The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Mar 22, 2024 at 2:56 PM
    #5241
    thatyotadude
    thatyotadude New Member
    2010 Barcelona Red Tacoma
    I called my local dealership to inquire about this and the parts guy told me he needed to call Toyota and get back to me. What he told me was that the new part number was for a different part that was produced to deal with the TSB issue, but they also fixed the issue in the original part after the TSB which is why now there is only one (the old) part number. Supposedly assemblies ordered with the pre TSB part number now no longer have the melting DRL issue. I think I'm still going to throw LEDs in my DRLs just to be sure, but this is the most recent information I have as of today.
  2. Mar 22, 2024 at 3:20 PM
    #5242
    Tiedie
    Tiedie PVC Pipe Pressure washer extraordinaire
    David
    WFOY
    09 4X4
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Look just do what I did and it cost me $40.00 and 30 minutes of my time and no more DRL's or LEDs.
    I used relay # 81980-02030 and JUNCTIONBLOCK (TOYOTA PART) #82671-30360 here is the write up.
    https://www.tacomaworld.com/threads/how-to-disable-2011-drls.113172/page-2#post-4087308
    Bought the relay from eBay.
  3. Mar 22, 2024 at 5:11 PM
    #5243
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Sounds like a suspect explanation. The entire TSB is around the new part number being the fixed version. Why would they discontinue the fixed part number and revert to the original flawed part number (now claiming it is the fixed version), it doesn’t make sense. The DRLs between the flawed and fixed lamps are distinctly different, if you purchase them, you can share the image and it would be easy to determine if it is the fixed or flawed lamp.
    Also, welcome to TW!
    TacoLolz and Tiedie like this.
  4. Mar 22, 2024 at 5:20 PM
    #5244
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    I've had the wiring harness and bulbs for awhile now. Haven't installed it. I've actually considered selling it.
  5. Mar 22, 2024 at 5:22 PM
    #5245
    Tiedie
    David
    WFOY
    09 4X4
    Install it you'll love it. Just do it.
    szidls and easleycrawler[QUOTED] like this.
  6. Mar 22, 2024 at 5:26 PM
    #5246
    easleycrawler
    Travis
    2014 RC Taco 4wd
    I may get around to it. I did like the led brightness of my tundra. I know these aren't led, but the brightness should be close.
  7. Mar 22, 2024 at 5:28 PM
    #5247
    Tiedie
    David
    WFOY
    09 4X4
    I don't drive much in the dark right now but when I have I was impressed with them.
    easleycrawler[QUOTED] likes this.
  8. Mar 22, 2024 at 5:30 PM
    #5248
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    You might actually find that they put out more light than LEDs. Trust me on that one.
  9. Mar 22, 2024 at 5:35 PM
    #5249
    AllTacosFloat
    AllTacosFloat Well-Known Member
    Boston ish
    Has lockers and a skewp
    Really, it’s a huge difference and only takes a few minutes. Do it!
  10. Mar 22, 2024 at 5:36 PM
    #5250
    easleycrawler
    Travis
    2014 RC Taco 4wd
    That's the main reason I haven't got around to installing them yet, I don't do much night driving either.
  11. Mar 22, 2024 at 5:40 PM
    #5251
    Tiedie
    David
    WFOY
    09 4X4
    Do it! Peer pressure
  12. Mar 22, 2024 at 5:48 PM
    #5252
    easleycrawler
    Travis
    2014 RC Taco 4wd
    Lol. Yall have about talked me into.
  13. Mar 22, 2024 at 5:48 PM
    #5253
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    I don’t have data on the Tundra OEM LEDs, but this upgrade is brighter than the 3rd Gen OEM LEDs, which are also fantastic.
    Tiedie and easleycrawler[QUOTED] like this.
  14. Mar 22, 2024 at 5:55 PM
    #5254
    Tiedie
    David
    WFOY
    09 4X4
    Tell em @crashnburn80.
    Don't make me figure a way to come down to SC and help you put it in. But then again I do need to go to PSA to shoot some at the range in Greenville.
    Oh off topic. Do it
  15. Mar 22, 2024 at 6:01 PM
    #5255
    easleycrawler
    Travis
    2014 RC Taco 4wd
    If a nice weekend ever happens, I'm gonna install it.
    Tiedie[QUOTED] likes this.
  16. Mar 22, 2024 at 6:08 PM
    #5256
    Tiedie
    David
    WFOY
    09 4X4
    Spring's here weekends are going to be nice.
  17. Mar 22, 2024 at 6:20 PM
    #5257
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Once you do, nearly every other vehicles headlights will feel like a downgrade.
  18. Mar 25, 2024 at 8:36 PM
    #5258
    szidls
    szidls Well-Known Member
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
  19. Apr 4, 2024 at 6:57 AM
    #5259
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    So I’ve had this kit installed for maybe 2 months now and it’s great, but my high beam indicator just started coming on when just my low beams are on. If I switch to high beams, they come on and the indicator brightens. So both low and high beam work, but the high beam indicator is essentially on all the time. Any idea what this could be?
    It just started doing this a few days ago, everything worked fine when I first installed.
  20. Apr 4, 2024 at 7:10 AM
    #5260
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    What year is your truck? I think somewherebmid-gen they changed from a ground switched to power switched circuit, and you're describing how my first (homemade) relay hsrness acted when Ininstalled it in my 4runner (before I realized it was ground switched, and I made a relay harness for power switched circuits)
