THE RETROFIT SOURCE FX-R / Mini GROUP BUY (only need 10) ROUND 2
Discussion in 'Group Buys' started by ambiguous, Jan 18, 2013.
Thread Status:
Not open for further replies.
  1. Jan 18, 2013 at 9:28 AM
    ambiguous
    ambiguous [OP] Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    For anyone else that wants in on this, you have until Monday January 28th 7 AM PST. 25% off stage III kits and please add $10 for shipping. I will place the order with Matt @ TRS first thing Monday morning.
    Thanks! My PayPal is
    burt.truong@gmail.com
    25% off:
    FX-R Stage III
    Mini H1 Stage III
    Mini D2S Stage III
    __________________
    http://www.theretrofitsource.com/index.php
    -Stage III complete kits
    -no CBI's/SVS discount
    -10 orders = 25% off
    -ships when 10 orders are completed
    -THIS RETROFIT IS PURCHASED DIRECTLY FROM ME. WILL DROP SHIP FROM TRS
    -shipping is flat rate of $10 within continental U.S.
    -$30 shipping to Canada
    info posted by buzzardsgottaeat
    A lot of people get the mini (H1 or D2S) because they're easiest to install
    FX-Rs are better quality but require free hand cutting of your light housing and a slightly more difficult aiming/securing process.
    Blazers are for fogs, you have to cut/rig it up custom, no plug n play or bake n reseal there.
    H4 headlights
    H10 fogs (H11 for 2012s) are the sizes you need and the harness will be the H4/9003 iirc
    H1 has been deemed a little brighter while D2S more even output. Most go with the H1 simply because its brighter but don't consider other factors. Matt and the guys at TRS mostly favor the D2S and I also like to point out that the larger shrouds fill our headlights better than the mini H1 and there is a greater selection.
    3000k is yellowish and good for fogs for its ability to cut through adverse weather
    4300k is like sunlight or stock color headlights and has the highest lumen count (brightest) of the available options
    5000k will be whiter and is the highest TRS recommends.
    6000k is also very white with a tiny bit more blue
    Any higher temp is stupid because you lose light output and fatigue your eyes and others.
    I always say 4300k is the way to go but can see how white/5000k has an appeal
    The upside to a projector retrofit vs cheap hid bulbs in your stock light housing is mainly that it is higher quality and has a clean cut off line.
    I can't think of anything else off the top of my head but that should be a good starting point for anyone who wants to start researching these.
    please add your name to the most recent list.
    1.
    2.
    3.
    4.
    5.
    Picture below is omac5's FX-R retrofit. (let me know if you want picture taken down)
  2. Jan 18, 2013 at 9:44 AM
    CO_Steve
    CO_Steve Active Member
    Monument,CO
    11 SR5
    1. CO_Steve (mini H1)
    2.
    3.
    4.
    5.
  3. Jan 18, 2013 at 9:48 AM
    jcmartinez17
    jcmartinez17 Well-Known Member
    jc
    ontario
    10 trd tacoma prerunner
    would you be doing the install or would this just be for the retros?
  4. Jan 18, 2013 at 9:50 AM
    ambiguous
    Burt
    2012 DCLB TRD
    This is just for the retrofit kit itself. If you purchase a retrofit through me, I have it priced with the kit already.
  5. Jan 18, 2013 at 11:48 AM
    ambiguous
    Burt
    2012 DCLB TRD
    2. KJaikaran (mini D2s)
    3.
    4.
    5.
  6. Jan 18, 2013 at 12:20 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Whats the difference between the D2S 2's and 3's?
  7. Jan 18, 2013 at 12:59 PM
    ambiguous
    Burt
    2012 DCLB TRD
    Not sure what you mean by D2S 2's and 3's
  8. Jan 18, 2013 at 1:05 PM
    Fivespeed
    Fivespeed Well-Known Member
    Tualatin, Oregon
    '12 TRD Offroad w/ Entune
    I'm currently looking for someone local that can do the retrofit for me otherwise you could add me to the list now. Great timing
  9. Jan 18, 2013 at 1:07 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    My question about these: When folks do the BHLM, they say it may suddenly become prone to water and condensation in the housing. Does the same go for this? Are mud puddles and water safe?
  10. Jan 18, 2013 at 1:12 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    If it involves opening the headlight and resealing it, then the answer to your question is yes. Yes it will become prone to ocndensation/fogging inside the housing.
    seal it properly and your ok. splash puddles and what not are ok.. i wouldnt go diving with ur truck.
  11. Jan 18, 2013 at 1:20 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    ^^ Thank you!
  12. Jan 18, 2013 at 1:42 PM
    VolcomTacoma
    Jeff
    NorCal
    Well i see there's the version 3.0's and version 2.0's on TRS
  13. Jan 18, 2013 at 2:07 PM
    ambiguous
    Burt
    2012 DCLB TRD
    Mini D2S 3.0 has not been released. If you've read about it on HIDplanet - yes a revised version is being worked on. If it's an older post about a 3.0 - typo or error on the OPs info.
  14. Jan 18, 2013 at 4:53 PM
    ambiguous
    Burt
    2012 DCLB TRD
    2. KJaikaran (mini D2s, Gatling Gun, 5000k, no glue)
    3. RMeserole12 (mini H1, Gatling Gun shroud, 5000k bulbs, halos, glue)
    4.
    5.
    Please feel free to add yourselves.
  15. Jan 20, 2013 at 3:48 PM
    cscott4
    cscott4 New Member
    Cody
    Rio Linda, CA
    03 dbl cab
    4. cscott4 (Mini H1)
    5.
  16. Jan 20, 2013 at 3:57 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Oh man, TRS GBs from two fronts!
    Maybe the Forester needs some . . . hmm.
  17. Jan 20, 2013 at 9:57 PM
    blizz86
    blizz86 Active Member
    Blizz86 over from t4r.org, and i also posted a message over there about this.
    I am interested in a set of the FXR stage III ..
    so its 25% off of the 315 correct?
    And can i pick it up from you? Im located in irvine, neighbor :)
    FXR (LHD, 3" lens if possible?)
    3five ballast, 3five bulb 5000k
    gatling gun 2.0 shroud (these would fit the 3" fxr right?)
    9003/h4 harness (4runner here :D)
    and no glue
  18. Jan 21, 2013 at 8:27 AM
    blizz86
    a friend of mine is going to be ordering through me
    5. blizz86 (fxr stage 3 3" lens LHD, gatling gun 2.0, 35w ballasts + 5000k bulbs, 9003/hb2/h4 harness, no glue)
    6. blizz86 (fxr stage 3 2.5" lens LHD, e46-r extended shrouds, 35w ballasts + 5000k bulbs, 9006 harness, glue)
  19. Jan 21, 2013 at 9:11 AM
    ambiguous
    Burt
    2012 DCLB TRD
    Price is correct. You are welcomed to pick up from me in Santa Ana or I can ship to you directly.
  20. Jan 21, 2013 at 9:12 AM
    ambiguous
    Burt
    2012 DCLB TRD
    4. cscott4 (Mini H1, XB35 5000k bulb upgrade, E46R extended shroud, h4 harness)
    6. blizz86 (fxr stage 3 2.5" lens LHD, e46-r extended shrouds, 35w ballasts + 5000k bulbs, 9006 harness, glue)[/QUOTE]
    Only 4 more!
Thread Status:
