Theory about dash speakers. Stock vs. Kicker-Subaru / DS18 PRO-ST
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RDW59565, May 11, 2022.
  1. May 11, 2022 at 12:37 PM
    RDW59565
    RDW59565 [OP] Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    There are a lot of posts about swapping the dash speakers that universally describe a noticeable improvement. Some have gone as far as doing some cutting and installing 3-1/2" coax speakers there.
    In poking around these posts and looking at the photos, it appears that the factory dash tweeter has a 2.2 uF capacitor for a high-pass filter. I haven't seen any coils, so I assume it is a 1st order filter. This would mean that the high-pass filter is attenuating any sound below about 18,000 hz at a rate of 6db per octave.
    In plain English, this means that your dog might be hearing what is coming out of the dash speakers, but you aren't hearing much. The cutoff is at the upper range of human hearing. Most tweeter high-pass filters are in the 4,000 to 5,000 hz range. If you listen to mp3 files there probably isn't much of anything coming out of them in the first place.
    Replacing these speakers with just about ANYTHING would result in a noticeable improvement. An additional benefit is that it should also help move the sound stage up and away from your ankles. The popular Kicker-Subaru and DS18 Pro-ST swaps are budget friendly mods that should make a real difference.
    I haven't been able to confirm any of this first-hand.....yet. I'm still patiently waiting for my truck.
  2. May 11, 2022 at 12:43 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    1st thing I did after I got my truck. Subarus still sound great.
  3. May 11, 2022 at 12:53 PM
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
    Your theory makes perfect sense . It’s starts with the tweeters….Leads to a door speaker upgrade…. And it’s ending for me with a Key200.4, a Key500.1 and a 10” down firing sub lol. Easy come easy go
  4. May 11, 2022 at 1:35 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I dont know, I am very happy with stock speakers in my taco. Nice clean sound with good base.
    BMH likes this.
  5. May 11, 2022 at 3:56 PM
    TacoLin1234
    TacoLin1234 Well-Known Member
    Lance
    Sutherlin, OR
    2020 TRD Sport
    I did the Subaru tweeter up grade speakers. Best decision I ever made for improved sound quality.
  6. May 11, 2022 at 4:00 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I agree with you...I spent the dough...can't even hear em. The 6x9 Rockford Fosgate speakers in the rear, pretty much dominate. being pushed with 300 watts.
    RDW59565[QUOTED][OP] likes this.
  7. May 11, 2022 at 4:18 PM
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    The tweeter upgrade by itself provided me with a noticeable difference. The front doors made another difference. The rear doors are practically useless with the way the head unit splits everything.
    For myself, I have noticed that the sound quality also varies by source. Pandora is pretty good but it too, varies song to song. If I was listening to FM radio all the time, I wouldn’t bother putting much money into the system
    RDW59565[OP] likes this.
  8. May 11, 2022 at 6:58 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The Kicker/Subaru tweeters were a worthy upgrade for me, they improved the brightness of the sound and moved it off the floor.
    That said my daily has an Alpine head unit, Alpine power pack 45 wpc amp with Kicker and Rockford Fosgate speakers, compared to that system the Tacoma sounds like there is a blanket in front of the speakers, it really misses the details.
    shakerhood and RDW59565[OP] like this.
  9. May 11, 2022 at 8:12 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I did the full Kicker speaker upgrade. It definitely cleaned up the sound. The new problem was the underpowered headunit, so I installed an Alpine Powerpack behind it. This woke up the fronts... the rears... that's a different story. Then to finish it off I fibreglassed a box into the right rear pocket for a shallow 10" sub powered by Hertz D-Power sub amp. That definitely improved the bass. There is still the problem of the rear speaker output, and the bass roll off as volume increases.... for now I will leave it... but I will consider options down the road...
  10. Dec 19, 2022 at 3:23 PM
    JerrTaco
    JerrTaco New Member
    Jerry
    2020 Off Road
    I just ordered the CS series kickers to do the full plug and play upgrade, why are your back speakers having an issue with power if you have the Powerpack? Curious because I was thinking of adding some sort of amp myself and figured any 4 channel would do the trick.
  11. Dec 19, 2022 at 5:19 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    The output from the HU to the rear speakers is so weak, the amp improves it but more to a level that I would have expected from the stock HU... so still pathetic...
    JerrTaco[QUOTED] likes this.
  12. Dec 19, 2022 at 5:26 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    I replaced mine with the DS18, cheaper than the subaru kicker set, sound great and installed easily. I didn’t realize how bad my stock dash speakers were until I pulled them. Go DS18 and be done with it
    Kolohe07 and JTScribe52 like this.
  13. Dec 19, 2022 at 6:52 PM
    Bigfun33
    Bigfun33 Member
    When you get your truck definitely get the Subaru dash speakers. Install only one and fade L & R and you will hear the difference!
    PS you can do the install without removing the A pillar trim
  14. Dec 20, 2022 at 7:10 PM
    mpritc1019
    mpritc1019 Member
    How? I have the tweeters but scared to remove the A pillar bc of the airbag. I have a 23 SR5 if that matters.
  15. Dec 20, 2022 at 7:13 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Unplug the Battery.....
    AmateurTaco1313 likes this.
  16. Dec 20, 2022 at 7:16 PM
    Bigfun33
    Bigfun33 Member
    If you use a plastic flat pry tool to remove the speaker covers you will be able to remove the original speakers. I think the speaker bolts are 10mm
    AmateurTaco1313 and mpritc1019 like this.
  17. Dec 20, 2022 at 7:29 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Welcome to the forum :hattip:
    Disconnect the negative terminal of the battery before doing any electric work on these trucks, with no power the air bag system is disabled.
    BTW: The electric systems on these trucks are very sensitive, people have started out to replace the map lights, made a spark and ended up with an expensive dealer only repair.
  18. Dec 20, 2022 at 7:30 PM
    AmateurTaco1313
    ROK
    Enough for now
    I used a thin curved pick tool, imagine like something a dentist uses. Didn’t scratch the plastic and was enough pressure to pull the pieces up
    mpritc1019 likes this.
  19. Dec 21, 2022 at 12:50 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I used a Rockford 2 way speaker/tweeter combo instead of just the tweeter only. The sound is much better and balanced. The tweeter upgrade does add some nice highs but doing a 2 way gets the benefit of a speaker too. I then added a RF 8 in sub and amp combo that fits behind the rear pass side seat and looks great for that factory oem look. Sound is nice, clear and enough thump for me.
  20. Dec 22, 2022 at 6:57 AM
    mpritc1019
    mpritc1019 Member
    W
    Was the tweeter speaker combo plug and play? Did you change the front door speaker?
