Thermostat As Maintenance ?
Discussion in '4 Cylinder' started by george3, Jul 23, 2022.
  1. Jul 23, 2022 at 10:16 AM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Do you guys change your thermostat as maintenance - if so at what mileage ? How hard is it ? How much time ? Anybody get in trouble because they didn't change it and it got stuck ? Any better link ? Any reply and or links appreciated.
    https://www.youtube.com/watch?v=858i1Ce0QIE
  2. Jul 23, 2022 at 10:24 AM
    Bishop84
    Bishop84 Well-Known Member
    They don't get stuck like they used to in the old days.
    All you need to do with cooling is, check for leaks, replace coolant every 10 years or so, wash the rad from time to time.
    If the t-stat is stuck, you either have no cabin heat, or it doesn't get up to temp. If your heat gauge goes to center and you have cabin heat. The t-stat is fine and no need to replace.
    a400ryan, AxisCab and SR-71A like this.
  3. Jul 23, 2022 at 10:39 AM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    Years ago I changed the thermostat on an 1989 Plymouth Voyager V6. Apples-Oranges I know, but it was stuck open in the winter and I put cardboard in front of the radiator. One of the bolts snapped. Luckily my neighbor at the time worked at a national auto repair chain. Went there to get a tap & die set. Also 'Easy Out', to get the broken bolt out. Should be called 'Diffi-out' - not so easy. Anyway I made a new thread 1 mm larger than the original.
    I'm posting this because if the thermostat is replaced during cold weather, you may want to warm the engine at least a little bit. Then again, maybe temperature had nothing to do with it. And - as stated above, probably best to just leave it alone if there's no signs of it not working right.
    Key-Rei likes this.
  4. Jul 23, 2022 at 11:32 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    On my V6, I replaced hoses and thermostat when I changed the coolant at 100K. Did same on wife’s 07 Lexus. That was probably too soon. The hoses and thermostat looked in real good shape. I now recommend wait till second coolant replacement, at 150K. Replace belt then also.
  5. Jul 23, 2022 at 4:46 PM
    george3
    New Jersey
    Thanks. How do YOU clean the radiator ? Do you use a chemical cleaner and a sprayer ? If you use a pressure washer you could bend the fins. Thanks .
  6. Jul 23, 2022 at 4:50 PM
    Bishop84
    Honestly I pressure wash without worrying, but I keep the distance. The weak fins of yesteryears are gone. I wash customers rads every day without issue.
    If I'm cleaning between the rad and ac condenser I half the pressure to the wand using the valve we have. But its rare I need to clean between the two rads.
  7. Jul 23, 2022 at 4:51 PM
    george3
    New Jersey
    Thanks - I just helped my Brother in Law change out the pipe - . I don't think we changed the thermostat - I'll check. He has 250K and it doesn't over heat.
  8. Jul 23, 2022 at 4:55 PM
    george3
    New Jersey
    Thanks for the reply and information. I guess I'll be OK if real careful with the pressure.
  9. Jul 23, 2022 at 4:56 PM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    My prior vehicle was a 2004 Ford and had the original heater hoses and thermostat. I did change the radiator hoses but that was about two years ago.
  10. Jul 23, 2022 at 4:57 PM
    george3
    New Jersey
    How do you know if the hoses need to be replaced. I have 150K now and they seem 2 B OK. Thanks.
  11. Jul 23, 2022 at 6:30 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I've done mine twice now. Each time I've flushed the coolant I changed it. Changed first time at 75k, 2nd at 150k and will do it again at 225k. Cheap part and easy to do.
  12. Jul 23, 2022 at 6:49 PM
    george3
    New Jersey
    Wow - nice post. Mine look pretty good especially compared to the pictures you posted.
  13. Jul 23, 2022 at 6:54 PM
    george3
    New Jersey
    Did you use OEM or after market ?
  14. Jul 24, 2022 at 5:31 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    +1 on fill ups and oil check. Head under the hood looking around. My wife has a RAV 4 and loves the dealership (?) but about once a week, I open the hod and take a look.
  15. Jul 24, 2022 at 6:57 AM
    george3
    New Jersey
    Ha Ha - hope U have lots of $$ to keep your wife happy going to the Stealership !
    JGO[QUOTED] likes this.
  16. Jul 24, 2022 at 11:49 AM
    Notoneiota
    Oakdale, MN
    Aftermarket. Whatever the local parts store had in stock.
  17. Jul 24, 2022 at 12:11 PM
    JGO
    She is really a kind woman. She does not like to watch me drag out the jackstands and floor jack in order to douse myself with dirty oil, cursing that low slung auto all the while. And if I was in California, I'd get cancer.
  18. Jul 24, 2022 at 4:14 PM
    george3
    New Jersey
    "And if I was in California, I'd get cancer." LOL
  19. Jul 24, 2022 at 4:14 PM
    george3
    New Jersey
    Thanks.
  20. Jul 27, 2022 at 10:41 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I changed the thermostat on my 2.7 at 170k while replacing the cracked coolant bypass pipe. Never had an issue with the factory thermostat I pulled out, kept it in the parts box. Because thermostats have moving parts, I've always believed they are a wear part that need periodic replacement, like a fan clutch or a belt tensioner. Also they are cheap and easy to replace, on most vehicles anyway.
    The only time I ever had a thermostat issue was when I put a "failsafe" thermostat in my 1992 Thunderbird. (I was young and thought it would be a good idea... you know, for safety LOL.) The failsafe thermostat immediately locked in the open position during the very first drive, preventing the engine from reaching full temperature after that. This taught me to use standard thermostats rated at the standard engine temperature. Never had an issue since.
