Thermostat Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoWorldDan, Jun 27, 2022.
  1. Jun 27, 2022 at 12:40 PM
    TacoWorldDan
    TacoWorldDan [OP] Well-Known Member
    2020 Toyota Tacoma SR5 DC V6 A/T
    Was planning on replacing my thermostat at the end of the summer as preventative maintenance and was told by a dealer tech there is a special way of bleeding the cooling system on these new 3rd gens. Does anyone know if there is anything different? Or should I just swap it out and jack the front end up with my coolant funnel and massage the hoses for a bit and run it till all the air is out and it cycles with the heater core flowing? I’m assuming it’s the same as I have been doing for all these years but just wanted a second opinion. Also on the V6 I haven’t looked to see where the housing is for the thermostat but I’m assuming it’s straight forward like most Toyotas, anyone know how difficult it is to access?
  2. Jun 27, 2022 at 12:42 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Why would you replace the thermostat on a 2020? How many miles do you have?
    fdbyrne, joba27n, zoo truck and 9 others like this.
  3. Jun 27, 2022 at 1:13 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Not as straight forward as the good ol' days.
    kahanabob likes this.
  4. Jun 27, 2022 at 1:20 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Agreed, I wouldn’t consider a replacement until 150K, at which point replace hoses and belt also unless you encounter cooling issues. On my 2nd gen I replaced all this, and rad cap and idler bearings, at 100K, and they looked good. Same for the Lexus ES350. Just replace the coolant at 100K and the rest will be good till at least 150K. At 100K, you can remove the belt and inspect the pulley bearings and belt for excessive wear/tear.
    AZ Pete likes this.
  5. Jun 27, 2022 at 1:22 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Not something that is necessarily a part that you would replace as part of preventive maintenance. When they fail, they fail. The one that is in there now is likely to last as long as a replacement.
    jmneill, kahanabob and Big tall dave like this.
  6. Jun 27, 2022 at 1:28 PM
    TacoWorldDan
    Thank You for the links, also I get it will probably last a very long time but when doing preventative maintenance I always weigh the cost and time it takes to replace more than anything. Knowing it’s a simple and cheap process I plan to do it every 3 years when changing out all fluids in the truck including coolant. I live by the moto if I’m already in there I might as well change it out if it’s cheap.
    mquibble likes this.
  7. Jun 27, 2022 at 2:28 PM
    Chuy
    Lakeside, CA
    Silver Taco
    That is your time and money, but I feel compelled to point out to others how wasteful this is. Money-wise and product-wise. Coolant is generally good for 100K, and there are coolant testers you can buy to test the coolant so you can know exactly when it starts to lose it’s effectiveness so you can replace it accordingly.
    To answer your question about bleeding - if your 3.5 is similar to 3.5 in our 07 ES350, there will be a bleeder valve on the intake, near the oil filler cap. I’ll check our ‘18 RX350 later tonight, I believe the 3.5 in it is same as yours.
    MR E30 likes this.
  8. Feb 13, 2023 at 2:45 PM
    Toyotatron
    Toyotatron Well-Known Member
    Megatron
    2019 Tacoma TRD Offroad Quick Sand
    I have a 2019 that has been throwing a thermostat code, the cruise shuts off and check engine light.
    The truck is not heating like it should so i will be swapping out the thermostat this weekend... ish.
    I would have done this without the code and the inconvenience of freezing my ass off in the dead of winter.
    Really didn't need Toyota to shut off one of my favourite things about my Tacoma, adaptive cruise.
    What a PITA.
    Leave it to the imagineers.
    poor driver and Rocksmasher1 like this.
  9. Feb 13, 2023 at 6:54 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Get the trd 180° thermostat.
    Toyotatron likes this.
  10. Feb 19, 2023 at 9:59 AM
    Toyotatron
    Megatron
    Installed the 87°C Thermostat which is 187°F version you are speaking of.
    I opened the radiator drain, about 4 litres drain, removed the spring clamps with a decent size pair of needle nose.
    I left the sensor plugged in, its easier to remove when the housing is removed.
    Copper antisieze on erything.
    The heat feels extra nice after freezing my arse off for an hour doing the install.
  11. Feb 19, 2023 at 10:05 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I had a tundra that was 19 years old, and i never needed to replace the thermostat, or the coolant in nearly 300k miles.
  12. Feb 19, 2023 at 10:13 AM
    Bishop84
    Bishop84 Well-Known Member
    I also recommend removing the drivebelt if you have time, the coolant can wreck older belts and it will squeal. No matter how much you drain the t-stat always has more to puke out.
    faawrenchbndr, Kev250R and Skydvrr like this.
  13. Feb 19, 2023 at 10:17 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    And mark orientation (numbers in / out) so it minimizes squealing.
  14. Feb 20, 2023 at 6:25 AM
    Toyotatron
    Megatron
    I managed good enough without removing the belt. I ll remove it when and if it starts squealing.
    The belt actually helped me catch one of the bolts twice when my big sausage fingers had trouble finding the hole.
    Bolt landed on the belt and trapped it before it disappeared into the abyss.
  15. Mar 6, 2023 at 4:01 PM
    Rocksmasher1
    Rocksmasher1 Member
    Blue Crush Taco
    Ontario, Canada
    2024 Blue Crush Tacoma Sport
    Hello all, my 2020 tossed the coolant low temperature code. Engine light on, cruise not working and remote start not working as well. Just received from Toyota the new water inlet/thermostat. Hope this fixes the problem. 48 000 miles seems early for such a failure.....
    Cronus402 and poor driver like this.
  16. May 8, 2023 at 9:14 PM
    51Beets
    51Beets Well-Known Member
    2020 TRD Offroad
    Too much to list
    Been getting the same code. I’ve reset it a few times because I was having issues with the front sensor and it will run for a month or two without issue.
    now that it’s getting warmer I’ll probably go ahead and replace the thermostat and/or sensor.
  17. May 9, 2023 at 3:11 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Mishimoto makes a coolant vacuum purge and fill kit that makes bleeding super easy. Kit is like $50
  18. Aug 1, 2023 at 8:49 PM
    poor driver
    poor driver New Member
    I have 2018 tossed the coolant low temperature code at around 70K. Engine light on, cruise not working. Just received from Toyota the new water inlet/thermostat. Hope this fixes the problem. dealer ask for 1500 for replacing the thermostat, that is BS, I am going to DIY. my taco is not reliable as I heart....
