Thinking of putting a 3" lift in my 2011 Tacoma TRD Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nashwaak1, Jun 18, 2016.
  1. Jun 18, 2016 at 2:19 PM
    Nashwaak1
    Nashwaak1 [OP] Well-Known Member
    NB, Canada
    Bilstien 5100 at 1.75, WeatherTech Floormats, AVS vent visors
    I recently purchased a used 2011 Tacoma TRD Sport and thinking of putting a 3" lift kit in or a 2" levelling kit and then changing tires to 265/70/17. Just wondering what is the better idea and if someone has before and after pictures of a similar lift? Also I've been doing a lot of reading and not sure what would be the best company to go with for the lift and if I will need to change out the UCAs and if I will need to lower anything?
  2. Jun 18, 2016 at 6:43 PM
    RogueFuel
    RogueFuel Well-Known Member
    there are tons of threads about 3" lifts and which options are available. It all depends on your budget, but the general consensus is to avoid spacer lifts. Bilstein 5100's front and rear are a good option. You can add some 887 springs up front to give the 2.5-3" of lift. You can purchase AAL (add a leafs) for the rear to gain some lift as well. Do some research on the forum and see what you like and what your budget it.
    cheers.
    JLaScala likes this.
  3. Jun 18, 2016 at 6:45 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Don't do a spacer lift.
    From what I have read here, the truck will explode.
  4. Jun 19, 2016 at 6:31 AM
    Nashwaak1
    NB, Canada
    I was considering the Bilstein Adjustable 3" lift kit with 5100 shocks and 2" ToyTec Add-A-Leaf. With this kit should I also purchase new Upper control arms as well and is there any other parts I should get?
  5. Jun 19, 2016 at 6:53 AM
    Pigpen
    Dan
    Northwest Montana
    Get UCAs. Also grease or anti-seize your LCA bolts. Do the front lift with new springs (887) if you want 3", don't do it with pre loading the stock springs (2.5") and then adding a small spacer - it will ride like shit. You'll like the 5100s, they're a fantastic budget shock/ strut. Prepare to address driveline vibrations after lifting your truck.
    PoweredBySoy likes this.
  6. Jun 19, 2016 at 7:03 AM
    Nashwaak1
    NB, Canada
    From what i read i was thinking 885 coils, but I'm new to this so there will be driveline issues as well if go 3"? What if I go only 2 1/2"?
  7. Jun 19, 2016 at 7:14 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    i have the rough country 3" spacer in the front with 2" block in the rear. i like mine. in all fairness if i decided i wanted to start doing some serious off roading then i would follow the normal route around here and do like bilsteins or similar. i don't plan on any serious off roading just logging roads and mud so i think the lift i have now will be fine unless my plans change. people will tell you oh this is bad or that is bad it's really about what works for you both function wise and budget wise. i maintained my factory ride with the lift i installed and am happy with it figure out what you think will work best for you and/or what you like it's your truck
  8. Jun 19, 2016 at 7:23 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Playing devils advocate here. If your not really using the truck in an off road manner don't bother with a lift. There are many negatives to a lifted truck, higher center of gravity (roll over), worse gas mileage, vehicle vibrations, poor gas mileage, handling issues, etc. Personally I don't get why people lift their trucks "for the look" and accept all the negatives. If you need the height increase for off road use, lift away!
  9. Jun 19, 2016 at 11:47 AM
    RogueFuel
    If you're only lifting it 3" the chance of a rollover in relation to stock height is not much of a difference.. Bad gas mileage would come from larger tires, not so much the lift itself.. vibrations would occur sometimes, everyones vehicle is different. Handling issues in my opinion are a lot better than they were stock.
  10. Jun 19, 2016 at 11:53 AM
    jgang
    jgang Well-Known Member
    Had a toytec ultimate kit on my 06, but with my new to me 13, I'm going to wait just a bit and see some more reviews/real world experience with the new bilstein 6112s. 2" is all I need for my purposes and will get me in and out of every place I need to go. Plus, it looks cool. :boink:
  11. Jun 19, 2016 at 11:54 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Toyota puts millions of dollars into these vehicle to make them ride and handle well. I don't think your going to improve the truck by putting a lift in it. Lifts make sense for off road use and make absolutely no sense for driving around on the street.
