THE PERFECT TUNE UP
Discussion in '1st Gen. Tacomas (1995-2004)' started by heiserb, Jun 26, 2015.
  1. Jun 26, 2015 at 2:16 AM
    heiserb
    heiserb [OP] Member
    brad
    honolulu
    98tacoxtracab4x4
    comeple sound system,mids tweeters and sub Sport rims off a 2010 tacoma
    This thread is to organize everything that can be done for the perfect tune up, I am very interested in hearing suggestions and what you would do.
    the scenario is; you have purchased a 1st gen tacoma with somewhere between 90k and 150k 3.4L v6 and you want to make sure that you can give it a compete tune up that will bring the performance of the vehicle from okay to Great and lets try to keep it under 500$ ( Lets assume timing belt and water pump have already been replaced )
    My Tune up would go as follows
    Oil and oil Filter
    air filter
    Spark Plugs and wires
    coil packs ( sort of optional; pricy )
    Fuel Filter
    pcv
    very interested to see what you guys have to say and to learn from your responses
  2. Jun 26, 2015 at 2:33 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Wires? Coil packs? That's not a tune up, that's a major redo. But you do have a truck that's almost 20 years old..............
  3. Jun 26, 2015 at 2:42 AM
    gearcruncher
    Canadain bumper technician
    throttle body cleaning . cheap and very effective . there is a write up with pics on here
    LeakyAC and scocar like this.
  4. Jun 26, 2015 at 3:14 AM
    heiserb
    heiserb [OP] Member
    brad
    honolulu
    98tacoxtracab4x4
    thanx for the suggestion, dang that is quite a lot of gunk build up, gonna have to tackle this one soon
  5. Jun 26, 2015 at 6:43 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Clean MAF
    Check (and if necessary adjust) valves
    Check resistance of critical sensors (temp, knock, cam, crank, etc)
    heiserb[OP] and scocar like this.
  6. Jun 26, 2015 at 8:00 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Oil and oil Filter Mobile 1 Full Synthetic with Purolator oil filter.
    air filter The cheapest. No cotton gauze filters. More harm than good.
    Spark Plugs and wires NGK Double ground
    coil packs ( sort of optional; pricy ) Replace only as necessary.
    Fuel Filter Replace every 30K miles. Sooner if the environment is dusty.
    pcv Replace when necessary.
  7. Jun 26, 2015 at 1:59 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Oil change - full synthetic, OEM filter
    Fluid changes all around
    Turkey baster power steering fluid replace method
    Grease driveshaft
    Rotate tires
    Chevron Techron bottle in empty gas tank, fill to 1/4, drive for a couple of days, then fill fully
    New PCV valve and grommet
    New wires, plugs, and coil packs (keep spare in case one fails)
    Throttle body, IAC cleaning
    New air filter
    Coolant flush
    Check hoses for wear, replace as necessary
    Condition or replace belts
    Carloss1017 likes this.
  8. Jun 26, 2015 at 2:04 PM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Add inspect and replace dried and cracked vacuum lines. I had quite a few on my '02 that were so loose they came off with minimal effort. Smoothed out my idle for sure when I popped some new silicone lines on.
  9. Jun 29, 2015 at 10:18 AM
    beedoola
    beedoola Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    A little more info on the Turkey Baster PS fluid method. Sounds pretty straight forward, but does just replacing the fluid in the reservoir have an effect on the fluid that remains in the PS lines?
  10. Jun 29, 2015 at 10:29 AM
    Indy
    Indy Master of all I survey.
    On average, yes, as a total no. If you want to replace all the fluid, without doing multiples to get it all you'll need to drain and replace it all.
  11. Jun 29, 2015 at 1:42 PM
    beedoola
    San Francisco, CA
    after watching some youtube videos, this guy drained his PS fluid completely. Is there a Tacoma guide/how to like this?
  12. Jun 30, 2015 at 2:19 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If you suck out and refill the PS reservoir a few times, enough to use up almost an entire quart, you will have roughly 60-75% fresh fluid.
  13. Aug 8, 2023 at 11:33 AM
    Carloss1017
    Carloss1017 Well-Known Member
    Carlos
    SoCal
    95.5 Tacoma 4wd 2.7L
    Has anyone had problems passing smog ? I did a full tune up and was sure it was going pass smog but didn’t ? Any suggestions on how to get it to pass
  14. Aug 8, 2023 at 11:35 AM
    Carloss1017
    Carlos
    SoCal
    Hi do you have any tips on passing why / how to get smog to pass on my Gen 1 Tacoma
  15. Aug 9, 2023 at 9:53 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    First thing is put an OBD meter on it and look for codes. The engine light in mine never came on but it had upstream O2 sensor code, replaced both O2 sensors and all good. Thankfully I didn't have to replace cat(s.) This was in Cal in 2018, passed.
    Carloss1017[QUOTED] likes this.
  16. Aug 10, 2023 at 6:02 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    My truck needs wires every two years.....What size small vacuum lines behind the engine
  17. Aug 10, 2023 at 8:53 PM
    Carloss1017
    Carlos
    SoCal
    Got it I’m throw the scanner tomorrow morning . Did find that the power steering air control valve was broken and they Mickey Mouse it. Replacing that …. Also I think I’m missing a EVP sensor I was looking at a diagram . I found this hose that’s top off with a screw. So I’m amusing that was once connected to the EVP sensor
  18. Aug 10, 2023 at 8:54 PM
    Carloss1017
    Carlos
    SoCal
  19. Aug 10, 2023 at 9:30 PM
    ToyTech_PNW
    ToyTech_PNW OG Toyota Customer
    Jeremy Jamm
    NW-PNW
    2004 GX470
    AISIN Timing Belt Kit, cracked dash...
    Looks like your EGR valve that failed is a good place to start. It is most likely partially stuck open. How does it run at idle? Smooth? Rough?
  20. Aug 10, 2023 at 10:19 PM
    Carloss1017
    Carlos
    SoCal
    It Idle high. when I’m driving it feels rough but not so bad If that make sense I hear the rpm’s running high. Also the smog guy told me that they were running high for its specs . And that my timing was off ? Didn’t really catch what he was telling me. I Could post a video tomorrow of how it sounds when I turn it on.
