Thoughts on RCI skid and sliders?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eric818, May 15, 2024.
  1. May 15, 2024 at 4:43 PM
    eric818
    eric818 [OP] Well-Known Member
    Eric
    2023 tacoma trd off road
    Looking into getting some sliders and skid plates.. RCI is having a great sale right now. Any thoughts on RCI?
  2. May 15, 2024 at 4:45 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I've beat the piss out of mine. They are solid. I have sliders and skids. Go steel if you are going to actually use them. Aluminium if they are just there for "oops"
  3. May 15, 2024 at 4:48 PM
    eric818
    Eric
    Thanks for the reply dude. Did you install them yourself? Wondering if the sliders are easy to install.
    G2.M6 likes this.
  4. May 15, 2024 at 4:50 PM
    eric818
    Eric
    Also, I saw your build.. Nice build
    How much did the exhaust re route cost you.. And any muffler shop can do it or is there a specialty shop for that
  5. May 15, 2024 at 4:52 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    I've absolutely beat the heck out of my engine skid when on stock suspension. Added trans skid later and sliders more recently. Can't go wrong with RCI
    Took it off here to clean up as i needed to replace the oil door after bending it
    20 degree sliders
    71tattooguy and eric818[OP] like this.
  6. May 15, 2024 at 4:53 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    RCI :thumbsup:
    BOZOJUICE likes this.
  7. May 15, 2024 at 5:06 PM
    ZColorado
    13 DCSB OR 6MT
    If you are in Colorado, I recommend the shop I went to. He did a fantastic job. There is a thread around here somewhere of others and some are functional, but not great.
  8. May 15, 2024 at 6:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Yes, do it!
    eric818[OP] and 71tattooguy like this.
  9. May 15, 2024 at 6:28 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    I haven't been able to put them through any paces yet, but the RCI skid set that I have in my garage waiting to get installed onto my 2008 T4R look to be solid as hell.
    The install points need a little love, several of the bolts for the factory plate were rusted in (bought the rig used in 2021 with 200k miles, and it spent its first 6 winters in the northeast according to Carfax) and snapped off when I pulled the OEM plate off the engine so those stubs need to be drilled out and the threads either "chased" clean or the nuts replaced with nutserts, and the forward mount points need to be re-fabricated pretty much entirely and every time I think I'm ready to spend a day rolling around on the concrete driveway my (damn near) 50 year old back laughs and says "the fuck you are"...
  10. May 15, 2024 at 8:40 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Installing the front skid by yourself is possible. I do it by wearing hard kneepads like flooring installers use. Then balance the skid on the kneepads to maneuver so front 2 bolts can be partly installed then the next two back ... at that point it should stay on easily enough. The RCI transmission skid is a flat 40 lb (steel, aluminum is 20 lbs I think) which I needs two people or jackstands (I screwed some 2x4 seectints into a holding box) to have it high and steady to slide in.
    But my steel engine skid already took a big scrape that surely would have damaged something.
    Get the catalytic converter guards with the transmission plate.
    eric818[OP] likes this.
  11. May 15, 2024 at 8:57 PM
    eric818
    Eric
    would you guys recommend the sliders with top plate? or without. i like how it looks without but not sure if there isa benefit.
  12. May 15, 2024 at 9:26 PM
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    RCI. No question. Solid products and great customer service.
    I've got engine, transmission, transfer and cat skid plates as well as sliders from RCI. Install is not hard. I would stay away from the aluminum and go with the steel. Extra weight, but it's going to take a beating.
  13. May 15, 2024 at 9:33 PM
    eric818
    Eric
    ya i am going all steel
    but for the sliders, do you recommend the top plates? would like to save 175 plus tax if i could lol
  14. May 15, 2024 at 9:39 PM
    Offroad Taco 2022
    Offroad Taco 2022 Well-Known Member
    Manny
    2022 TRD Offroad
    How much of an improvement do you get over the TRD skid plate?
  15. May 15, 2024 at 9:53 PM
    RichochetRabbit
    TRD is aluminum, my RCI engine skid is steel. Steel is stronger and some may find it easier to re-weld if it takes a hit and needs a seam rewelded. Aluminum can be re-welded but requires more specialized methods.
  16. May 15, 2024 at 10:29 PM
    Southwest Tacoma
    Southwest
    Top plate not necessary. Just a personal preference.
    eric818[QUOTED][OP] likes this.
  17. May 15, 2024 at 10:33 PM
    RichochetRabbit
    Some say the top plate traps mud and debris. Some say it helps as a step, even if a very narrow step. As stated, personal preference because nothing can be proven scientifically.
  18. May 15, 2024 at 10:46 PM
    OnePuttBlunder
    AZ
    Re top plate mostly personal preference but if going 5 degree sliders the top plate does act as more of a step and if you have dogs or little kids can help prevent legs slipping been bars when getting in and out. I went top plates on 20 degree to help with a bit more of a step for access to the roof rack and top of the GFC. From what I've seen on others there is a little benefit keeping mud/rocks from getting flung up into my rockers/doors. Also we have a couple little dogs and I don't want to deal with the aftermath of having one of them break a leg getting in/out of the cab.
  19. May 15, 2024 at 10:54 PM
    eric818
    Eric
    Ya I don’t have kids or a dog that will b getting in my car. I just wish I could see them in person to see if without the top plate if I could still use as a step lol. I’m not on the tall side so my running boards do help to get in right now. But I want to go with the 20 degree with no top plate. It looks better IMO
  20. May 15, 2024 at 10:57 PM
    RichochetRabbit
    Pick your region, post a request to see them in person. Some will not even need a six-pack as payment for seeing them: https://www.tacomaworld.com/forums/regions.36/
    71tattooguy likes this.
