Thoughts On Slotted Axle Shims
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buckaroo1993, Jul 22, 2018.
  1. Jul 22, 2018 at 11:10 AM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Anyone use the slotted axle shims rather than the single hole shims? Seems like it would be easier to install the slotted since all you would have to do is loosen the assembly and push/tap/hammer the shim in place. Shouldn't have to remove the centering pin I wouldn't think.
  2. Jul 22, 2018 at 11:13 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I read about them when I was considering putting shims in. Seems like the general consensus was that if you wheel a lot and are flexing out the springs regularly, you're better off with the non-slotted ones as the slotted ones can move around more easily or fall out of place.
  3. Jul 22, 2018 at 11:14 AM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    Just off the top of my head I would think under heavy abuse youd be more likely to have failure.
    Usually if I have to remove ages old u-bolts it's best to get new ones anyways. If not, how hard is it to put one with a hole on it in? There's usually ample room between the axle and the springs once the bolts are loosened. Plus the ones with holes have their own centering pin to adjust the axle .
  4. Jul 22, 2018 at 9:08 PM
    Buckaroo1993
    Vinny
    Georgia
    Mines a DD and rarely sees off-road use except during deer and turkey season. Even then I don't "wheel" it. Repair's cost too much. :thumbsup:
  5. Jul 22, 2018 at 10:16 PM
    KkelX4
    2017 Tacoma TRD OR
    RTT Rack
    Honestly I wouldn't even be worried about wheeling. I would worry about washboard or hitting a deep pothole. Just go with holes it's like no extra work and way more peace of mind.
  6. Jul 22, 2018 at 10:25 PM
    Buckaroo1993
    Vinny
    Georgia
