The Tacoma 1GR-FE Story
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skittles93, Jan 21, 2018.
  1. Jan 21, 2018 at 12:40 PM
    Skittles93
    Skittles93 [OP] 'Member
    Novato CA
    TRD OR SB 4x4 (sold) 19 4runner TRD Pro
    Frankenstein Mid-Travel Kit, sPod, Relentless Custom Baja Bumper, Relentless: Sliders, T-case skid, rear bumper, tailgate reinforcement, Rago Fab: Bed Channel Stiffeners, SCS 16" wheels, BFG KO2 275,75,R16, Diff breather mod, A/C hose extension mod, Custom exhaust routing. (Sold)
    The 1GR-FE is a naturally aspirated port injected 4.0L displacement V6 gasoline engine produced by Toyota for their light duty trucks. This engine can be found reliably propelling Toyota trucks in the most inhospitable environments of Africa, South America, North America, and the Middle East. Toyota introduced their GR family of engines with the 1GR-FE in 2002. At inception, the engine was put into the U.S. spec Toyota 4Runner and global spec Land Cruiser. The engine then slowly made its way into the Tacoma, Tundra, FJ, and many more of Toyota’s light duty trucks. Today, in 2018, the engine can still be found in the Hilux, Land Cruiser 70, and 4Runner. Over the engine’s 16 year life it has been relatively unchanged. Beginning in 2009 Toyota introduced a dual variable valve timing technology that could alter timing for both the intake and exhaust camshaft. The introduction of this technology increased horsepower (236-270 hp) and torque (266-278 lb-ft) while having a negligible impact on fuel economy per EPA economy predictions. Most other changes to the engine were in regards to more strict emissions standards, such as the introduction of a secondary air injection system for 2012 model year vehicles. The 1GR-FE is arguably a low stress engine when compared to most other automobile powertrains available today, likely lending to its reliable nature. The 1GR-FE in the Toyota Tacoma (equipped with VVT on the intake camshaft only) produces 236 horsepower in a 4.0L package or 59 horsepower per liter. In comparison a 2010 CR-V with a 1.8L I4 produces 148 horsepower or 82 horsepower per liter, thats a whole 23 more horsepower per liter than the 1GR-FE. At the other end of the spectrum is the Lexus LFA with the 1LR-GUE 4.8L V10 that produces 552 horsepower or 115 horsepower per liter, almost double what the 1GR-FE produces per displacement. The reliability of the 1GR-FE is legendary. In 2016 a 2007 model year Toyota Tundra equipped with the 1GR-FE reached 1,000,000 miles on the original engine, reportedly without ever performing an engine rebuild or overhaul. The only faults commonly reported on TacomaWorld are issues with the head gasket, with many drivers reporting high mileage (over 250K) with no gasket related or other issues while performing purely general maintenance. There are several reports of catastrophic engine failure resulting from a myriad of issues but there is no common denominator for the the fault causing those failures. A mechanical complaint that has not been deemed a reliability or performance issue is excessively loud valve clatter which has been reported by many Tacoma (1GR-FE only) operators.
    The 1GR-FE has a cast aluminum block with cast-iron liners and aluminum heads with steel laminate gaskets. The crankshaft is forged steel with aluminum alloy bearings. The connecting rods are forged steel. The pistons are aluminum alloy and sport a “taper-squish” style cylinder head. The camshafts in the DOHC design are cast iron alloy and utilize maintenance free timing chains as opposed to a timing belt. The engine utilizes siamese style intake ports and a “drive by wire” or “linkless” butterfly intake valve. The 1GR-FE is port injected and uses sequential injection with 12 hole injectors placed ahead of the intake valves for each cylinder. There are 2 intake valves and 2 exhaust valves per cylinder, 24 in total. Ignition is coil on plug and uses Denso K20HR-U11 spark plugs with a firing order of 1-2-3-4-5-6. The exhaust system in pre-2012 MY trucks uses three way catalysts with both upstream and downstream O2 sensors. In 2012 secondary air injection was implemented to heat up the catalysts faster and facilitate complete combustion of unburned hydrocarbons.
    Specs:
    Wet Weight: 370lbs
    Style: 24-valve DOHC 60 degree V6
    Oil Capacity: 5.2 liters/ 5.5 US quarts, uses 5W-30
    Coolant Capacity: 9.8L/ 10.4 US quarts, uses Toyota Long Life coolant
    Compression Ratio: 10.0:1 (VVT-i)/ 10.4:1 (Dual VVT-i)
    HP: 236HP (VVT-i)/ 270HP (Dual VVT-i)
    Torque: 266lb-ft (VVT-i)/ 278lb-ft (Dual VVT-i)
    Emissions (USA): Low Emissions Vehicle (LEV) (pre-2012)/ Ultra Low Emissions Vehicle (ULEV) (2012- )
    Emissions (Global): EURO-II
    Fuel Consumption per Fuelly for Tacoma (05-15): 17.6 MPG/ 13.36L/100KM
    Carbon Dioxide Emissions: 1.1lbs/mile / 310g/km
    Fuel consumption at idle: 0.4 gallons/ hour (A/C OFF) / 0.55 gallons/ hour (A/C ON)
  2. Jan 21, 2018 at 1:14 PM
    devkurf
    devkurf Member at Large
    midwest
  3. Jan 21, 2018 at 2:02 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    5w30 oil not 10w30 is recommended.
  4. Jan 21, 2018 at 4:44 PM
    Skittles93
    Novato CA
    Whoops yes 5W-30, good catch.
    650H1 and Stryker420 like this.
  5. May 9, 2018 at 10:42 AM
    Turbomeister
    Turbomeister Member
    Missouri
    09 AC V6 AT TRD OR
    DTRL Switch Mod Pioneer DEH-7800BHS
    One small thing: The Million Mile Tundra had the 4.7L V8, not the 4.0L V6 1GR-FE used on our trucks. This point is especially confusing because several sources, including Jalopnik, claimed it had the V6. This video was finally proof of it having the V8:
    https://youtu.be/TL7fyyUNRmA?t=77
  6. May 9, 2018 at 1:05 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    My Honda Silver Wing 600 (582 cc) puts out 93 HP/L; making them both he Toyota and Honda engines slackers...
  7. May 9, 2018 at 1:11 PM
    Muddinfun
    Muddinfun Well-Known Member
    A quart Gatorade bottle screws perfectly into the oil fill neck on the 1GR-FE.
    t1m829, grydsrt, Ouranos and 8 others like this.
  8. May 10, 2018 at 8:06 PM
    Skittles93
    Novato CA
    Ive never tried that, isnt the fill neck threaded on the inner part though?
  9. May 10, 2018 at 8:07 PM
    Skittles93
    Novato CA
    Yeah, I needed to correct that. I saw the video a while after I posted this. All of the info I gleamed before then was that it was the 4.0L
  10. May 10, 2018 at 8:41 PM
    Muddinfun
    Yes, cut the bottom off the Gatorade bottle. Screw the bottle into fill neck. Perfect funnel.
  11. Sep 6, 2023 at 9:10 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    I have a friend that keeps saying that not all the 4.0 have forged crank is this true I find it hard to believe they would switch it up
