Think I may have over tightened spark plugs. Can I take them out and reuse?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Numismatist, Oct 12, 2019.
  1. Oct 12, 2019 at 10:48 PM
    Numismatist
    Numismatist [OP] New Member
    2008 Red Tacoma 4x4 Base
    Aftermarket Tow Package
    I recently bought a 2008 Tacoma with 140,000 miles. I’ve decided to do all the routine maintenance that was most likely neglected at various points during the trucks life and today that included spark plugs. I got them all removed and replaced with Toyota oem. The truck gave me no indication that I should switch out the plugs, but I suspected they were the original factor plugs (they were) and I figured after 140,000 miles it was about time!
    Here’s the problem: I think I may have over tightened them. The plugs that were factory were extremely tight, requiring a cheater bar to remove so I figured I should make em nice and tight again. I hand screwed the new plugs in, then screwed them in with the wrench as much as I could and then gave them a good jerk, maybe a half turn. Too tight I take it? I also didn’t use anti seize since Toyota specifically says not to and the dealer said if his guys did the swap the plugs wouldn’t see a lick of anti seize but now I’m thinking maybe I should have... I just REALLY don’t want a broken plug in 30,000 miles.
    Anything wrong with taking them back out and then sticking the same plugs back in again? No issues with the crush washer being used up or anything? Or do I need 6 new plugs? Thanks for any help you can give me!
  2. Oct 13, 2019 at 12:17 AM
    JunkYardHD
    JunkYardHD Member
    Nathan
    2005 Access Cab
    oooh, we are just getting started
    I have a nervous tick from reading this.
    If you don't already have a torque wrench either get or borrow one, before doing any more maintenance on your truck.
    I would not take the plugs out now, until your mileage dictates they should be done again. Cranking on them hard like this risks stripping them out. Also, if the dealer said his Tech's don't bother with anti-sieze, I would consider never taking my vehicle there again.
    Next time you do them, follow a guide, like this one:
  3. Oct 13, 2019 at 12:34 AM
    Cory07TRD
    Cory07TRD Well-Known Member
    Cory
    Sacramento, CA
    07 Tacoma TRD
    Body Armor Rock Slider/Step, 5100's, Falken Wildpeak AT3W's
  4. Oct 13, 2019 at 1:15 AM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    Welcome to TW, and damn, you are lucky you didn't strip out any of the threads in the cylinder heads. The old ones were tight because they have been in there for 140,000 miles.
  5. Oct 13, 2019 at 4:51 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Personally I would just back them out just a little and then just snug them up. Anti- seize is not “required “ I would do this now before you get more miles on them. And as long as your not getting any codes you should be fine. I hope you checked your gaps before installing. When I bought mine set every single one was out of gap
    AllenOne1 likes this.
  6. Oct 13, 2019 at 4:55 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Damn..... “gave them a good jerk...half turn” yikes!
    JunkYardHD likes this.
  7. Oct 13, 2019 at 5:55 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    They're gasket seat plugs... for like $2-3 each, I'd pull them out and chuck them. That's based on my imagination of how tight you got them, which I'm kinda surprised you still have threads in the heads, and didn't crack the insulators, if you really wrenched on them that hard.
    TBH I hardly ever use a torque wrench on them myself, although I've put plenty in and have a pretty good feel for how tight they need to be to not risk loosening, but not damage anything. A decent exertion with just your forearm on a standard 3/8 ratchet is all ya need, enough to crush the gasket.
  8. Oct 13, 2019 at 6:00 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    ^^^^ this. You can feel the crush washer crush if you pay attention. I stop when it stops.
  9. Oct 13, 2019 at 6:09 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I think torque us only 15 ft lbs
    EDITED
  10. Oct 13, 2019 at 6:14 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    15 ft/pds
    Plain Jane Taco likes this.
  11. Oct 13, 2019 at 6:21 AM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    for my first gen the manual states 13flbs which is nothing and if you do use anti seize to reduce torque 20%
    Black DOG Lila likes this.
  12. Oct 13, 2019 at 6:23 AM
    Plain Jane Taco
    USA
    Oops. Thanks.
    My wrench starts registering at 20. So I dial up to that and back off a tad
    BillsSR5[QUOTED] likes this.
  13. Oct 13, 2019 at 6:40 AM
    AllenOne1
    AllenOne1 Well-Known Member
    Allen
    Nashville, TN
    2013 TRD Sport / 2018 TRD Off Road
    Gen2: Access cab platform, Gen3: MESO Puddle Lights, KTJO Power Folding Mirrors,
    I would take them out, inspect them closely for any damage to the insulator, if any are cracked replace them all. Then put them back in with no anti seize and torque to spec (which sounds like it should be 15 lbs ft by reading the posts above). Not all torque wrenches will go down to 15 ft lbs so you will have to look for one that does. Even if you torque them to 20 ft lbs you would likely be just fine but it sounds like you are way over that the way you have described your process.
  14. Oct 13, 2019 at 11:04 AM
    Numismatist
    Would the codes be indicative of a bad gasket seal? I did gap them, they were all pretty decent from Toyota though! Technically out of spec but far better than the ones I pulled out that were still running fine, if I didn't have a gapper I would've used them anyways without worrying too much about it (then again, I'm also the guy who was yanking on his spark plugs)
