This is why you need to replace your VVT screens
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fullboogie, Nov 24, 2019.
  1. Nov 24, 2019 at 3:22 PM
    Fullboogie
    Fullboogie [OP] Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    For you guys working on your VVT solenoids and thinking about not replacing (or just cleaning) your screens, this is after blasting them with brake cleaner and compressed air. It's hard to see the scale in the screens unless you hold them up to the light. Spend the $10 and replace them.
  2. Nov 24, 2019 at 3:54 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Honestly I did not know that existed
    Biscuits, JustJon and Sxottie like this.
  3. Nov 24, 2019 at 4:13 PM
    TacoTuesday1
    FL
    x2
    ight who gon post part number and location diagram
  4. Nov 24, 2019 at 4:15 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Homeboy got the part number in the pic lol
  5. Nov 24, 2019 at 4:36 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Location?
  6. Nov 24, 2019 at 4:49 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    These gunk up the same way vtec solenoid screens do in Hondas, should be added to the maintenance list every once in awhile for sure.
  7. Nov 24, 2019 at 4:51 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    What does this do??
  8. Nov 24, 2019 at 4:53 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Casper66 likes this.
  9. Nov 24, 2019 at 4:57 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
  10. Nov 24, 2019 at 5:01 PM
    azzwethinkweiz
    Tucson, AZ
    Item number: 15678A, one located towards the bottom right and the other towards the bottom left of the diagram. As far as I know its just a secondary filter for the OCV solenoid that controls the variable valve timing. Gunk similar to what builds at the bottom of the oil sump tends to build up in these screens over time. I checked mine on my truck and after 50k and they where both clean... my older Honda would get gunk built up like every 30k though. YMMV
  11. Nov 24, 2019 at 5:04 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    This is why these trucks need regular oil changes. Great info gents!
  12. Nov 24, 2019 at 5:06 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    EDIT:
    Removed post so as not to confuse part numbers.
  13. Nov 24, 2019 at 5:10 PM
    azzwethinkweiz
    Tucson, AZ
    P/N 1567831010 for the screen itself
  14. Nov 24, 2019 at 5:11 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    What all was involved on getting in there to check on the screen when you last did it?
  15. Nov 24, 2019 at 5:14 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Now they’ll be a run on these .... lol
    Lohan808 and TomTwo like this.
  16. Nov 24, 2019 at 5:22 PM
    azzwethinkweiz
    Tucson, AZ
    The passenger side is easy enough to get to, a hex shaped plug on the block almost directly behind the engine oil dipstick. The drivers side is kind of behind the alternator IIRC (its in the same location as the passenger side, just mirrored). I had to swing it out of the way to get to it. Maybe if you are crafty you can get to it without doing that.
    So passenger side you can get to, driver side would require you to at least swing out the alternator.
    jeminyned likes this.
  17. Nov 24, 2019 at 5:33 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Was the engine drained of oil when you did this?
  18. Nov 24, 2019 at 5:35 PM
    azzwethinkweiz
    Tucson, AZ
    I honestly don't remember 100%, it was over 2 years ago but I don't think it was drained... I remember a small dribble of oil coming out but that was it. The screens are high up from the sump.
    fatfurious2 and TomTwo like this.
  19. Nov 24, 2019 at 5:37 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Hmmmmmm. I'll probably do it when I change the oil next. Thanks!
  20. Nov 24, 2019 at 5:40 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
