The Ranger's First Look Tire Review: Hercules Trail Digger M/T
Discussion in 'Wheels & Tires' started by Maticuno, Jan 16, 2012.
  1. Jan 16, 2012 at 12:33 PM
    Maticuno
    Maticuno [OP] Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    We'll start off with some background info:
    I am a law enforcement ranger responsible for the back country patrol of 27,000 acres plus some extra surrounding zones of impact. My patrol vehicle sees at least 50% of its miles off-road in 4 wheel drive. The most common types of terrain I drive are soft sand, sharp rocks, and hot pavement. The type of driving is usually code 3, which means lights and sirens or at the very least just hauling ass either chasing someone or responding to a medical call. Needless to say, I am extremely hard on tires. For those of you curious, my patrol truck is a Chevy Colorado. Certainly not my first choice of vehicles, but it gets the job done.
    Unfortunately, with the state budget cuts, I can't always purchase the absolute best and top of the line. I would have loved to pick up some Cooper Discoverer ST Maxx's, but those are far too expensive. While shopping around this time, I came across the Hercules Trail Digger M/T. It had higher than average reviews, and the price was right at $150 a tire for 30X9.5R15's. Three of the tires balanced very well, with the other taking a couple of large weights to get it right.
    The first thing I noticed was the smoothness. Compared to the previous set of Firestone Destination M/T's (a tire I highly recommend, BTW), they felt like riding on a set of A/T's. As far as noise, they are quiet for an M/T, one of the quietest I've used. On road handling is a little bit lacking, but the same is true for most M/T's, and if you are used to driving with a meaty, knobby tire then you probably won't notice a difference.
    Off-road handling is a different story. The name of Trail Digger is quite adequate. Once the rubber hits the dirt they grip like velcro. Soft sand traction is the most admirable. Even in the deepest of sand with lots of other tracks cut through, these tires want to make their own line instead of "floating" around like other tires do. Steering response is great and I have no worries of ever drifting off-course in the soft stuff.
    Driving over sharp rocks and boulders is equally sure-footed. I was a little aprehensive of this load range "C" tire having only a two ply sidewall, but so far the built in "stone blockers" seem to be doing their job as the amount of rock rash I usually see just isn't happening.
    Tread life is something I'll have to watch. M/T's usually don't fare that well, especially with me at the helm. I killed a set of BFG A/T's in only 15,000 miles. I have not yet seen any chunking or chipping, but I only have about 1,000 miles on them so far. Also, being in the desert in a drought-like winter, I have yet to run the Trail Diggers in mud, snow, or ice.
    Bottom line:
    Would I purchase these tires for my own vehicle? Yes...if I were in the market for an M/T. With the type and amount of off-road driving I do in my Tacoma I can't justify the increased price and decreased life span, on road handling, and all around comfort over an A/T. However, if I were moving to Colorado or some other state with a good mix of snow and mud, I would consider the Hercules Trail Digger M/T in the top of my list of tires to choose. Are the Trail Digger's the best tire? No. Not hardly. But for the price and the features you get with a low cost, American made tire, they are certainly worth considering.
    UPDATE: 4/15/12, 5,000 Miles
    Finally hit 5,000 miles and rotated the tires for the first time. There are some small cuts and chips in the tread, but overall they are holding up very well. At this point I'm anticipating 20,000 miles out of these, which translates to about 40-50,000 for normal drivers. These tires perform the same no matter the surface they are on. I feel confident in complete traction whether I'm on asphalt, hard packed dirt, deep soft sand, light mud, sharp rocks, and/or boulders. The Trail Diggers see the most severe use on some of the worst terrain imaginable. Google Image search "Last Chance Canyon V Notch" to see an example of the areas they are being used in. I have not been stuck once with Hercules Trail Diggers due to lack of traction. There are only two reasons why I wouldn't purchase these for my personal vehicle: 1) They don't make a load range "C" in the size I need. 2) I'm already dead set on the Treadwright Guard Dogs. Other than that I wouldn't hesitate on making this purchase.
