The squealing 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jahyota, Apr 16, 2017.
  1. Apr 16, 2017 at 7:06 AM
    Jahyota
    Jahyota [OP] Well-Known Member
    Jake
    Denver
    '16 TRD OR DCLB quicksand
    Went wheeling last weekend, hit a decent amount of big puddles, got caught up in some snow, and drove about 1.5 hours on the highway each direction.
    Everything was fine. Next morning (Monday) when I started the truck the serp belt was squealing. Water tested and I'm leaning towards a misaligned belt or loose pulley.
    Looks as if idler pulley 2 on the top end has a slight wobble. Confused as to how it could start acting up, parked over night. Maybe my tensioner barely lost its tension. Can I get some input on what you guys see under your own hoods?
    I've done a fair share of serp belts, but never a Tacoma and definitely not a 3rd gen yet. Looks like a god damn nightmare.
  2. Apr 16, 2017 at 7:10 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Havent done the belt on my truck but you are pretty sure its the belt? I thought my belt was chirping occasionally but its actually coming from the high pressure fuel pump right in the area and deemed "normal"
  3. Apr 16, 2017 at 7:18 AM
    Jahyota
    Jake
    Denver
    Oh no, it's the belt. it's loud and obnoxious. A little squirt of water and it shuts up for a couple seconds. I've got an idea as to the exact problem. Just wanted any mechanical advice. Looks like a few things need to be removed before you can even attempt to get the belt outta there.
    Ya that's Leighla. She's an American Bully Boxer.
  4. Apr 16, 2017 at 7:30 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    I would let it go and drive it for a while, maybe it will go away, could have gotten ecessively wet driving thru the puddles, needs to dry out
    Jahyota[OP] likes this.
  5. Apr 16, 2017 at 7:34 AM
    Jahyota
    Jake
    Denver
    I can try that. I've been getting a ride to work last few days so I didn't risk any other potential wearing or damage. There's literally not a single thing online in regards to belt work for the 3rd gens. So frustrating. I'm good with mechanics but I'm not tryna remove half the front end of my year old truck lol I'll leave it to the pros.
    cblow5 likes this.
  6. Apr 16, 2017 at 7:53 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    OP sounds like you need a new skid plate... and a new belt!
  7. Apr 16, 2017 at 7:54 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It should be under warranty so probably best to let the dealer have a look.
  8. Apr 16, 2017 at 7:59 AM
    Jahyota
    Jake
    Denver
    Ya I'll try to bring it in tomorrow.
    Some of those puddles were more like water crossings. So hopefully a new belt, clean the pulleys. Don't think my AC compressor ,alternator, or water pump pulleys would be going out in 27,000 miles. But I've been surprised before
    shakerhood likes this.
  9. Feb 19, 2018 at 5:38 PM
    kupaa1
    kupaa1 Well-Known Member
    Hawaii
    2016 Tacoma TRD Sport Access Cab
    My belt started squealing too. Chirps when I accelerate from stop then goes away. But really screams going up a steep hill. I don't go wheeling. So, no idea what started this. Tried belt conditioner. No help. Can't find any help online on how to adjust tensioner for 3rd gen. Less than 9000 miles.
  10. Feb 19, 2018 at 5:48 PM
    phsycle
    phsycle Well-Known Member
    CA
    As noted above, it’s still under warranty. Don’t try any more home remedies. Take it to the dealer.
    AKGSD and shakerhood like this.
  11. Feb 19, 2018 at 5:56 PM
    blown ION
    blown ION Well-Known Member
    NJ
    2017 TRD PRO White
    There's a product, almost a fat wax-like crayon thing(yes, that's exactly what they call it lol)that dealerships/mechanics will use on squeaky belts. Never tried it but it does exist. May or may not be what you need.
  12. Feb 19, 2018 at 6:10 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    For that, I just use a bar of soap. Don't think that is the issue here though.
    AKGSD likes this.
  13. Mar 22, 2020 at 10:31 AM
    Cbake82
    Cbake82 New Member
    Carl
    2018 Tacoma SR
    Lifted on 33's currently
    Mine started doing the same thing yesterday. I am also seeing a weird wobble on the upper pulley. What came of this? Im a 2018 SR with 48k.
    jcmotr likes this.
  14. Mar 22, 2020 at 11:00 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Also just started having this issue, suspect the upper (driver side) idler pulley is the culprit. I'm getting close to my 20k service, so I'll probably just have them look at it then.
    jcmotr likes this.
  15. Mar 22, 2020 at 11:07 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Did you ever figure out what it was?
    jcmotr likes this.
  16. Mar 22, 2020 at 3:50 PM
    jcmotr
    jcmotr Well-Known Member
    I’ve had this issue as well. It started at around 18k miles, currently 26,000.
    Squeal on and off, increases with acceleration (even while parked) and goes away when I spray water directly to the belt.
    It still does it intermittently, especially after it rains or off-roading, which I can assume is the belt getting dirty.
    I’ve researched this forum quite extensively and it has guided me to the high pressure fuel pump and pulley. I also have a slight play in the pulley, but others mention it’s normal.
    Ultimately I believe it’s the belt - I mean, why else would the chirp stop when I spray water, right?
    So, I went to the dealership and asked them to take a look at it. They quoted 135dlls for “diagnosis” plus parts - in case it wasn’t covered by warranty. By what I’ve read, the belt is NOT covered by warranty, only the pulleys up to 36k miles. I passed on their offer and just bought a new belt for 40 bucks.
    What did you guys end up doing?
  17. Mar 22, 2020 at 3:57 PM
    styk
    styk Well-Known Member
    Greg
    New Brunswick
    Inferno 17 TRD Sport DCLB 4x4
    in-channel vent visors
    wobble likely means a bad bearing in the pulley.
  18. Mar 22, 2020 at 9:45 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
  19. Apr 3, 2020 at 3:15 PM
    mulishan909
    mulishan909 Well-Known Member
    Mulishan909
    2017 Tacoma TRD Sport
    Mine is doing the same. And I noticed the pulley wobbly. Some people are experiencing the same and it the pulley going out already. I guess these are cheap bearings inside with less grease and it's probably all dried up. I ended up buying 2 pulley#2 and one pulley#1. Going to change them out this weekend since they are probably gonna go bad soon as 1 or 2 is already. I usually stick to oem but these ones are crap from Toyota or whoever manufacturer these oems for them cough China
  20. Apr 15, 2020 at 3:34 PM
    SandyTaco4x4
    SandyTaco4x4 Well-Known Member
    Southern CA
    17 DCSB/AT QS TRD Sport 4x4
    How did it go? Did that fix your problem?
