Thermostat Jiggle Valve on 3.4L 6 Cyl TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Jan 20, 2014.
  1. Jan 20, 2014 at 11:22 AM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    After replacing the thermostat I was browsing through my repair manual and noticed that the jiggle valve must be up plus-or-minus 15 degrees. I don't recall in which position I installed the thermostat.
    How important is the location of the jiggle valve and if it is not up what will happen?
  2. Jan 20, 2014 at 12:35 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    If air is not bled from system it can overheat. Purpose of jiggle valve is to bleed system of air without having to do it manually.
  3. Jan 20, 2014 at 3:00 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I'm getting a little tired of posting this, so for one last time.
    The Toyota FSM gives that spec for the 4 cyls and "down" (6:00) for the 3.4.
    It is has been widely documented on this and many other forums that placing it "up" on the 3.4 results in about a 10* increase in the ECT sensor reading.
    Read this entire thread before commenting. http://www.yotatech.com/f2/5vz-fe-r...ing-belt-pictures-pleasure-249481/index2.html
    FSM for the 3.4
    e89abd99-5d3d-4e9e-ab8d-44d2296c42ef_zps_6791b275e5670456bcabf6dd42f04bc1cff23918.jpg
  4. Jan 20, 2014 at 3:44 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    I was actually just wondering this the other day... You da man
  5. Jan 21, 2014 at 3:46 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    10-13 degree difference in temps is what I got.
  6. Jan 25, 2014 at 3:04 PM
    skeezix
    Colorado
    1998 Limited
    When I removed the thermostat, the jiggle pin was at the 12 o'clock position and when I installed the new thermostat I placed the jiggle pin at the 12 o'clock position.
    I bought the truck brand new in January of 1998, BTW.
    chirkin likes this.
  7. Feb 20, 2014 at 11:47 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I just replaced rad hoses and thermostat. I was confused after reading in my Haynes manual that it should be at 12 o'clock. Mine was coincidentally came out with it at 7 o'clock. I was confused as I'm the original owner and it's other original thermostat, so I searched here. I trust y'all and the FSM that was referenced so, I put it at 6. Strange about the typo in the Haynes though been using those for 20 years...
  8. Feb 21, 2014 at 7:09 AM
    joemauma
    joemauma Well-Known Member
    Oregon
    Double Cab
    I just picked up a Gates 170 degree thermostat to replace mine and it doesn't have a jiggle valve. Do you guys think this will lead to problems?
    If so, does anyone have a part number for a toyota 170 degree thermostat for the 3.4?
  9. Feb 21, 2014 at 7:16 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Does it have a little "bite" out of the outer circumference? If so, put it in with the bite at 6 o'clock. Or, pays your money at the dealer.
  10. Feb 21, 2014 at 8:51 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
  11. Feb 21, 2024 at 7:08 PM
    Lakeabilene
    Lakeabilene New Member
    I know it's an old thread, but I just went through this, not enough definitive info on it at one place, the jiggle pin goes at the top for the 4 cyl. engine and at the bottom for the 6 cyl. engine. in the Tacoma. So that is why the confusion exists, too many folks comment without telling their engine size and it's very confusing. And don't stress about torque for the bolt and two nuts, you can't get most torque wrenches in there, it's a job for a stubbie ratchet for sure. but it would be about 6 ft pounds if you did, very little force needed, just tighten up and stop. if you drop one of the nuts you might add an hour to the process, took me two hours total. if the tstat was clogged with rubber pieces, someone probably used USA antifreeze marked, use in ALL cars. it has stuff that will destroy Japanese components, always use the Japanese stuff, it's a delayed damage and nobody gets it. and a year after someone changed the anti freeze good luck convincing them they used the bad stuff and now owe you repairs. the bypass line had to be replaced also, due to the same issue.