    UPDATE: 7/27/12, 9,000 Miles
    I was starting to dislike these tires, thinking that they were getting unmanageable as they wore. Then at 9,000 miles I had them road force balanced. What a difference! Back to being smooth as glass on the highway!
    UPDATE: 12/22/12, 15,000 Miles
    I can safely assume that I will get 20,000 useable miles out of these tires. They are still performing flawlessly even after some of the most aggressive driving over brutal terrain. There are a few cuts in the sidewall and good chunks taken out of the lugs. Tire pressure is almost always 25psi or less. With all of this in mind, I would estimate a normal person would get almost 40,000 miles on these. Verdict: I am extremely happy with the purchase and would recommend the Hercules Trail Digger to anyone wanting an affordable M/T that thrives in desert driving.
    UPDATE, 3/9/13:
    We had a late season winter storm come through the area. Precipitation was forecasted, but not the amount of snow that fell and stuck. A portion of Highway 14 in my area is high enough elevation that snow can become a hazard. With snow falling and Caltrans plows 30 miles away taking care of Tehachapi pass, I spent almost 2 hours slowly driving back and forth in a few inches of snow and slush with my code 3 lights on slowing down traffic and calling out spinouts to my dispatch as they happened. At near the end of their life, the Hercules Trail Digger M/T's still stuck to the pavement quite well. Reasonable speeds, proper throttle and brake pedal control in conjunction with 4 wheel drive and I never lost traction.
    I also noticed that I have a nail in one of the tires and it isn't losing any air. Replacement tires are ordered but will take a few weeks before they come in. Until then, I am still fully confident that the HTD's will perform just as well as they have since day one.
    END OF LIFE UPDATE, 4/22/13 - 20,000+ MILES:
    The new tires have finally come in and the Hercules Trail Digger M/T's will be retired this week. Over 20,000 miles with the kind of severe abuse I put them through is absolutely outstanding. They are down to about 5/32's and while they still have a bit of life left in them, I am starting to see a little bit of sidewall cracking due to running them constantly hard at high speeds with pressures below 25 psi. I have only had one puncture due to a nail. Not a single sidewall gash or rock puncture through the tread. This is the first set of tires I've run out here where I can say that.
    I would recommend the Hercules Trail Digger M/T without hesitation to anyone needing the looks and performance of a maximum traction tire. The only reason I am not buying them again is that a change in staffing has me driving the paved roads a lot more often than driving the back country. Stay tuned for my "first look" review of the Hercules Terra Trac A/T.
  2. Jan 16, 2012 at 4:34 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Those look good. I'm starting my tire search now although I won't need them until the fall and these are on my list. Let us know how they wear please.:)
  3. Jan 16, 2012 at 4:41 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
  4. Jan 16, 2012 at 4:59 PM
    Maticuno
    2011 Suburban 2500
    I will definitely keep posting updates. If I get 20,000 miles out of a set of tires on my patrol truck, that's doing great. Got 23,000 out of the previous Firestone Destination M/Ts.
  5. Jan 16, 2012 at 5:09 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Well damn, I literally just found out about these tires today like 4 hours before I saw the OP.
    This review is really sending me in their direction as I can get them at an even lower cost. I could get a 235/75/15 for $111.37 (ad on TireDiscounters runs $147)
    At least on their website (Hercules tire), they had a decent snow rating.
  6. Jan 16, 2012 at 5:27 PM
    medictrack
    medictrack Well-Known Member
    Bill
    Colorado
    2011 tacoma 4x4
    relentless sliders bullet proof front skid pro comp bilstein lift fj trd tt wheels duratracs
    Damn I like those tires keep us posted by the time I need new tires I will have to consider these.
  7. Jan 16, 2012 at 5:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Sounds like Hercules tires have come a long way since my last set. I had a set on a Ranger in highschool and they only lasted for 12k miles.
