Theft deterrent light keeps blinking even when engine is ON.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Robinshen, Dec 4, 2012.
  1. Dec 4, 2012 at 8:09 AM
    Robinshen
    Robinshen [OP] Member
    California
    Tacoma
    Lost my key, had a new one made. Chip programed by lock smith. Works great. But now the theft deterrent light on the dash keeps blinking even when the truck is running. Anyone know how to reset this thing? Thanks.
  2. Dec 4, 2012 at 8:22 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    What year is your truck? I've never heard of this issue before. If you truck is still under warranty I'd call the dealer cause I'm sure they can fix it.
  3. Dec 4, 2012 at 9:17 AM
    Robinshen
    California
    Tacoma
    truck is a 2007, was hoping to avoid dealership. I would have to take off from work to do that and when I called them, they acted pretty surprised. So I suspect it will be a fat load of diagnostics. Not under warranty anymore.
  4. Dec 4, 2012 at 9:20 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My suggestion is that the immobilizer portion of the vehicle is acting up. Is it keeping your car from starting?
  5. Dec 4, 2012 at 9:24 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You got the key programmed at an independent locksmith rather than the dealer? Surprised that would work (kinda defeats the purpose...).
  6. Dec 4, 2012 at 10:03 AM
    Robinshen
    California
    Tacoma
    Car is running great. No problems. Just want the blinking light to go away when I am driving.
  7. Dec 4, 2012 at 10:05 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting.... I'm surprised its not causing starting issues.
    My suggestion. Do the tape mod? :D
    Haha in all seriously, you might have to make a run to the dealer, try disconnecting your battery and touching the positive and negative terminals for 10 seconds. Then try reconnecting it all back up and see if that makes a difference before you let the stealer take your $$
  8. Dec 4, 2012 at 10:06 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Put a piece of black electrical tape on it. Problem solved.
    TexasWhiteIce likes this.
  9. Dec 4, 2012 at 10:16 AM
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
  10. Dec 4, 2012 at 11:15 AM
    Robinshen
    California
    Tacoma
    I will try the battery disconnect thing. I guess it can't hurt. Hate going to the dealer for something so trivial.
  11. Dec 4, 2012 at 11:37 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I know, it's stupid, I agree.
  12. Dec 4, 2012 at 11:40 AM
    BamaToy1997
    Bill
    Navarre, FL
    I would contact the locksmith. It sounds to me like the key was not properly programmed.
  13. Dec 5, 2012 at 6:46 AM
    Robinshen
    California
    Tacoma
    For anyone else with this problem. Got a suggestiong that worked. Take the key, put it in the ignition, turn it clockwise for two clicks. Repeat 10 times quickly. Resets the theft deterrent. Problem solved.
    Marc70, MDub07 and OffroadToy like this.
  14. Sep 30, 2016 at 7:28 AM
    grvygirl83
    grvygirl83 New Member
    05 Tacoma TRD Sport
    Had the same exact thing happen with my 05 Tacoma and ^^^^ worked perfect. Don't waste your money at a dealer.
  15. Nov 30, 2017 at 7:46 AM
    MDub07
    MDub07 Well-Known Member
    KS
    2012 Tacoma AC 4WD SR5 SSM
    Thanks for the post Robinshen. I have a 07 Tacoma and recently programmed a new key using a $12 programmer tool from ebay and also added another remote. Truck, keys and remote worked fine but immobilizer light stayed on when truck was off and flashed when driving, cycling the key on and off quickly per your post seems to have fixed it. Thanks.
  16. Jun 6, 2018 at 2:29 PM
    pdxptw
    pdxptw Well-Known Member
    Patrick
    Denver, Co
    2021 TRD PRO 6M
    Thank You!
    This was driving me nuts! Dealer had no clue. Worked like a charm.
  17. Jan 2, 2021 at 1:01 PM
    SamT
    SamT New Member
    Sam
    Great Fix! Thank you. My 2010 Tacoma was blinking for 2 days with the truck off & on. Craziness. The 10 times on and off procedure works. Thanks again.
  18. Jan 2, 2021 at 1:21 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Are we talking the Immobilizer light?
    I want to get some spare keys made, will I need to do this for each chipped key?
  19. Jan 2, 2021 at 3:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  20. Mar 26, 2021 at 2:36 PM
    Toyo4200
    Toyo4200 New Member
    Toyo
    2005 Tacoma
    Non
    Just wanted to say thank you to Robinson, Asked the dealer about my light staying on they told me that the couldn’t fixed it, took it the the lock smith who did my keys and nothing.. took your advice turn the switch on and off 10 time and it work.. thank you for posting it here..
