The PRINSU How To Thread
Discussion in 'PrInSu Design Studio' started by zscott, Jan 26, 2016.
  1. Mar 23, 2017 at 9:10 AM
    #121
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    At the lowest setting for mine I'm ~1/4-1/2 off my roof.
  2. Mar 23, 2017 at 9:29 AM
    #122
    perkj
    perkj Well-Known Member
    I'm in the same boat. I've sent a couple question emails about the racks before I purchase and so far no responses. I'll try PMing him here base on the feedback others provided here.
  3. Mar 23, 2017 at 9:31 AM
    #123
    C4 Fabrication
    C4 Fabrication Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    Ok I will try that as well. I tried everything I could to get mine to touch the roof, but it wont adjust back that far. I have about a 1/2" gap and it makes a lot of wind noise. I may take the deflector off and put a slight bend in it on our press brake to get it to touch the roof. But I wanted to contact Prinsu first to see if there is another solution.
  4. Mar 23, 2017 at 9:39 AM
    #124
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    I know Zach is a little behind on orders right now b/c of some issues with some vendors he uses. So he may be trying to respond to other emails related to outstanding orders. He is generally pretty responsive, though he has a normal 9-5 so his responses often come in the evenings. Also a husband and father - so I'm sure his life is about as hectic as can be right now.
    As to the wind noise, there is a weather strip that Zach sells on his website. This should fill that gap and rid most of the wind noise. As to whoever said their rack is "touching" the roof, I'm guessing you mean the weather stripping is touching the roof. Otherwise, you're going to rub your paint off pretty quickly.
  5. Mar 23, 2017 at 9:54 AM
    #125
    winguyen
    winguyen Well-Known Member
    Kevin
    Watertown, MA
    2014 Pyrite-Mica DCSB TRD Off-Road
    Yes it's the weather stripping is touching my roof but if it wasn't there it would definitely be scratching my paint off. My deflector has a slight "bow" to it at the lowest setting so it's pretty snug.
  6. Mar 23, 2017 at 10:37 AM
    #126
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Mine did come with the weather stripping and I have it installed. But there is still about a 1/2" gap. I will probly just remove it and add a slight bend on the press brake to get the rubber strip to seal against the roof.
  7. Mar 23, 2017 at 10:39 AM
    #127
    Mcdees84
    Tallahassee, FL
    Pics? I don't think I've heard of anyone having that big of a gap with the deflector on the lowest setting.
    scott96929 likes this.
  8. Mar 23, 2017 at 10:50 AM
    #128
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Neither I, would like to see.
  9. Mar 23, 2017 at 10:53 AM
    #129
    LEXICON
    LEXICON born where the prairies meet the rockies
    Courtney
    Canada
    2016DCLBBLACKTACOMATRDSPORT4X4PREMIUM
    Nothing worthy
    Lowest setting on my 3gen, maybe 1/2"
    Never tried the rubber thing. very little wind noise.
    PNWTacoma likes this.
  10. Mar 23, 2017 at 10:56 AM
    #130
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Looks like the 3rd gen rack sits a little further forward than my 2nd gen.
    sierra141 and scott96929 like this.
  11. Mar 23, 2017 at 11:04 AM
    #131
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
  12. Mar 23, 2017 at 11:05 AM
    #132
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Couple pics for you guys. Its more like 3/4" gap at the ends and 1/2" in the middle. DSCN4608.jpg DSCN4609.jpg DSCN4607.jpg
  13. Mar 23, 2017 at 11:06 AM
    #133
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    I tried moving the deflector cross bar down one more set of holes to the lowest point and it still had about the same gap.
  14. Mar 23, 2017 at 11:33 AM
    #134
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    It should be pretty close, within a 1/2". With the noise reducing edge trim the bulb touches the roof on mine when it is in the lowest setting.
  15. Mar 23, 2017 at 11:34 AM
    #135
    zscott
    Zach
    Utah
    Wheat year truck? Mine touches when it is on the lowest setting.
  16. Mar 23, 2017 at 11:51 AM
    #136
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    This deflector is not at the lowest setting. If it is installed at the lowest setting, the deflector with the seal will just touch the center part of the windscreen.
    Below is set at the lowest setting.
  17. Mar 23, 2017 at 12:06 PM
    #137
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Saw the same thing. You can lower that sucker another spot down.
  18. Mar 23, 2017 at 12:12 PM
    #138
    winguyen
    Kevin
    Watertown, MA
    He said he tried the lowest setting a few posts up. My deflector is currently on the lowest setting but it did touch the roof in the middle as well.
  19. Mar 23, 2017 at 12:31 PM
    #139
    Mcdees84
    Tallahassee, FL
    Not sure how the gap could be the same if you lower it to the next mounting holes, which are about a 1/2" lower. Not calling you a liar, just baffles me how that could be possible.
    MountainManGuy likes this.
  20. Mar 23, 2017 at 1:12 PM
    #140
    Lone Walnut
    Lone Walnut Well-Known Member
    Kirk
    Northcentral PA
    2016 Tacoma OR DC/1998 Reg cab
    Yep, I agree. If you move the fairing down to the lowest holes, you should be in good shape.
