8-$10 a quart, it would be Red Line. Since I don't heat up my oil by towing a trailer or having a turbo, I'll stick with my syns that I get on sale.
  19. Mar 6, 2010 at 7:55 PM
    BreezyTaco
    Corpus Christi, TX
    I'm starting to feel bad about my purchase, next time Ill do some more research, but I think I'm going to switch to Mobil 1 synthetic
  20. Mar 6, 2010 at 8:20 PM
    hate2work
    Washington State
    06 standard cab
