third brake light questions???
Discussion in '1st Gen. Tacomas (1995-2004)' started by FirstGen Jer, Nov 25, 2015.
  1. Nov 25, 2015 at 12:08 PM
    FirstGen Jer
    FirstGen Jer [OP] Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Ok so I want to put led's in the light. So I took the lens off and realized there where no lights in there from the previous owner. So should I replace with white or red led's? Also Is the light supposed to stay on all the time with the headlights turned on or just when I hit the brakes? I tested the sockets with a extra blue 194 I had laying around and they only work when I hit the brakes. Just wondering if that's normal or if they should come on with the headlights.
  2. Nov 25, 2015 at 4:51 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    For best results, match your LED color to the lens color so, I recommend RED LEDs.
    The third/upper brake light should come on only when you hit the brakes.
  3. Nov 25, 2015 at 4:51 PM
    BigBird
    BigBird Paddock Rat
    Michael
    S.F.Bay Area
    Prerunner
    "Also Is the light supposed to stay on all the time with the headlights turned on or just when I hit the brakes?"
    "..... they only work when I hit the brakes...."
    That's kinda why it's called a "brake light...."
    Hope this clears up any confusion.....
  4. Nov 25, 2015 at 4:56 PM
    FirstGen Jer
    Jeromey
    Thanks, I thought maybe it was like the tail lights and might run all the time and get brighter when you hit the brakes. Sorry noob here.
  5. Nov 25, 2015 at 4:58 PM
    FirstGen Jer
    Jeromey
    Thanks you sir...:thumbsup:
  6. Nov 25, 2015 at 5:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    That's not how brake lights work.
    The tail and brake lights are separate circuits, usually with a dual filament bulb. The brake filament is heavier, thus brighter, than the taillight.
    For your third brake light, I'd test it out with a DVM before sticking LEDs in it. The PO may have been lazy and just not replaced bulbs, or there may be a problem with the fixture that needs attention.
    It's plenty bright with conventional bulbs.
  7. Nov 25, 2015 at 5:16 PM
    FirstGen Jer
    Jeromey
    Thanks...ya I am a total beginner with lights and electrical. I have spyder tailights which are led so I was just wanting to match the light output to those. I had some extra blue 194 led's I stuck in there from my dash mod just to see if the sockets worked and they did. I was thinking it was like my girls subaru third brake light...her subaru light is a constant running light and just gets brighter when you hit the brakes, so it made me think maybe mine had an issue. Thanks for spreading the knowledge though.
  8. Nov 26, 2015 at 8:02 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    If your girl's 3rd brake light is a "constant running light and just gets brighter when you hit the brakes" she has some kind of a electrical issue goin on. All 3rd brake lights only light when the brake pedal is applied.
    FirstGen Jer[OP] likes this.
  9. Nov 27, 2015 at 6:50 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    for reference. the brake lights don't need to light up anything more than the lense in the daytime so people behind you can understand your braking. don't need to get a crazy bright bulb