  12. Jun 19, 2016 at 12:27 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    3" lift on my truck with 285/70/17's and it rides better than it ever thought about stock and handles just as well if not better
  13. Jun 19, 2016 at 12:49 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Call Toyota corporate because you have defide the laws of physics.
  14. Jun 19, 2016 at 12:57 PM
    Nashwaak1
    NB, Canada
    Can you post a picture of what your truck looks like with the 3" Rough Country spacers and 2" blocks. Also what size tires are you using? To be honest I'll be using the truck mostly on paved roads and only going off road during hunting season. When I'll be on logging roads.
  15. Jun 19, 2016 at 1:12 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Most of what you'll read here is a case of "if you do it any other way than what I did, it'll explode" nonsense.
    I installed a 2" front spacer lift with 1" rear blocks and ran that for 50,000+ miles with NO complaints. It rode identical to the stock ride. (TRD OR) The only real negative is, if you off road hard with 'em, you can bottom out the shocks before you run out of suspension travel. That can potentially cause the shocks to break at their lower mounting point. Personally, I know of NO ONE who's actually done that. Best advice is do NOT go jumping dunes with a spacer lift.
    At the 72,000 mile point, I decided the stock shocks were beginning to wear out. I went with Bilstein 5100's set @ 0" lift, then used OME 885 coils for a 2-1/2" (+) lift. On the rear, same 5100's and a Deavers 2" AAL. The ride is a little firmer, but still plenty "plush" for a comfortable highway ride. Off road performance is great. I still don't dive off the tops of dunes....
    I got a tick over 2-1/2" of front lift, and got ideal alignment numbers WITHOUT aftermarket upper control arms.... Rear end is sitting 2" higher than stock ride height. It hauls a load better.....The truck actually rides and drives BETTER than it did in stock form.
    In spite of what you may hear, you do NOT have to spend $5000 to get a good riding lifted truck. With a rear U-bolt flip kit to boot, I spent less than $800 and wouldn't change a thing.
  16. Jun 19, 2016 at 3:46 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
  17. Jun 19, 2016 at 3:50 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    sorry forgot the wheels are 17x9 4.5" bs -12 offset the tires are 285/70/17's and the truck actually does ride better than stock and handle as well or better my usage is the same as yours mainly on road except when i go hunting and some of the logging roads i travel sometimes can be rough but not rock climbing rough
  18. Jun 19, 2016 at 4:05 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Your posts just get more and more stupid. OP had questions and wants a lift - why are you trying to talk him out of it?
    :facepalm:
    A well designed and well installed lift will improve the ride over OEM. Toyota engineered a good suspension but it's not the penultimate in ride quality. The laws of the physics statement :crazy:
    OP I spent a long time pondering suspensions and ended up with the OME kit -887s in front and Dakars in the back. A 3/4 carrier bearing drop got my driveline angles perfect and it rides great. I have an Al bumper, winch and sliders and that setup with top plate spacers got me just under 3" lift. Do your homework and happy building :thumbsup:
    Casper66 and SDtacoTK like this.
  19. Jun 19, 2016 at 4:16 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    The stock suspension components are a compromise. They AREN'T the best riding parts available. They AREN'T the best load carrying parts available. They AREN'T the best off road capable parts available. They ARE a compromise of lower production cost parts capable of handling what a very stock vehicle will see in average conditions. The concept that Toyota "engineered" them to be the highest performing suspension components known to man is laughable at the very least. Simply ridiculous at most..... One need look no further than the simple fact that stock rear leafs are failing and must be replaced in many cases to see just how inferior they are.....
    Oh....and it's DEFIED, not defide.....You'd think a physicist would have at least learned to spell....
    jgang and Casper66 like this.
  20. Jun 19, 2016 at 4:21 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    5100's are softer riding than stock. Paired with 885's makes for less roll in turns and less diving during breaking. Looks better and rides better than stock IMO. I got 2.25"s of lift that way and didn't need UCA's. 1.5" aal returned the rake to 3/4".IMG_20160528_173327102.jpg
    SDtacoTK, Nashwaak1[OP] and Casper66 like this.