  8. Jan 17, 2012 at 5:01 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I pulled the trigger on a set of these. Read some good reviews from a couple other sites.
    Same size.
  9. Jan 18, 2012 at 8:54 PM
    Maticuno
    2011 Suburban 2500
    Pics on the truck?
  10. Jan 19, 2012 at 1:01 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Not yet. I only have 2 at the moment, sitting at work. Warehouse they came from only had 2 left (??good sign..their being bought??) so I had to pay a little extra to get 2 more shipped to me...or have to wait 4 or more weeks for 2 more.
    Other 2 will be in next week.
    Gives me time to think of how I'm gonna explain this one to the other half....I've been preparing her, "What you gonna do when I just show up with different tires...??"
    (RuggedFail's in the background....NOT MINE...I can see why they suck.)
  11. Jan 19, 2012 at 5:58 AM
    Maticuno
    2011 Suburban 2500
    I'm pretty sure my wife wouldn't notice right away.
    And yes, when I ordered them for my patrol truck they took about 12 days to come in from the nearest warehouse. I think it is partly the 30X9.5R15 size. It seems hard to find in any brand.
  12. Jan 20, 2012 at 2:21 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Hercules Tire Webiste: http://www.herculestire.com/
    Scroll down just a little bit and off to the "center-right" is a Review of the TD M/T from Petersen's 4 Wheel & Off-Road. They tested some TD M/Ts in Moab over several days.
    Maticuno,
    This will my first real experience with M/Ts, I've driven/riden on KM2s before so it's not a totally strange world. My biggest concern is really with tire pressure. What are you running? Do you air them down?
  13. Jan 20, 2012 at 6:41 AM
    Maticuno
    2011 Suburban 2500
    Because these are on my patrol truck and I occasionally have to go high speeds on the highway, I can't air them down as much as I'd like. I've got them down to around 30psi which is right at the level where the TPMS warning light comes on on cold mornings.
  14. Jan 20, 2012 at 5:22 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Other 2 tires actually made it in today!! Hopefully by the end of the work tomorrow they'll be on. Have to hit up the Oil change, diff fluid and trans fluid changes as well.
    Wife knows about it, so that coast is clear. It's money I've been saving anyway.
  15. Jan 21, 2012 at 3:39 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Alturas? Susanville?
  16. Jan 21, 2012 at 4:06 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Their on!!!!!!!!!!!
    Wow!!!!!
    Like I said, I've driven/riden on KM2's and when you take off or almost come to a stop you can really feel the tread lugs, always felt like the vehicle was "walking"...if that makes any sense.
    These? Not even close to anything like that. I totally agree with the "smoothness" comments from Maticuno. Smooth for a MT.
    They do hum obviously, but I was not annoyed. I did not get a chance to get over 45MPH. The combo of my muffler (wicked flow) and the tires is interesting.
    I did get to use them in some light snow/slush and seemed to be decently mannered. I rev'd it up then hit the brakes real fast (in a parking lot, behind my work) and she didn't slide much, a little squirm maybe. ABS did kick in for a brief second though....THEY PERFORMED BETTER THAN MY DESTY A/T's however, which had the ABS kicking in pretty good sometimes. Seemed to have decent "take off" traction as well. I could kick out the rear end in the Desty A/Ts in snow pretty easy and get a good slide, the TD M/T definitley provided better traction. I'd like to get an open area where I could screw around a bit more with them.
    Pics suck, didn't get them on until it was dark. Still....
  17. Jan 21, 2012 at 4:18 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I'm really liking the looks of these tires. Curious as to how much you paid for them.
    Nevermind just saw you're running 15 inch.
  18. Jan 21, 2012 at 4:41 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
  19. Jan 21, 2012 at 4:54 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I was just looking to get some real world pricing on some 265/75/16's. Thanks for the link, where did you get yours?
    Edit: guess I've had one too many beers tonite...thanks for all the info
  20. Jan 21, 2012 at 5:22 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Through my work, so I'm not much help on pricing.
