Thoughts on 285/70/16s / cuttin?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by efmason87, Jul 26, 2019.
  1. Jul 26, 2019 at 12:56 PM
    efmason87
    efmason87 [OP] Member
    evan
    2019 Tacoma TRD Off-Road
    non yet
    Hey all,
    Im wondering what you all prefer out there between 285/75/16s and 285/70/16. Looking to size up here soon and while I know there isnt a huge difference between the two Im still interested in hearing suggestions/ recommendations. Also, I know a CMC will be necessary for 285/75/16, but what about with 285/70/26?
    thanks!
  2. Jul 26, 2019 at 1:06 PM
    JudgeJosephDredd
    JudgeJosephDredd I AM THE LAW!
    Crestucky, FL
    2017 TRD Off Road DCSB, 6 spd
    Stuff and Things
    CMC may not be necessary. It all depends on what wheel and or tire you go with; I doubt you will fit them without some sort of lift. I have 285/75/16's Wildpeak AT3's, Level 8 wheels and a 3/2 leveling kit and plenty of room at full lock. I'm assuming you meant "16" and not "26" as I'm relatively certain that doesn't exist... Either way, knobby M/T COULD scrape or rub on a mud guard or body, the biggest thing is clearing the UCA with the bigger tire.
  3. Jul 26, 2019 at 1:11 PM
    efmason87
    evan
    non yet
    So ill be putting on a 2.5-3" king suspension lift prior to getting tires. For wheels im looking at the Stealth F5 16x8" 4.5 bs. Tires it kind of depends, if I can get away without cutting with 285/70/16 then Ill go that route. But if ill need to cut either way ill just size up to 285/75/16 since id be cutting with both sizes.
  4. Jul 26, 2019 at 1:12 PM
    efmason87
    evan
    non yet
    Also I would be going with BGF Ko2's for tires. I will be replacing OEM UCAs with some TC ones
  5. Jul 26, 2019 at 1:43 PM
    JudgeJosephDredd
    Crestucky, FL
    Stuff and Things
    Is your truck under warranty? I wanted to do a suspension lift but that required cutting on the cross member. TacomaWorld said if the stealership puts on the lift they must still honor the warranty if something goes wrong with the parts down the road. The physical location where I get my truck serviced said "any modification to the truck other than cosmetic things will void the warranty". So definitely avoiding cutting would be in your bests interest.
    I can't say for sure if you would rub on the UCA or not but the stock ones would definitely rub on anything bigger than a 265. The KO2's shouldn't take up too much space since they aren't too aggressive. I'd say go for whatever your gut says. Some people here have valuable input, others just argue for the fun of it. It's your truck, might as well make it what you want.
  6. Jul 26, 2019 at 1:46 PM
    efmason87
    evan
    non yet
    yeah still under warranty which is why Id rather not cut if I didnt have to. Maybe the best route is to go with the biggest size possible without cutting while its under warranty, and after its up go crazy with the cutting haha
  7. Jul 27, 2019 at 6:32 AM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
  8. Jul 27, 2019 at 3:34 PM
    efmason87
    evan
    non yet
    What kind of tires? I’ve looked for 285/70/16 in a few different brands and it seems like a lot don’t make it in that size.
  9. Jul 27, 2019 at 5:41 PM
    Inferno!
    El Dorado Hills
    Pro Taco Portland likes this.
  10. May 13, 2024 at 7:58 AM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    What's your concerning and on highway handling like with those tires?
    I'm trying to decide between 16x8 and 17x9 wheels, although the 17x9 would require new tires in which case I'd be better off doing it alongside a lift.
    My immediate goal is to get rid of the spacers while maintaing comparable poke
  11. May 13, 2024 at 8:02 AM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    How's handling and cornering with those? I'm trying to determine if I can get 16" wheels for my current 265/70/16 now or if I should just wait a year or so and do a lift + 17" + 33" tires all at once. I'm mildly concerned about sidewall flex effecting cornering and thing like high speed lane changes with 33's on 16 inches.
  12. May 13, 2024 at 8:05 AM
    king.cong.1119
    king.cong.1119 Well-Known Member
    little confused since I have not seen many 285/70r16s, most of the ones in 285 are either 285/70r17 or 285/65r16
  13. Jun 27, 2024 at 5:13 PM
    Yoooedwin
    Yoooedwin Well-Known Member
    Riverside
    2021 OFF ROAD 4x4
    Avs wind deflector Rough Country Tonneau Tacoma beast interior LEDs Blacked out emblems Pop n lock Led bed lights Led dome lights Gas hole Molle panels Behind the bumper led lightbar
    Did anyone else do this set up? Thinking of doing this. Got some bilstein 6112/5160s coming in once they are in stock.
