The Pros and cons of wheel spacers
Discussion in 'Wheels & Tires' started by mjm540ii, Feb 28, 2012.
  1. Feb 28, 2012 at 9:46 AM
    mjm540ii
    mjm540ii [OP] Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Ok, as it stands, I know little about this subject. I am starting this thread so others like me will be able to find all they need in one place. I understand that spidertrax and all pro seem to be the brands to buy. Please discuss the pros and cons along with any experiences regarding the use of wheel spacers, including success (better wheel clearance, etc.) and failures (ball joint problems, etc.). Hopefully this helps others considering wheel spacers other than myself.
    Thanks
    Deucer01 likes this.
  2. Feb 28, 2012 at 9:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    Just an FYI, ECGS sells Toyota spacers in different thicknesses also.
  3. Feb 28, 2012 at 10:23 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    whatever brand you choose to buy, make sure they're hub centric adapters. i have a set of allpro and my brother has a set of spidertrax, neither of us have issues. we both added them to get push out the stock Toyota wheels after our lifts. torque them properly and you should not any issues.
    strongrob likes this.
  4. Feb 28, 2012 at 2:10 PM
    mjm540ii
    Oxford, PA
    pros? cons? experience?
  5. Feb 28, 2012 at 3:37 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Thanks for the link! Op, I have never seen anyone on this site have an issue with spacers. I've never seen anyone on this site complain about a proper spacer
  6. Feb 28, 2012 at 3:44 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    been running spidertrax for 3 years now. no problems and they do the job
  7. Feb 28, 2012 at 4:09 PM
    mjm540ii
    Oxford, PA
    just wanted to know, whats the deal with the rumor about bad ball joints? Why Run with spacers in the first place??
  8. Feb 28, 2012 at 4:12 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    i run them for clearance. I have TRD rims with a wider tire and it was contacting the UCA. Now they have plenty of clearance.
  9. Feb 29, 2012 at 9:26 AM
    sixsixsix
    sixsixsix Well-Known Member
    I have 1.5" AllPro spacers. I got the ET style lug nuts for more bite and for piece of mind. Mine are lug centric and I have TRD TT wheels mounted to them. The conical seat lug nuts will self center the spacer and wheel to the hub.
    Ive had mine installed for about a year now with no issues. I use them to get a wider stance.
  10. Feb 29, 2012 at 10:18 AM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    Wheel spacers push the wheel out from the hub. This extra distance acts like a lever on the joints etc. You know how the longer a pry bar is the easier it is to move something? Well, now apply that to your wheels.
    That's how I understand it. May not be 100% accurate. Just think of the extra leverage they cause.
  11. Feb 29, 2012 at 10:25 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Aftermarket wheels give you the same backspacing, making the effects the same. Spacers also give you more threads to tigten the wheels too as aftermarket wheels usually only leave a few threads for the lig nut.
    All that being said i have run my spidertrax for 50k and a dozen wheeling trips and havent had one single problem. Needed them to keep my 35s off my camburg spindles
    Catfish21 and Jcole like this.
  12. Feb 29, 2012 at 1:39 PM
    drifter
    Sam
    Oregon
    good stuff
    nice. I'm not saying that with spacers you will have problems. You may have problems, you may not.
  13. Mar 4, 2012 at 1:01 PM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    Ok, got that stuff. OP thanks for the thread.
    So my tires rub barely at full lock only. I have a 3 in lift and 275/75/R17 Goodyear Wrangler MT/R w/Kevlar on them. If I get 1.25 in spacers, will I get more rubbing? I don't know how if you push them out you get more rubbing, but I've heard it in threads.
    Will I get more? Stock wheels for TRD Sport 17 in.
    2K01SpaceOtterSea likes this.
  14. Mar 20, 2012 at 11:33 AM
    Sunner
    Sunner Well-Known Member
    I tried searching but could not find the answer so Ill ask here, will getting 1.25 or 1.5" spacers cause my stock size tires to rub my fenders? On a 2nd gen.
    EDIT: I meant to say at stock height(no lift)
  15. Jan 13, 2015 at 9:03 AM
    AustinDeh
    AustinDeh Well-Known Member
    Austin
    SoCal
    04 SR5 TRD 4x4
    What is the correct Torque specs for these? I have the Allpro 1.25" but can't find the specs anywhere and don't want to put them on until I do. I read somewhere that its between 80 - 100 ft/lb.
  16. Jan 13, 2015 at 2:08 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    I torqued mine at 80. No problems so far
  17. Jan 13, 2015 at 2:21 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I bought the spydertrax 1.25 for all 4 wheels. No issues. I rubbed the cmc and fender more but alittle trimming fixed that.
    Casper66 and kskm497 like this.
  18. Sep 9, 2016 at 10:38 AM
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    I see of a lot of these spacer horror stories. Are these happening due to cheap spacers or improper use?
  19. Sep 9, 2016 at 10:47 AM
    Mademan925
    Nick
    Discovery Bay, CA
    Probably alittle of both. Spacers need to be high quality and hub centric. Also, they need to be installed correctly and re-checked every 10,000
    Bulljolly and CementTRDOffRoad like this.
  20. Sep 9, 2016 at 10:50 AM
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Mostly I see people saying they had studs sheer off. What causes a stud to sheer off? Low quality metal? Loose attachment?
